Results 1 to 8 of 8
    Apr 2009
    Kingswood
    930
    Default Sacrificial Milling Plate Material
    I intend milling with 4-5-6 mm end mills some 10 mm CI disks clamped directly on the table.
    What I need is a relatively thin (say 2 mm) sacrificial plate that will be partly machined by the tips of the end mills.
    As I believe the sacrificial plate should be softer than the work, I have aluminium, PVC and brass available.
    Looking for comments on the advantages and disadvantages of these materials, or suggestions for better alternatives.
    John.
    Oct 2015
    melbourne
    473
    If it were me, aluminium definitely. Brass = $, pvc may not compress equally and so allow the work piece to tilt.
    -russ
    6,475
    Hi John,
    I agree, aluminium is perfect. I made a false table from 12 mm plate to do just that. Easy to drill and tap holes exactly where needed. I originally used 3 mm alloy plate and the "T" slot bolts with clamps, but found that I couldn't always get clamps in the best place.
    Jan 2012
    Hinchinbrook
    112
    MDF or HDF
    jatt's Avatar
    jatt is offline Always within 10 paces from nearest stubby holder
    Bendigo
    51
    760
    MDF -- can't say I have tried that.
    Dunno if I would like to put it on mine with coolant and all. And wouldn't the "swarf" go to dust, come sludge??
    Frisky wife, happy life. ​Then I woke up. Oh well it was fun while it lasted.
    From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
    Apr 2009
    Kingswood
    930
    Thanks to all, aluminium it is, I have some 3 mm which will be perfect for this job.
    BaronJ,
    Yes, I think a thick plate like yours could be very useful.
    John.
    Mar 2014
    South of Adelaide
    1,227
    Quote Originally Posted by 12bolts View Post
    MDF or HDF
    Mdf is really good if you are machining dry. With coolant it turns into a soggy mess that is hard to clean up.
    Oct 2007
    Sydney
    3,112
    John I don't know why you feel it's necessary to have the sacrificial softer than the work, it really won't make any difference.
    What you use is largely a matter of what you have available and the tolerances you need. Wood is fine if the tolerances aren't tight. Aluminium/acrylic/steel/cast iron/etc if the tolerances are tighter. In the latter case it's easier to use a piece considerably larger than your work, fix it down to the table, and then give it a light skim with a fly cutter or large end mill. Thicker material will make that job much easier. Your sacrificial table is now as accurate as your machine can mill. Then clamp your work down to this new "table". A lot of people make fixture plates specifically for this purpose with tapped holes, especially for clamping down small work, I've heard them called "mini-pallets" so you can look that up if you like. A small pallet like that has been on my list of jobs to make for a while now, and of course the same principle can be taken as large or small as you like.
  1. Compact Workpiece Clamps for the face plate and angle plate.
    By metaler in forum METALWORK PROJECTS
    Last Post: 10th Oct 2016, 07:16 AM
  2. sacrificial plate on cross slide
    By steamingbill in forum THE HERCUS AREA
    Last Post: 30th Apr 2015, 09:27 AM
  3. Backing plate material
    Last Post: 11th Jan 2013, 10:01 AM
  4. material selection
    By mick A S in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 17th May 2011, 10:41 PM
  5. Material supplies
    By Dusty Wheels in forum METALWORK GENERAL
    Last Post: 16th Jun 2007, 06:00 PM
