Results 16 to 16 of 16
Thread: Making a Steel Beam Flat
26th Jun 2017, 09:31 PM #16Golden Member
- Apr 2008
- NSW
- 537
Weight equals sag . So no matter how well you grind or mill it with support it can sag without support . So rigid bracing design but lighter weight will give far less sag once erected .
If you have support options along the length then most sag can be shimmed out . However once you have support along the length you don't need excessive strength .
Welded bracing design can warp and your back at stage one. It all comes back to how the beam is supported as to which beam cross section and strength is best .
A beam that is reasonably straight can be clamped down shimmed and bolted , made straight using a good straight edge and an engineers level . High spots can be found by moving the straight edge from side to side and see where it pivots . Low spots can be found by placing paper strip under the straight edge and see where it pivots or just pulls out . Engineers level can track along the whole length turning the level each time to see if it's straight and level or if there's still humps and hollows.The volume of a pizza of thickness 'a' and radius 'z' is given by pi z z a.
Need someone to bend Flat Steel Bar in Melbourne
By jk200sx in forum METALWORK GENERALReplies: 3Last Post: 20th Apr 2016, 10:39 PM -
Calculating steel beam load capacity
By markgray in forum METALWORK GENERALReplies: 22Last Post: 16th Oct 2015, 04:51 PM -
Sourcing Bright Flat Steel Bar
By ericg in forum METALWORK GENERALReplies: 7Last Post: 26th Sep 2014, 08:11 AM -
Decorative steel - flat bar supplier
By Marc in forum METALWORK GENERALReplies: 3Last Post: 19th Aug 2012, 09:09 PM -
Buying flat bar in grades other then black mild steel
By .RC. in forum METALWORK GENERALReplies: 11Last Post: 28th Dec 2009, 07:08 PM
