Results 1 to 9 of 9
Thread: Precision level - or is it?
5th Dec 2016, 09:20 PM #1Philomath in training
I've just hit the buy button on one of these -
MACHINE/ENGINEERS AJUSTABLE OLD BUBBLE LEVEL | eBay
(Although not that one - the one I have coming is dirtier and rattier than that.)
However, looking at it, it should be screwed down to something and from the date and symbols on the end wonder whether it is something to do with artillery/ mortar for getting a mount or base to a known degree of level.
Anyone have any thoughts on whether that might be the case?
At 30" per division I calculate it out at 0.15mm/m. I plan to make up a base for it and use it for comparisons of angle that are too far out for my normal levels (it's around 6" long btw).
5th Dec 2016, 10:24 PM #2Golden Member
- Mar 2009
- 54
- 825
G'day Michael,
I think what you have is an old surveyors clinometer.
While clinometers were used on both artillery and machine guns, the absence of any markings like a pheon (/|\) makes me think it's probably not military.
I've got an old Vickers machine gun clinometer buried away somewhere, I'll try to dig it out and take some photos if you like.
Greg.
5th Dec 2016, 10:26 PM #3Intermediate Member
- Apr 2009
- Tas
- 66
- 30
AM 38 might be referring to Air Ministry approved supplier 1938. See this link Mechanism
Sorry can't help with actual use in aircraft / aircraft industry.Last edited by Driftabout; 5th Dec 2016 at 10:59 PM. Reason: added industry into scope of use
6th Dec 2016, 10:12 PM #4Senior Member
- Jan 2012
- Hinchinbrook
- 112
Definately not artillery! There is no way they would let a timber cased instrument loose in the hands of a mortarman. Apologies in advance to all the USMC here
Cheers Phil
7th Dec 2016, 07:02 AM #5Philomath in training
I think the timber box is a ring in - it does not look like it fits, lacks cradling and there are two countersunk screw holes on the base, so I think the idea was that it was (semi) permanently attached to something. It does not look the sort of thing that was kept as a 'stand alone' time.
Driftabout pointed out an ad for this maker that referred to military aircraft, so I wonder whether it was kit to help get gun sights aligned - lift the tail of your WWII fighter aircraft until a reference surface was to a predetermined spec and then adjust sights/ weapons to coincide at a particular distance. It's about the only thing that I can think of on an aircraft (of 1938/1944 vintage) that would need alignment to 30". You would need the adjustablity to cope with variations in mount or gun geometry/ manufacture and they would have been volume produced as every time a gun was replaced the sights would need to be set up.
7th Dec 2016, 07:51 AM #6Most Valued Member
Sounds like you are onto something
https://books.google.com.au/books?id...0level&f=false
8th Dec 2016, 05:54 PM #7Philomath in training
Stranger and stranger...
The level arrived today and what I thought was dirt is that waxy protective grease. Underneath the paintwork looks unmarked (corner scuffing is about it), such that I'm wondering whether it has ever been used.
This one has the war dept. arrow on it and a reference number (procurement contract?) of 1B/4235
8th Dec 2016, 09:00 PM #8Senior Member
- Feb 2012
- Willunga
- 114
Hi Michael
I have one that is much the same which is marked RAAF with a date in the early 50s, mine also looks more or less new. Did you by any chance get yours from a gent at Brighton? I got mine there and I think that he had more. I did some googling at the time and I think that the RAAF was using it to set the angles on ground to air beacons. I would call it a clinometer, strictly a inclinometer.
I have found it really good as a precision level and have been much happier about my lathe since I have had it.
Ian
9th Dec 2016, 06:43 AM #9Philomath in training
G'day Ian
This one came from c-tool over in NSW.
Precision level adjustment
By simonl in forum METALWORK GENERALReplies: 8Last Post: 3rd Sep 2014, 09:05 PM -
VICTORIA Starrett 199 Master Precision Level
By Greg Q in forum METALWORK - Machinery, Equipment, MARKETReplies: 2Last Post: 11th Sep 2013, 01:49 PM -
SOLD: Starrett 199 Master Precision Level in box
By Greg Q in forum METALWORK - Machinery, Equipment, MARKETReplies: 3Last Post: 9th Aug 2013, 10:56 PM -
SOLD: Precision level like Starrett 199
By Greg Q in forum METALWORK - Machinery, Equipment, MARKETReplies: 5Last Post: 20th Jun 2012, 08:54 PM -
precision level?
By fubar in forum METALWORK GENERALReplies: 29Last Post: 5th Aug 2011, 08:59 AM
