Results 1 to 6 of 6
29th Apr 2016, 11:19 PM #1New Member
- Jun 2009
- West Aust
- 5
Imperial and Metric Bolt Thread and Torque Chart
Hi all
This is a printable double sided Bolt Drill Thread Chart for the workshop. Laminate it.
The torques are based on standard bolt tensions for reusing bolts.
Important for the THREAD PITCH INDICATOR on the side.
If you print the chart measure the 1mm thread form with an accurate rule to make sure the printer is not distorting the thread pitch forms.
Use the peak of the bolt to the peak of the thread forms to identify bolt threads pitch. (It is not a thread gauge so don't try to use like a thread gauge)
TAPPING DRILL & Torque Con Chart.pdf
Regards moorebrm
30th Apr 2016, 10:15 AM #2
Hi Barry,
Welcome to the The Metalwork Forums
and thank you for posting the chart. I am sure many will take advantage of it.
Don't be shy tell us about your metalwork interests are and how you would like to interact with us.
here's the spot to do it - //metalworkforums.com/f300
GrahameLast edited by Grahame Collins; 30th Apr 2016 at 10:44 AM. Reason: more info
30th Apr 2016, 12:21 PM #3Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
The 250mm scale is more like 249mm from my printer.
Close enough!
Thanks,
Jordan
30th Apr 2016, 05:38 PM #4New Member
- Jun 2009
- West Aust
- 5
Jordan
The most important measurement is the "1mm" thread form that you should measure with an accurate rule to make sure the printer is not distorting the width of the page and thus all the the thread pitch forms. The 150 mm arrow at the bottom of the page doesn't work as good as lining up the 1mm thread with a rule.
The thread pitch forms are a quick(el cheapo) and thread gauge. if you find your printer is slightly out then correct it as close as possible by scaling the print 99% or 101%.
The ruler does not have to be super accurate as bolts come in 1/4" or 5mm length increments.
Also
There is a one in ten 1:10 diagonal line superimposed over the threads - put a ruler on the diagonal line and slide your bolt down it until it touches the 250mm ruler line this gives you the diameter of a bolt or drill x 10 - a 5mm drill should line up with the 50mm on the 250mm line.
Hope its useful to you
regards moorebrm
30th Apr 2016, 07:53 PM #5
I have a Samsung monochrome Laser printer, width wise, with default margins, the dimensions are just about spot on. However the print is compressed in length a percent or two. I accidentally discovered that not having top and bottom margins allowed the print to be the correct size. I have since found that changing the margins alters the algorithm for "Fit to page", where the printer recalculates the page size to suit the margins that you specify.
Hope this helps when printing things that have to be accurately sized.Best Regards:
31st May 2016, 01:48 AM #6New Member
- Jun 2009
- West Aust
- 5
Inch to Decimal conversion chart
I have added this Inch to Decimal conversion chart for accurate conversions up to 20 inches
Regards moorebrm
metric thread cutting on old imperial (new visby) lathe??
By gpigeon in forum METALWORK GENERALReplies: 17Last Post: 12th Aug 2014, 03:13 PM -
Metric thread on imperial lathe, without reverse.
By Vernonv in forum METALWORK GENERALReplies: 65Last Post: 7th Nov 2013, 09:32 AM -
Hafco Imperial and Metric Drill, bolt, tap gauges
By Jim Ferrous in forum METALWORK GENERALReplies: 10Last Post: 3rd Oct 2013, 11:12 AM -
260 metric to imperial chart
By tanii51 in forum THE HERCUS AREAReplies: 3Last Post: 2nd Jun 2010, 02:50 PM -
Metric Thread Cutting on Model 9A with Imperial Lead Screw
By Rodd Perrin in forum THE HERCUS AREAReplies: 3Last Post: 21st Sep 2009, 02:14 PM
