Results 1 to 14 of 14
3rd Nov 2016, 12:52 PM #1Intermediate Member
- May 2003
- 26
How would you make these table legs
Hi.
Is there an easy way to make these table legs.
I think this is my first post on the metalworking forum which probably indicates my skill level.
I guess its the taper which is the main issue - would have to be just right.
Also, what type of metal would they be ? brass ?
cheers
Arron
3rd Nov 2016, 01:36 PM #2Member: Blue and white apron brigade
- 7,183
Solid brass or steel would be too heavy
If you used solid Al the taper could be cut with a taper jig on WW table saw and an negative raked tooth blade
3rd Nov 2016, 01:45 PM #3Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,894
If the legs are hollow, they might be made from brass angle.
If the angles were machined to a taper, two halves could then be soldered together, forming the shape you want.
A mill and fly cutter could do the machining, with brass angle set up high at one end.
Alternatively they could be steel, copper or brass plated after brazing together
3rd Nov 2016, 02:16 PM #4Senior Member
- Jun 2012
- melbourne
- 341
I think I found the website that picture came from
Ginger Brown France,galuchat,shagreen furniture
All I could see was a close up of another style with similar legs, but it looks to me like its painted wood, not brass.
3rd Nov 2016, 03:19 PM #5Intermediate Member
- May 2003
- 26
3rd Nov 2016, 07:04 PM #6Most Valued Member
- 5,945
As it comes from a commercial supplier, I would say that they were either drawn or rolled . Forced/drawn into a tapered tube with a tapered mandrel, or rolled around a tapered mandrel then ERW welded, then brass plated.
Contact a metal spinner to see if they could do something similar.
3rd Nov 2016, 07:16 PM #7Senior Member
- Jun 2012
- melbourne
- 341
Don't pay any attention to me, I'm usually wrong! If you look at the ABOUT tab on the web site you can see a better resolution version of the legs. i thought it had very soft edges everywhere, and the finish looks like a sprayed "shabby chic" finish (well done mind you). Painted wood is cheaper which was my guess. However, shagreen is expensive anyway I imagine, plus the web site says they use cast brass, so that would be my second guess.
3rd Nov 2016, 10:01 PM #8
It is made from Cast Bronze and Shagreen (Stingray skin), I would hate to see the asking prices
Quote from the site and a link to the exact table which they call a console
"Designer and manufacturer of exclusives furniture and decorative accessories, our collection is handcrafted with the rarest and finest materials such as shagreen, sea shell, parchment,
cast bronze and more..."
Rick
4th Nov 2016, 08:12 AM #9Senior Member
- Jun 2012
- melbourne
- 341
You have to get a quote for the furniture, but here's one with an indicative price of US$12k. Maybe the legs are made of gold. Can't see why shagreen is so expensive. You can get a fish supper for $5, and I usually throw away the skin.
4th Nov 2016, 10:12 AM #10
A quick way would be to start with some RHS and plasma or waterjet cut the angles , tig weld and polish and plate to requirements ,
4th Nov 2016, 03:27 PM #11
If it was me, I'd start with square and draw out the round taper in the smithy. Although I think I'd want to be using a power hammer not doing it by hand.
Couldn't you turn a taper on square stock? I think you would want weight in the legs to offset the cabinet.…..Live a Quiet Life & Work with your Hands
4th Nov 2016, 04:54 PM #12Intermediate Member
- May 2003
- 26
Thanks for the response guys.
As I understand it the method proposed by Nadroj and Mike4 are fairly similar, except that one starts with angle and the other Rhs. Basically, both involve doing each leg by cutting two right angled tapered lengths then welding down the seams. There being two seams, each going the full length of the leg - is that right ?
Given you had some brass angle, would it be a big deal to taper the angle using a grinder and a file?
Could I use my cbn wheel to do the grinding ? I think it would chew the brass away all to quickly, but they are expensive things and I don't want to ruin it.
Then joining the two pieces together, what would be the most accessible way of doing it. Is it practical to solder something like this? MAP gas maybe ?
Googling tells me I can mig weld brass. Is that really practical in thi instance?
Arron
Oh, btw, anyone know where to buy some shagreen.
4th Nov 2016, 10:10 PM #13Mechanical Butcher
- Oct 2004
- 1,894
- Yes.
- I don't think it would be worth trying without a guided machine tool. With a milling machine it would be easy. You'd need to arrange for the brass angle to be supported with the open V upwards.
It might be enough to start with a longer length than needed, drill through each end for bolts to secure to slots in the table, then cut off the ends when finished. Hardwood packing pieces of varying thickness along the length would provide resistance to bending when machined.
4th Nov 2016, 10:50 PM #14Intermediate Member
- May 2003
- 26
Ok thanks
I did an answer to this but I think it got lost so here goes again.
I don't have access to a milling machine so need to think of other options.
I have a big boy sander, one of these L112 | L-80 Belt Sander | For Sale Sydney Brisbane Melbourne Perth | Buy Workshop Equipment & Machinery online at machineryhouse.com.au
Mine is the oscillating version.
Given a zirconia belt it should eat the brass in a few minutes.
I'm thinking I would make a jig from mdf, brass angle to be held in place with a few screws (fill the holes later). Have a little screw mechanism to advance the brass towards the belt at either end.
I do this already for timber. I don't see why it wouldn't work with brass, but never tried a long length. Am I missing something.
Arron
Looking for some steel table legs (available to ship or pickup in Sydney)
By bassmansimon in forum METALWORK GENERALReplies: 14Last Post: 12th Oct 2015, 12:57 PM -
Simple steel tube table legs.
By gatesy in forum METALWORK GENERALReplies: 9Last Post: 19th Aug 2015, 10:52 PM -
Needing some legs for a large timber desk
By Afro Boy in forum METALWORK GENERALReplies: 22Last Post: 18th Aug 2014, 06:50 PM -
Hinges for Folding Table Legs?
By rookie1 in forum METALWORK GENERALReplies: 5Last Post: 5th Jun 2012, 08:18 PM -
hairpin legs
By babi in forum METALWORK GENERALReplies: 3Last Post: 30th Aug 2010, 10:07 AM
