Results 1 to 15 of 59
Thread: Worst Shop Day Ever
15th May 2017, 04:10 PM #1Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
Worst Shop Day Ever
Thought I would share this YouTube video I came across, it was linked on the Jimmy Diresta channel, I'm not sure if this could have been prevented, he says in the video comments that the cable had a fibre core that had absorbed moisture and rusted the cable from the inside out, maybe careful storage and periodic replacement could have prevented this, otherwise, just an unlucky accident
https://youtu.be/0Ako5guyzNg?t=5m50s
15th May 2017, 04:24 PM #2Member: Blue and white apron brigade
Pants staining stuff - thanks for posting.
15th May 2017, 04:27 PM #3Most Valued Member
- 4,258
at least Brian wasnt hurt
15th May 2017, 07:20 PM #4
A lesson for us all, particularly in respect to those who have home lifting gear.
Regular qualified inspection and replacement of lifting gear is mandatory at an industrial level,but at home some of us at home might be tempted to avoid an otherwise expensive process.
I have a relatively light lathe to move ( Chinese 12 x 36 ) but will be using a brand new 1 ton sling when I move it from garage to shed.
After 3 years the paint on the floor has cured enough.
15th May 2017, 08:06 PM #5Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
I saw that video the other day, pretty scary.We have to daily checks on our gantry cranes at work and they get a major 3rd party inspection every 12 months. All the crane cables i have ever dealt with have been heavily greased with moly disufide grease for lubrication and to prevent corrosion, that cable must not have been greased for it to corrode from the inside out.
15th May 2017, 09:10 PM #6
You are absolutely correct, Snapatap.
Its not bad luck and we should not be sorry for him. Its a highly dangerous operation and he had not even observed the basics. He is an amateur and never took the trouble to understand the potentially dangerous equipment he was dealing with. Its only sheer luck that we were not watching someone seriously injured.Just look at where the man is standing tells me he does not have a clue.
If you watch the video he uses an endless chain which powers the overhead pulley set. To me, that indicates a really old set up. It is blatantly obvious he who was never properly trained in lifting gear safety and understanding the need for inspection / maintenance.
I went back and watched the video in its entirety. There is a close up of the break. I have a some steel slings which are never used for lifting and the failed cable is the same rust colour as my slings which have not seen oil in 20 years or more.The fibre he speaks is used between layers to avoid friction between strand layers and the failure has nothing to do with the fibre holding moisture and again that alone points to the age of cables as I think the current ones have a plastic of some sort.
See this about how cable is made https://www.youtube.com/watch?v=eDVf71xd2cQ
That cable has not seen grease in decades.
15th May 2017, 09:34 PM #7Senior Member
- Jun 2012
- ex Perth, now Mittagong
- 105
Coming from a crane operator and rigger background I can see why that hoist rope broke. Wire rope for hoists/cranes in my experience do not have fibre cores. Fibre cored wire ropes are used for slings, NOT hoisting. No doubt at some stage of the crane's life the original hoist rope was replaced with a much cheaper fibre cored one.
15th May 2017, 10:11 PM #8Pink 10EE owner
- 6,218
It is somewhere around 12.5 tonne that drill. So not exactly Hercus 9A weight.
16th May 2017, 08:54 AM #9Most Valued Member
I watched the video before reading everyones comments, so didn't really know what was going to happen or when. I needed to change my undies after that!
Crickey!
16th May 2017, 09:48 AM #10Member: Blue and white apron brigade
Anyone watch the preceding video of where the drill was picked up? Listen to the trailer groan as the drill is loaded onto it. I wondered if the moving setup was really up to spec.
16th May 2017, 10:14 AM #11
I have watched a few of Brians videos. He has some huge machines to move into that workshop. He mentioned 3ft thick concrete at the rear of the shop where one of the biggest is to go.
I would not have said he was lacking in knowledge etc, but that cable obviously should have been replaced. It is a very old hoist and the condition of the cable was unknown. I did see a video where he tests the hoist by lifting the rear of a tractor.
16th May 2017, 10:15 AM #12Pink 10EE owner
- 6,218
16th May 2017, 07:15 PM #13Pink 10EE owner
- 6,218
Probably one other thing is I am not sure I would want to meet someone on the highway pulling that weight with such a lightweight vehicle. In Australia I think it would be go direct to jail, do not pass go, do not collect $200. He is probably pulling 15 tonne.
16th May 2017, 07:24 PM #14Most Valued Member
- Jun 2012
- SA
- 1,649
16th May 2017, 08:16 PM #15Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
I hadn't actually watched the video from the beginning, scary stuff all right, he's lucky it let go when it did and not when he was working the endless chain at ground level and under the thing
Is there a prize for the worst thread ever cut HELP!
By th62 in forum METALWORK GENERALReplies: 57Last Post: 7th Sep 2014, 10:39 PM -
Suggestions on a Shop Vacuum?
By Michael G in forum METALWORK GENERALReplies: 31Last Post: 11th Jun 2012, 06:45 PM -
work shop vac
By azzrock in forum METALWORK GENERALReplies: 21Last Post: 20th Aug 2011, 11:42 AM -
QLD Blacksmith course/shop/centre
By Clinton1 in forum THE SMITHYReplies: 2Last Post: 28th Sep 2005, 11:30 AM
