Results 61 to 67 of 67
Thread: Simso's pan brake
23rd Apr 2018, 10:51 PM #61Senior Member
- Aug 2005
- 185
I also recently designed my own belt grinder for sharpening, haven’t quite finished it yet
http://www.mirwa.com.au
1st May 2018, 09:44 PM #62Senior Member
- Sep 2009
- Newcastle
- 341
What was the cost for the laser cutting (or water jet) for the frame?
Nice way to build a strong stiff and dimensionally reliable frame.
8th May 2018, 09:10 PM #63Member
- Jul 2003
- 52
- 67
10th May 2018, 11:53 AM #64Most Valued Member
- 4,255
10th May 2018, 07:26 PM #65Senior Member
- Sep 2009
- Newcastle
- 341
Grinder
18th May 2018, 11:17 AM #66Senior Member
- Aug 2005
- 185
Sorry dont visit often, laser cut charge was about 130 dollars I think, all 6mm mild steel.
Way over designed, it can rotate the grinding head through an arc of 90 degrees, three different bar positions, so you can adapt tool holders onto the unit as well, I went way over the top
I used a motor that I had laying around, since then I have adapted a variable speed three phase motor, so I can go from 100rpm to any speed upwards of 1500rpm.
SteveSteve
18th May 2018, 12:26 PM #67Most Valued Member
- 5,942
Thanks for that Steve, looks a very interesting build, and highly adaptable.
What would be the chance of getting a PDF of the plans and download or similar to take to the profilers PLEASE?
Thanks again,
Lathe brake
By Stustoys in forum METALWORK GENERALReplies: 15Last Post: 29th Sep 2011, 09:23 PM -
Lathe Brake
By Stustoys in forum METALWORK GENERALReplies: 29Last Post: 10th Apr 2011, 08:17 PM -
Lathe brake
By Grahame Collins in forum METALWORK GENERALReplies: 14Last Post: 15th Jan 2011, 10:30 PM -
Brake for Cyclone
By m2c1Iw in forum METALWORK GENERALReplies: 3Last Post: 3rd May 2007, 10:01 PM -
Brake press
By gdk3000 in forum METALWORK GENERALReplies: 2Last Post: 1st Feb 2006, 08:58 AM
