Results 1 to 7 of 7
3rd Jul 2016, 11:08 PM #1Senior Member
- Victoria, Australia
- 114
Using a dial indicator to set an angle?
Using a dial indicator to set an angle.
If one is using a metric indicator with graduations of 0.01mm and therefore 100 graduations per circumference, which means each 1 graduation is approximately 0.278 degrees (100/360). So to set say a tool post at a 5 degree angle, the indicator would have to move about 18 increments or 18 X 0.01mm (0.18mm).
Is this the approach a machinists would use setting angle with an indicator or is the method wrong?
Hope the question makes sense.
Thanks,
Tom
3rd Jul 2016, 11:46 PM #2Senior Member
- Apr 2013
- Toowoomba Qld
- 401
I'm not quite sure I follow you there Tom
I think your missing a key element of your equation and that would be the length of the part you are measuring.
From what I can gather you are effectively measuring a triangle, the indicator would give you the short side length, the length measured along your reference rod would be another important length
I have never done it before so not sure
If you have a reference piece with the correct angle you could look at mounting it in the chuck and using it to set your angle, I have done this before to make MT3 chucks for the tail stock
4th Jul 2016, 12:31 AM #3
One would usually use a sine bar set to the correct angle and then indicated parallel with one of the machines axis.
4th Jul 2016, 03:07 AM #4Golden Member
- Nov 2010
- Gippsland Victoria
- 733
protractor
Hey Topari,
I'd do the calculation the other way around.
ie if 100 divisions = 360 degrees
now divide both sides by 100
1 division = 3.6 degrees .......... this means that your dial has rotated 3.6 degrees every time one of the dial marks passes the index mark and your cutting tool has moved 0.01mm either towards or away from the dial knob.
If you could post a sketch or photo of what you are doing and give an indication of what sort of accuracy is required then you may get responses more relevant to what you want to achieve.
Some basic reading on trigonometry might be helpful ie things like this
https://www.mathsisfun.com/algebra/trigonometry.html
On metal lathes there is often a 360 degree protractor engraved on the cross slide around base of the compound slide that would allow rough as guts setting of a 5 degree angle see attached photo.
Bill
4th Jul 2016, 10:10 AM #5Pink 10EE owner
- 6,218
4th Jul 2016, 11:04 AM #6Senior Member
- 114
Thanks for the replies. Opps yes 360/100. I will put sketch together. The general idea is to avoid trig and only use the indicator to set angles.
4th Jul 2016, 12:31 PM #7
Uh.. no, you seem to be suggesting using the dial itself as a protractor, that's not how to set up angles.... or how you use a dial gauge.. see the posts by RC and Ueee for how to use a sine bar.
You can also get digital angle gauges, but the sine bar method is more accurate.
Dial Indicator Question
By Chris Parks in forum METALWORK GENERALReplies: 19Last Post: 15th Jun 2013, 02:34 PM -
SOLD: Mercer Dial Indicator
By SurfinNev in forum METALWORK - Machinery, Equipment, MARKETReplies: 4Last Post: 4th Mar 2013, 09:48 AM -
dial indicator
By fittermachinist in forum METALWORK GENERALReplies: 30Last Post: 12th Aug 2012, 12:20 AM -
Dial Indicator
By Bidgee in forum METALWORK GENERALReplies: 6Last Post: 23rd Nov 2009, 12:10 PM -
Lever Dial Indicator
By Sterob in forum METALWORK GENERALReplies: 4Last Post: 6th Nov 2006, 02:08 PM
