Results 46 to 60 of 101
Thread: Hembrug lathe on the way.
13th Feb 2017, 02:28 PM #46Most Valued Member
- Australia east coast
- 2,713
13th Feb 2017, 03:34 PM #47Most Valued Member
- Jul 2016
- 35
- 1,522
Thanks PDW, that makes sense, also for anyone who was curious this is the tool turret in the top right Greg Q was talking about, quite ingenious. turret.pdf (its the drawing in the top right of that page.)
13th Feb 2017, 05:52 PM #48It's all part of the service here at The House of Pain™
13th Feb 2017, 05:54 PM #49
15th Feb 2017, 04:45 PM #50Most Valued Member
- Jul 2016
- 35
- 1,522
I started the cleanup last night, nothing drastically terrible found yet, other than as usual someone has used grease in all the oil nipples, Greg do you know if the spindle bearings in these were oil or grease lubricated, I would be almost positive they should be oil, they were also absolutely packed with grease no breathing room at all. Does anyone have a good method for breaking all the grease down and flushing it out of the narrow passages in all the castings?
*Edit* reading the manual, the bearings are meant to be greased but not with anywhere near as much as is in them.
Regards - Ralph
Some photos below, the reversable leadscrew is a great idea, although as a patternmaker the leadscrew and nuts have not been used much, they are full of crap though.
15th Feb 2017, 05:01 PM #51Philomath in training
- 6,563
I was advised to fill an oil gun with kerosene and just pump that through the oil system to flush out the grease.
15th Feb 2017, 10:52 PM #52Most Valued Member
- Oct 2007
- 3,112
I've got grease out of a few machines and it really gets in there. I doubt it would be flushed out with just a grease gun I'm afraid. Maybe enough to get it going, but in my experience the grease just basically sits there and will keep breaking down and glob on through. It makes a hell of a mess. I've found completely stripping it and power flushing all the galleries with kero and poking around with bits of wire etc was the only solution. Then wait until you see the crap that comes out!
16th Feb 2017, 06:38 AM #53Philomath in training
- 6,563
Yes, pumping kero through won't get all of it but when the alternative is to take the machine apart, some times it is a viable option.
16th Feb 2017, 09:59 AM #54Most Valued Member
- Oct 2007
- 3,112
Some of the hydraulic oils used are quite thin, and to be quite honest I can't see much difference between just squirting proper oil in vs contaminating the whole lot with kero. I don't know how much pressure those oil guns develop, but certainly nothing like what a grease gun can. Often the oil galleries are quite long/thin, and not meant to take grease. I've found the grease gets in there and begins to harden and it can be real tough to get out, even with the part in a parts washer working things like TIG wire through to help flush them out. I've had a couple harden completely and there's no way in heck any gun was going to budge the resulting log-jam.
Clearly what somebody chooses to do with their own machine is up to them, but FWIW I would not recommend relying on squirting some kero through and thinking the machine was then getting correct lubrication. In contrast I'd say you've now got an even bigger mess to contend with. It may be frustrating to have to strip the machine to clean the galleries out, but that's life. It MAY be possible to use a very strong solvent in an oil gun and try flushing with that, I don't know as I've never tried it. I doubt it, but can't say. I've personally only ever used kero and can pretty much guarantee it won't work as the person suggested.
16th Feb 2017, 10:13 AM #55Most Valued Member
- Jul 2016
- 35
- 1,522
I basically have the entire thing apart anyway, thankfully the headstock is all fine the gearboxes all have pressure oil lubrication I really only have to contend with the saddle at this point, Ill probably try cleaning the galleries with wire, then oil then kero, I will report back on the results, thanks for the help!
16th Feb 2017, 10:47 AM #56.
- 6,459
Ralph,
Just in case you haven't yet chanced upon this...
The Dutch seller Machinehandel A.G. Bos' website has featured numerous Hembrug lathes over the years and fortunately he has a Facebook page where images of those lathes ( amongst other delights ) still reside -https://www.facebook.com/machinehandelbos/
The photo below shows a lever operated tailstock from a garishly repainted AI DR1.
Bob
16th Feb 2017, 12:34 PM #57Most Valued Member
- Jul 2016
- 35
- 1,522
Thanks Bob, interestingly it looks like the tailstock is set up to take collets. I havent seen that before.
16th Feb 2017, 07:19 PM #58
You should check with Phil about getting some Kluber Isoflex...I seem to recall those AC bearings at the rear take around 5g of grease.
My machine was ex-telecom, ex-whatever they were called before that. All of the spares that came with it were labelled "artillery lathe", since AI stands for the Dutch phrase Artillery Industries.
Collets: the lever tailstock takes the same collets as the spindle: B26. Good luck finding any outside of Holland. I have most of a complete set in imperial sizes by 64ths. Pretty narrow clamping range. If I was going to ever get that serious again I would look at making a D-4 collet chuck using ER32s
All of this is making me miss metalworking machinery. I bought a geared head drill press last year-same as the Tai-Boga I restored 5 years ago. My new one has the table that NASA used to fake the moon landings. Big craters that you can see from space, which is what gave them the idea, I guess.
GQIt's all part of the service here at The House of Pain™
16th Feb 2017, 08:20 PM #59Golden Member
- Mar 2012
- Western NSW
- 543
Life can drag you off to other things sometimes but I hope its time to get back on the horse and get some oil/grease/dirt under those fingernails.
Mark
16th Feb 2017, 10:27 PM #60It's all part of the service here at The House of Pain™
AI Hembrug universal grinder
By WoodBee2 in forum METALWORK GENERALReplies: 29Last Post: 6th Mar 2018, 02:27 AM -
By Auskart in forum METALWORK - Machinery, Equipment, MARKETReplies: 9Last Post: 29th Jun 2010, 07:02 PM -
By Ch4iS in forum METALWORK GENERALReplies: 5Last Post: 25th Mar 2009, 12:19 PM -
Anyone here ever run a Hembrug lathe?
By Greg Q in forum METALWORK GENERALReplies: 10Last Post: 15th Feb 2009, 07:42 PM
