Results 31 to 45 of 101
Thread: Hembrug lathe on the way.
3rd Feb 2017, 03:02 PM #31
Hi Pete, how did you get around the voltage change on the Aciera motor, or are you running a 415 motor on 240? If so do you use the 29Hz trick?
3rd Feb 2017, 03:28 PM #32Most Valued Member
- Jul 2016
- 35
- 1,522
Okay synopsis is, single phase, single speed motor + vfd, no problems. Most of the motors I have lying around are out of woodworking equipment and are 2880, but ill look about for a 1440 motor. Thanks everyone for going over this topic again ill now move onto the other problems the machine no doubt will present.
Ralph
3rd Feb 2017, 03:32 PM #33Most Valued Member
- Australia east coast
- 2,713
3rd Feb 2017, 03:33 PM #34Most Valued Member
- Jul 2016
- 35
- 1,522
Sorry that was a slip, I only have 3 phase motors anyway.
3rd Feb 2017, 03:59 PM #35Most Valued Member
- Oct 2007
- 3,112
Good question Ray, this was a while ago now and I can't recall the specifics, but I must have found the star point. I always run the motors on their appropriate voltage in delta.
I do remember taking a motor to a rewinder and getting them to dig out the star point for me, and I have a sneaking suspicion it was this one. Normally I'm able to dig them out without too many problems, and have on every other motor, albeit sometimes not easily, but I do remember taking this one apart, digging around and thinking it was all getting ugly. The two speed motors are a lot "busier" in there than standard motors and while I'll have a go at most things, there's also a time to admit it's time to call in experts on some jobs. The more I think about it the more I think it must have been this motor as I remember them having a whinge about it when I picked it up.
It's not exactly free to have the above work done. But this is Sydney, and you can't get anyone to answer the phone for less than a hundred bucks! They had to dig pretty deep as I understand it, then re-bake the whole package, so it was probably a good call on my part to take it in.
3rd Feb 2017, 04:14 PM #36Most Valued Member
- Oct 2007
- 3,112
Yes other than that slip about it being single phase, that's correct. I'm not saying you can't run a two speed motor through one VFD, but I think you're opening a can of worms there that might be best left alone. As I mentioned, there's a heck of a lot going on with these motor drives besides being a single to 3 phase conversion, and at the end of the day that's the most minor of points, despite the fact it's why many of us first begin using them.
Here's a couple of photos I found of the control panel and the internals of that motor. Being a Swiss machine you can imagine the motor was typically over-built! There's two spindles on that machine, hence the "Main Spindle" and "High Speed" labels. The high speed is in fact a completely seperate motor attached to my high speed head. I have a lead with a plug on it and plug it in to the control panel when I have that head on the machine.
3rd Feb 2017, 04:25 PM #37Most Valued Member
- 2,713
12th Feb 2017, 02:37 PM #38Most Valued Member
- Jul 2016
- 35
- 1,522
I moved it in over the weekend, just have to find time to start cleaning it, see what needs work, the gibs still have some meat at least. I have all the original 'standard' accessories, changewheels, thread dial drive plate and face plate, travelling steady but no fixed steady, the QCTP is an interesting design too.20170211_133601[1].jpg20170211_133615[1].jpg20170211_133617[1].jpg20170211_133619[1].jpg20170211_133624[1].jpg
12th Feb 2017, 09:53 PM #39
I see that your lathe has the mechanism to allow belt pulley changes. Does your spindle only have one pulley?
I have a different rotary tool holder completely...one that rotates in the vertical plane.
GregIt's all part of the service here at The House of Pain™
13th Feb 2017, 08:34 AM #40Most Valued Member
- Jul 2016
- 35
- 1,522
I saw that vertical tiny turret toolpost in the manual, it looked quite interesting, ill post the ppage from the manual here. And mine has a matching pair of 4 speed pulleys.
13th Feb 2017, 10:58 AM #41
The vertical toolpost is very robust, but strikes me more like a mini turret type set-up. My lathe also came equipped with two tailstocks, although the lever action one looked unused.
Since the motronics drive that I had provided only one pulley I went down the servo route, but those parts are still on my shelf. (Its future home is only a month from lock-up, so it is coming north soon.)
13th Feb 2017, 12:16 PM #42
Welcome back. Good to hear that beautiful Hembrug that I keep eyeing off when I visit Phil's is scheduled for resurrection. With additional brain surgery no less. The electronic lead screw, servo driven spindle, you realise you are only a hop skip and jump away from full CNC?
13th Feb 2017, 12:33 PM #43
Hiya Ray...
I don't think I will do anything with the leadscrew now that I think about it. But the servo drive has to be done. Michael G got me some acme rod from McMasters a few years ago and I think ther's a big chunk of leadscrew rod in there if I recall correctly.
The CNC caper is something that I was teying to avoid, but it looks like I need to make a cnc foam cutter quickly, so maybe after all of the house stuff is done I will retrofit a milling machine. Of course I will have to make a cnc router first. Sigh.
The house is taking sooooooo long. We started construction almost a year behind schedule and have just slipped further and further behind from there. I haven't been to MEL in over a year now, so a visit is long overdue. I am looking at a supertanker in Singapore harbour as I write thinking that's about how much Black Label I owe Phil by now.
GQIt's all part of the service here at The House of Pain™
13th Feb 2017, 01:24 PM #44Philomath in training
- 6,563
PM me as I have literally kgs of NiChrome wire here (around 5.8ohm/m ) and I'll never use that much.
Same goes for anyone else who wants to make a hot wire cutter.
There was a thread about the sophisticated one I made here but all the pics have gone //metalworkforums.com/f65/t1514...-foam-castings. Without them it just reads like another precision project.
13th Feb 2017, 01:49 PM #45Most Valued Member
- Jul 2016
- 35
- 1,522
Greg if you had access to it I would really appreciate a few photos of the lever action tailstock, I would be very keen to replicate one. On another note it came with a qctp morse taper toolholder, what is the purpose of these, why would you want to hold anything with a mt shank off center? Is there some obvious use case im missing?
AI Hembrug universal grinder
By WoodBee2 in forum METALWORK GENERALReplies: 29Last Post: 6th Mar 2018, 02:27 AM -
By Auskart in forum METALWORK - Machinery, Equipment, MARKETReplies: 9Last Post: 29th Jun 2010, 07:02 PM -
By Ch4iS in forum METALWORK GENERALReplies: 5Last Post: 25th Mar 2009, 12:19 PM -
Anyone here ever run a Hembrug lathe?
By Greg Q in forum METALWORK GENERALReplies: 10Last Post: 15th Feb 2009, 07:42 PM
