Results 16 to 30 of 67
Thread: Simso's pan brake
28th Mar 2017, 02:50 PM #16Most Valued Member
- 4,258
I purchased a stack bright steel from Bolher in Melbourne for every thing except ends and feet.
1020 50.00 X 10.00 X 1,000 MM FL BRIGHT 4 KG $24.00
1020 75.00 X 10.00 X 1,000 MM FL BRIGHT 6 KG $33.00
1020 25.00 X 10.00 X 1,000 MM FL BRIGHT 2 KG $16.00
1020 100.00 X 10.00 X 1,000 MM FL BRIGHT 8 KG $44.00
Plus GST and Includes Delivery
plus the ends at $116 plus some odds n ends I had lying around here.
Black flat would be cheaper again of course.
30th Mar 2017, 11:04 AM #17Most Valued Member
- 4,258
MMM? wonder which came first ..the chicken or the egg?
Bramley Box and Pan Sheetmetal Folders
30th Mar 2017, 10:45 PM #18Senior Member
- Aug 2005
- 185
So happy someone saved all the dxf files, I lost them all on a computer crash 5 plus years ago, and then found all the original uploaded pictures and files were gone, awesome jobs folks.
The original purpose of this unit was really just to bend up small panels for doing car rust repairs.
1.6mm mild steel full length is a bit to much for this unit, smaller sections work okay, but it's all about the finger angle as others have mentioned, the steeper the angle the better it folds and grips, the lower the angle the more she will tend to slip.
You folks make my original design look great.
incredibly good work...
steveSteve
http://www.mirwa.com.au
31st Mar 2017, 12:03 AM #19Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
I think I might build one. Do I just have to give the school file to the Stella's place to be lazer cut?
31st Mar 2017, 07:56 AM #20Most Valued Member
- 4,258
31st Mar 2017, 08:04 AM #21Most Valued Member
- 4,258
Azzrock...a printed file is not the way to do it. They need a autocad file DXF? so they can just up load into their system and away they go. Else they will need to have someone draw in autocad or similar and then upload into the laser...all extra time and money.
Also try a getting a group together for laser cut...i reckon the more there are the cheaper it will be per each person?
I say this as 1 end was going to cost just over $100, but 2 only cost $116.
Do you need the autocad files? if so Pm me your email and I can send files. YOU will need autocad or similar or Autocad Reader to view.
31st Mar 2017, 10:58 AM #22Senior Member
- Aug 2005
- 185
Thank you for the offer of a copy of the files again, the fact someone has them is awesome, and they are willing to openly reshare them - thumbs up..
I have not seen the Bramley link, only perchance was I linked to this one.
The very first copy folder I saw ever made, was made by a gentleman by the name of Rod Mell over here in perth, I must say his attention to detail and craftmanship made me all warm that I had shared my design. You folks do a sensational job and have taken the quality of the product to a whole new level.
SteveSteve
31st Mar 2017, 11:00 AM #23Most Valued Member
- 4,258
31st Mar 2017, 11:15 AM #24Most Valued Member
- Oct 2010
- 1,910
31st Mar 2017, 11:22 AM #25Most Valued Member
- 4,258
Shallower or steeper angle?
A shallower angle as Bob indicates should allow more surface contact of the fingers, but more stress on the clamping leaf angle?, where as a steeper angle will give less stress on clamping leaf and less contact with fingers?..or am I missing something...anyway...what is best angle and why! etc.
31st Mar 2017, 12:50 PM #26Senior Member
- Aug 2005
- 185
31st Mar 2017, 12:56 PM #27Most Valued Member
- 4,258
my point is Steve...which came first?..... the chicken or the egg or put another way...who copied who's
Bramley is a new Zealand mob
Click this below
31st Mar 2017, 03:07 PM #28Senior Member
- Aug 2005
- 185
Well I can confidently say they have copied my design, why, because I made the design from scratch, I made it when I was in the military in sydney i joined in 1988, it was one of what we called at he time a "foreigner jobs"m that is I made it at.work during work time.....I altered it as I was making it, I used hacksaw blades and a milling machine I put it on this forum in 2007 as freeware because I posted a picture of something I had made in my shed, and a forum member asked where I got the pan brake from, explained I had made it and then decided to draw it in cad and give it free to people so they could make there own. I did a step by step tutorial in the drawing of each stage on the main woodworking forum.
Totally awesome someone made a commerical version, how much do they sell it for?
SteveSteve
31st Mar 2017, 03:14 PM #29Diamond Member
- Aug 2006
- 1,106
Thought it looked familiar when I was over at Machinery house last weekend. Wonder how much of it is actually the same.
31st Mar 2017, 03:21 PM #30Senior Member
- Aug 2005
- 185
The funny thing, I made the unit using scotch keys to hold the parts together, this to me as a layman was far easier to do than making a broached key, which if IMO I had ever thought of doing as a commerical build, I would have simply used a broach to do all the mechanical joins, but the bramley appears to use my scotch keys as well. Bwahaha, that was done purely because of my laziness...
Lathe brake
By Stustoys in forum METALWORK GENERALReplies: 15Last Post: 29th Sep 2011, 09:23 PM -
Lathe Brake
By Stustoys in forum METALWORK GENERALReplies: 29Last Post: 10th Apr 2011, 08:17 PM -
Lathe brake
By Grahame Collins in forum METALWORK GENERALReplies: 14Last Post: 15th Jan 2011, 10:30 PM -
Brake for Cyclone
By m2c1Iw in forum METALWORK GENERALReplies: 3Last Post: 3rd May 2007, 10:01 PM -
Brake press
By gdk3000 in forum METALWORK GENERALReplies: 2Last Post: 1st Feb 2006, 08:58 AM
