Results 1 to 8 of 8
28th Oct 2016, 12:59 PM #1Senior Member
- May 2015
- Richmond
- 214
C.C Model D Tool and Cutter Grinder
Rather than dig up an old thread, a question on this grinder to see if anyone has pics/details of table extensions to cover the slides from grit damage. There are tapped holes in the table ends but as yet haven't found any details of these items. The earlier model which was posted on the forum some time back had shorter cross slide table ways so didn't have this problem
Gradually getting the "scrap iron" back together!
28th Oct 2016, 09:29 PM #2Senior Member
- Brisbane Australia
- 122
Try here.
Woodwork Forums
You can see the plates to hold felts I presume,I have the same machine as your pics , it came with small plates and felts for the forward /backward ways but lacked the ones in the above attached pic , can send some pics of them tomorrow if you would like them.
Hope that helps.
Jim.
28th Oct 2016, 10:56 PM #3Senior Member
- May 2015
- Richmond
- 214
Thanks Jim. Maybe it never had anything on the ends other than the felt wipers. Even the pic I found with the swivelling table shows nothing. I'll pm my email address so you can send me some pics. The spindle also looks a bit short on my one if it were to be used for surface grinding.
1st Nov 2016, 01:05 PM #4Senior Member
- gold coast
- 303
Hi Rusty,
The previous owner to me had hand cut pieces of aluminium sheet to hold felt wipers in place . Not very eligant but I assume a facsumilie of the original.
I am in awe of your scraping and the finish of your tables. I was of two minds to even show you a pic of my restoration.
1st Nov 2016, 01:26 PM #5Senior Member
- May 2015
- Richmond
- 214
That tells me a bit more BrianGoldcoast! Any restoration is worth doing! I have the lower dovetail wiper parts but not the zero plate. I wondered what the tapped holes were beside the T-slot. I also don't have the tapped holes in the table for the swivelling table but now I can see what the length of a swivelling table should be.
Looking at your pics, I think my one is a slight different model D mark xxx as in the pic of the green one in previous post. The table stop rod on my one is on the back nearest to column (as I got it!!) and there is a stop pin screwed into the saddle. There is no bit of angle as some pics show just to the right of the traverse pinion shaft. The tapped holes for the swivelling table zero scale is on the RH end whereas yours is on the LH side
The table surface was in great shape so I thought I'd pretty it up a bit with the scraper. Had to make a new pinion shaft. That's back in now and time to look at the cross feed nut and screw. Only slight backlash in the thread so will split the nut so it can either be clamped or spread. Might go the spread path so I can use grub screws to do the job. Will post more pics as it progresses.
1st Nov 2016, 05:58 PM #6Senior Member
- gold coast
- 303
Hi Rusty,
There was a lot of 'blacksmith' type modifications on my machine and like you it took me a while to sort out how it worked.
I also needed a motor and drive belt as well as hours of rust removal and thick grime. I could not shift the cast iron base and welded up a stand from 50mm RHS.
Theres a thread back about 12 months in here of the progress and questions with a few pics. I had not even seen one before.
Currently I use it as a light surface grinder and while its ont a toolshop quality machine it does an adequate job for the small jobs and infrequent use I put it to.
If I can send you any pics that could be useful to you--just ask.
regards
Brian
16th Sep 2017, 05:22 PM #7Novice
- May 2012
- Hobart
- 18
table extensions
Are you still after photos of table extensions?
My newly acquired model D has a metal set.
Jon
16th Sep 2017, 10:56 PM #8Senior Member
- May 2015
- Richmond
- 214
CC. Tool and cutter grinder.
By stix012 in forum METALWORK GENERALReplies: 1Last Post: 11th Jan 2015, 10:13 PM -
DIY tool & cutter Grinder
By DSEL74 in forum METALWORK GENERALReplies: 0Last Post: 18th Dec 2014, 09:46 AM -
Another Tool And Cutter Grinder
By Anorak Bob in forum METALWORK GENERALReplies: 26Last Post: 13th Nov 2013, 12:15 PM -
Tool and Cutter grinder
By 4-6-4 in forum METALWORK GENERALReplies: 2Last Post: 12th Oct 2011, 11:40 PM
