Results 1 to 10 of 10
Thread: Cash T&C grinder
2nd Jul 2017, 12:54 PM #1Intermediate Member
- Jan 2009
- Auckland, NZ
- 32
Cash T&C grinder
I recently swapped some money for som Cash - a CC model D tool and cutter grinder. I paid to much for it.
how do you adjust or set the spindle bearings, and what does the machine use for lubrication.
e spindle is very stiff and not consistent during a rotation. If it starts, it will go for a couple of seconds then slow and stop. It doesn't seem warm to touch.
geoffLast edited by Big Shed; 2nd Jul 2017 at 02:03 PM. Reason: Please read forum ToU
2nd Jul 2017, 02:17 PM #2
You will get a better idea of whats going on if you pull it apart and clean everything and check for worn out parts .
2nd Jul 2017, 11:02 PM #3Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,039
Assuming you are talking about the CC Engineering model D TCG, there are several threads on here about them, lots of photos to look at. On early models the spindle runs in substantial split bronze bushes, screws in the casing allow you to adjust the clearance between the shaft and the bush. On later models the spindle runs in bearings. The spindle housing is partially oil filled to provide lubrication in either case.
3rd Jul 2017, 08:08 AM #4Intermediate Member
- Jan 2009
- Auckland, NZ
- 32
Thanks to everyone for your replies. I had a look in the weekend and the spindle has a thread and nut on the right hand end that pulls up on a bush. adjusting this and good lubrication made a difference.
photos coming later. It has seen a bit of life, with the grey paint coming off easily with baby blue paint underneath that was applied with a worn out toothbrush... doesn't seem to be much wear on the slides.
it didn't come with much tooling and of course no instructions. There is a motor driven centre which I am not sure how to use, and a pair of dead centres that look like mice have been having a go at them. I cobbled up a jig for drill grinding, but it is not as good as it should be. Anyone have any pics of tooling, jigs
or similar, or instructions of how to use it?
geoff
3rd Jul 2017, 02:05 PM #5Senior Member
- gold coast
- 303
I've got one Geoff, but with no tooling, so I envy your motor driven centre.
I use mine as a very simple surface grinder , holding small pieces onto the table with small super magnets or a tool vice.
I started a thread a couple of years ago here on it's rebuild if it's any help for yiou
regard
brian
3rd Jul 2017, 10:18 PM #6
Cash was a Melbourne company and not related to CC Engineering of Sydney....
I can't recall if Cash made a T&C grinder, but C C certainly did. I too have a small model CC with ball bearing spindle.
I also know the grandson of the Cash family (because I have a Cash horizontal mill) and will ask him next time I speak to him if they ever made a T&C grinder.....
Good find!Cheers, Joe
3rd Jul 2017, 10:28 PM #7Most Valued Member
- Australia east coast
- 2,713
4th Jul 2017, 09:21 AM #8Senior Member
- gold coast
- 303
My machine is made by CC engineering--sorry for th confusion
4th Jul 2017, 01:05 PM #9Senior Member
- May 2015
- Richmond
- 214
This post jogged the mind to get back to assembling a bit more of this one. Could someone with one clarify the spindle length on the left side. The one in this one looks a bit dodgy. It had all the adjusting screws for the bronze bearing but has had ball races fitted at some stage of it's life. Would be good to get the boat anchor off the bench although it may be of some use!! Other than the centres for the table (not complete by the way) there was no other attachments with it.
17th Sep 2017, 01:47 PM #10Novice
- May 2012
- Hobart
- 18
Diagram of my model D spindle
Cash Mill rebuild
By jhovel in forum METALWORK GENERALReplies: 25Last Post: 12th Jan 2023, 06:06 PM -
WITHDRAWN: Cash Milling Machine
By kwijibo99 in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 11th Nov 2012, 10:58 PM
