Results 1 to 14 of 14
Thread: surface plate stand
11th May 2016, 05:30 PM #1Most Valued Member
- 4,258
surface plate stand
I am making a mobile surface plate stand. The plan is to balance the plate on three points as recommended.
My floor level is doubtful in some parts. I was going to just place the plate on a small piece of thick waffle pad on the stand? or is it more benificial to fit adjusting bolts so as to ensure the plate is sea level level or can it be at a slight incline....should the floor levels so dictate
11th May 2016, 06:25 PM #2Most Valued Member
I'd say 99.9% of the time it wont matter a stuff.
How big a plate are you talking about?
11th May 2016, 06:35 PM #3Most Valued Member
- 4,258
24x36
I am just about to get it of the box it came in when Greg did the group buy for us. (The box is open tho....its being aged)
I cant think of a reason why either Stuart....but thought i would ask the question...just in case
11th May 2016, 10:07 PM #4Most Valued Member
I think ultimately it's more important that the plate is supported in much the same way as when it was calibrated. Whether it sits on a slight incline is neither here nor there.
11th May 2016, 10:49 PM #5Most Valued Member
Well if its level and the top of something you place on top of it is also level then you know its parallel.
Now how often do you think you'll need to do that?? I'm sure there are other reasons.
My plate stand is pretty much a scaled down copy of Phil's. Sure I can set it better than 0.02mm/m, but I haven't checked it since the day I set it up.
I assume a mobile one would need to be much lower.
I'm confused by airys points and waffle board?
12th May 2016, 10:34 AM #6Most Valued Member
- 4,258
waffle pad
is it just me as I cant upload pics, or is it still down...but here is a link to a pic
Anti-Vibration Waffle Pads - WILREP LTD.
airys points???... three points of contact on top of the table for plate
13th May 2016, 01:47 PM #7Most Valued Member
Yeah... I think thats what they are called but Mr Airy worked out where to support a beam, and that seems to be around the same numbers used in the 3 point mount.
Not sure where you plan to put the waffle pad but if you use it I wouldn't worry about trying to level the plate. But as always it depends on just how "close" you are trying to get and how often.
13th May 2016, 09:31 PM #8Most Valued Member
- 4,258
13th May 2016, 10:05 PM #9Philomath in training
Use some firm rubber (conveyor belt for example)
Airy points are the points that have been worked out as causing the least sag due to gravity when a beam/ slab is supported on 3 points.
14th May 2016, 12:29 AM #10Banned
- Jul 2011
- Melbourne Australia
- 1,376
To be fair the 3 points under a plate aren't Airy's work. He was big on straightness of a beam and parallel ends. He dealt with single axis beams.
Pretty sure it was Friedrich Bessel that finished up with the Bessel zero sag theory. Hence forth they are Bessel points under a surface plate. Not Airy point's.
Regards Phil
19th May 2016, 09:20 AM #11Most Valued Member
- 4,258
Ah Ah now I know what they are on about.... I was thinking you all couldnt understand me and was calling my comments as a lot of hot air...or something
The stand is mostly completed ...see attached pic...I tried but no go
Just need to make some draws, a shelf, paint and put the plate on
19th May 2016, 07:26 PM #12Pink 10EE owner
- 6,218
I would not bother with leveling pads for something designed to be mobile. When I built the stand for one of my surface plates I made it so I could move it around with the pallet jack. You will need some sturdy castors under it to handle the weight. Maybe some brakes as well if it takes off on you
19th May 2016, 08:04 PM #13Most Valued Member
- 4,258
25th May 2016, 09:19 AM #14Most Valued Member
- 4,258
all done...plate is on top nowstand.jpg...
now to get some slides and fit some draws under so that I can put some goodies in there
didnt take long as long to get that out of its crate as it did the first lathe...lol
SOLD: Granite surface plate on welded stand with levelling mounts.
By Greg Q in forum METALWORK - Machinery, Equipment, MARKETReplies: 4Last Post: 28th Aug 2013, 10:43 PM -
Calibrating a Surface Plate
By RayG in forum METALWORK GENERALReplies: 52Last Post: 15th Apr 2013, 11:34 AM -
Surface Plate Substitutes
By Oldneweng in forum METALWORK GENERALReplies: 41Last Post: 28th May 2012, 08:41 PM -
Granite Plate Stand
By Stustoys in forum METALWORK GENERALReplies: 63Last Post: 30th Mar 2012, 03:59 PM -
what do you think of my surface plate
By welder in forum METALWORK GENERALReplies: 11Last Post: 21st Nov 2011, 05:33 PM
