Results 1 to 5 of 5
10th Jan 2017, 11:46 AM #1Golden Member
- Apr 2008
- Canberra
- 805
Box tubing clamp for holding table leg to table frame
Hi All,
I made a kids table and benches on the weekend which was good fun and a bit of proof of concept for the design that I will use to make a bigger version as an outdoor setting. I used a 90 degree corner clamp to keep the upper frame square, and then in a second operation I used the same clamp to clamp the legs to the finished upper frame and welded those on.
I was wondering if a clamp exists that would simultaneously allow me to clamp the table frame and legs so they would all be square to each other and could be welded in one go? The attached technical drawing might explain what I am trying to do better.
10th Jan 2017, 12:26 PM #2Member: Blue and white apron brigade
I've seen more specific versions but here's one that will work.
W1019 | UDL365 Corner Clamp | For Sale Sydney Brisbane Melbourne Perth | Buy Workshop Equipment & Machinery online at machineryhouse.com.au
11th Jan 2017, 09:49 AM #3Golden Member
- Apr 2008
- Canberra
- 805
Thanks Bob - your post also led me to this one:
Welders Angle Clamps 3 Axis - Products - Precision Specialty Tooling
I found a price for it on another website and it was like $400 or something...brutal. I think i'll go with your version!
Brendan
11th Jan 2017, 11:45 AM #4Senior Member
- Apr 2013
- Toowoomba Qld
- 401
Strong hand do a similar version to the bessey one with similar price or if you are after something a bit cheaper
V101 | AC-100TC 90 degree Angle Vice Clamp with Swivel Top Clamp | For Sale Sydney Brisbane Melbourne Perth | Buy Workshop Equipment & Machinery online at machineryhouse.com.au
11th Jan 2017, 12:05 PM #5Member: Blue and white apron brigade
It should not be that difficult to make a corner clamp like that especially if you could find a premade corner of a steel box that could be adapted.
FixturePoint Welding Table 900 x 600mm Table
By dradyz in forum METALWORK - Machinery, Equipment, MARKETReplies: 2Last Post: 26th May 2016, 01:38 PM -
rotary table
By tanii51 in forum METALWORK GENERALReplies: 24Last Post: 9th Jun 2014, 07:34 PM -
Oxy cutting table
By Aerohydro in forum METALWORK GENERALReplies: 2Last Post: 29th Aug 2010, 10:03 AM -
Which rotary table??
By xr6t in forum METALWORK GENERALReplies: 20Last Post: 5th Mar 2010, 09:22 AM
