Results 46 to 60 of 67
Thread: Simso's pan brake
25th Apr 2017, 08:10 PM #46Most Valued Member
- 4,258
20170425_182924.jpgScotch keyed the shaft to the pivoter units today.
thank god for super glue!
Is the 1/4 x 1/2 long grub screw going to be okay (thats what i had) or should I re-drill and fit 8mm...cos thats what I have
25th Apr 2017, 08:13 PM #47
Yep, we have the largest Buddhist Stupa here in Bendigo - Karma just spreads out from there (apparently)...
IntroductionCheers, Joe
25th Apr 2017, 11:01 PM #48Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
i forgot about that stupe.
its just a word that pricks my ears up
27th Apr 2017, 09:20 AM #49Most Valued Member
- 4,258
mmm problem
how can you carry out step 17 without step 18 being made and put in place and connected to the top arms?
Maybe Steve will come and have a look and explain?
and what postion does the pivot units for the locking assy canter levers need to be?
15th May 2017, 10:16 AM #50Most Valued Member
- 4,258
DIY Angle iron
I attempted to make a length of heavy (16mm-50x66) piece of angle iron for the cross arm
I thought I could make it with out warping..but no.
I thought I had it clamped to stop that from happening when I welded it
the max bow is about 1.5mm.
Can I machine the bow out without it wanting spring/bow/twist or whatever at a later stage?
It wont matter if it ends up 14mm - 48mmx64
15th May 2017, 11:53 AM #51
Machining is likely to cause it to bow again unless you 'normalise' it in a fire first. If you can, add some welds on the inside of the bow instead to let the weld contraction pull it straight. In other words, counteract the forces that caused the bow. You can grind away some of the weld afterwards.
Cheers, Joe
5th Jun 2017, 12:13 PM #52Most Valued Member
- 4,258
some update pics.
Fingers just needing holes for clamp bolt
Lift up assy started out as 20mm flat black bar. Bohler and the likes was just too expensive
If the liftup bar moves back while folding I can place a set screw (or bolt) on the arm, that its bolted to...well at least thats the plan if it does move back while trying to fold 1.6mm
My lever handle for the clamping assy.
13th Jun 2017, 09:38 AM #53Most Valued Member
- 4,258
its all together
forgot to contour the top arms before I welded the top brace to the arms.
and it works....had a job for it immediately, making some gas burner flame tamers/shrouds for the bbq
from this
to this, made from 1.2 s/s.
It will do small widths of 1.6 (not sure how wide at this stage), but I dont think it will do full width 1.6...need to get a little bit and see?
It will do 1.2 tho...and bolting it to the bench will make it easier. I need to make some hold down clamps as the holes in the feet interfere/conflict with the cast iron supports of the bench.
now to pull it apart and paint it...or CRC long life it might be easier...by not painting it you will also be able to see my brilliant machining and welding, and all the other faults
13th Jun 2017, 05:27 PM #54Golden Member
- Apr 2009
- Ballina N.S.W.
- 644
eskimo,
Good to see that you have finished and better still used it. It sure looks good and robust, what angle did you finally decide on for the fingers?
Bob
15th Jun 2017, 09:10 AM #55Most Valued Member
- 4,258
made them at 30 Bob
the cross arm is just a solid bit of 16mm x 60. I made an angle piece but when I welded it pulled and is now bent. I can get some extra support behind the bar if I need it. Just need to get a few bits of sheetmetal to see what occurs at a few varying width of 1.2.
Also might need to put a support leaf for front ...but can do this later if and as required
2nd Jul 2017, 12:32 PM #56
Eskimo ,
It looks great in the white,but what will you do to prevent rust?
2nd Jul 2017, 06:52 PM #57Most Valued Member
- 4,258
23rd Apr 2018, 08:26 PM #58Senior Member
- Aug 2005
- 185
I don’t visit very often, awesome job mate.
Great sense of pride comes from using it and going, yeh I made that....
steveSteve
http://www.mirwa.com.au
23rd Apr 2018, 08:55 PM #59
Hi Steve
Wonderful to hear from you.
I take it that you are a very busy luthier.
When you don't hear of someone in a long while you tend to worry!
Best regards
23rd Apr 2018, 10:46 PM #60Senior Member
- Aug 2005
- 185
Thanks Grahame, yes in the last 5 years I have never cleared my workload, so one gets caught up in that aspect of life.
The funny thing was, I started doing some rust repairs on my car again, been sitting there for 5 years now, I got my iPad out and started scrolling through some how to change quarter panels for my car to see if I needed to fit internal bracing and saw the metalwork forum and clicked, came up wth you have four notifications.
Some talented people running with that folder I designed is awesome to see
steveSteve
Lathe brake
By Stustoys in forum METALWORK GENERALReplies: 15Last Post: 29th Sep 2011, 09:23 PM -
Lathe Brake
By Stustoys in forum METALWORK GENERALReplies: 29Last Post: 10th Apr 2011, 08:17 PM -
Lathe brake
By Grahame Collins in forum METALWORK GENERALReplies: 14Last Post: 15th Jan 2011, 10:30 PM -
Brake for Cyclone
By m2c1Iw in forum METALWORK GENERALReplies: 3Last Post: 3rd May 2007, 10:01 PM -
Brake press
By gdk3000 in forum METALWORK GENERALReplies: 2Last Post: 1st Feb 2006, 08:58 AM
