Results 1 to 4 of 4
19th Apr 2016, 12:14 AM #1New Member
- Melb
- 1
Need someone to bend Flat Steel Bar in Melbourne
Hello Guys,
I need help in finding someone who can bend some flat steel bar, for legs for a coffee table and a side table that I'm making.
To give you an idea, I need to get the bar bent, similar to what is shown in the attached photo here:
http://www.plumedesign.com.au/shop/images/lillia%20round%20dia%201000%20$559.jpg
The material is 40x10 Flat steel bar, and the attachment below shows what I need to get bent, ie 2 pieces of item "A", and 2 pieces of item "B".
Ideally if you know anyone in Melbourne's Northern suburbs, please provide their details here, or PM me?
Thanks again in advance!
19th Apr 2016, 03:28 PM #2Most Valued Member
Hi there,
If you don't get any offers, have you considered welding four pieces together and then grind/linish the edges to a round finish?
I have done this in the past with many projects and with a little time and care you can achieve a finish that looks like one piece of material.
19th Apr 2016, 09:42 PM #3
Used to have similar things done in stainless and mild bar in the past. With 100x10 stainless bar the tightest bend we could get was around 55mm inside radius with an 80 ton pressbrake and special tooling. Mild is slightly easier to work with and has more predictable springback tendencies than SS, which will be to your benefit.
The issue with tight radius (relative to material thickness) bends is that the force needed to achieve the bend increases virtually exponentially as the bend radius decreases, so for a given amount of force, there is a lower limit to the bend radius.
Another issue that you will probably face is one of tooling and setting the machine. We had to shell out for custom tooling to do our jobs, and although the people we contracted to do the bending made up the male tooling, it was not cheap to produce ( think $2k ten years ago) and the female V was a stock item also around $1K back then. We were doing a run of 100 legs and the tooling costs were incorporated into the pricing of the job, but for a custom 1off job, they would be prohibitive. You would also get charged to setup the machine for your job, then reset back to normal config for the job the machine is used for, unless you find someone with the tooling on hand who is regularly swapping tooling and jobs on the machine, in which case you might only get stung a single setup fee.
A final issue is damage to the material during bending. the bar actually has to self feed (slide) into the V bed as it is being formed so tends to scrape as it does so. Once the bend is achieved, there is likely to considerable distortion in the material where it has been in contact with the lip of the V, and this needs to ground and polished out taking a fair amount of time if you need to match an existing finish.
All in all, for the tight radiuses you are wanting, I think I would be talking to a good fabricator about having them cut and welded, MIG outside and edges and TIG with minimal filler rod for the seam inside the corner. The MIG could be ground back flush to the surface and the TIG should fill the seam without needing grinding. Also much easier to get sizing exact this way without needing to do test bends to calculate gain through the bend which is a whole other issue.
Remember to do any required surface prep, drilling, countersinking etc before bending or welding, it is much quicker and easier that way.
My 1c worth.I used to be an engineer, I'm not an engineer any more, but on the really good days I can remember when I was.
20th Apr 2016, 10:39 PM #4Golden Member
- Mar 2009
- 54
- 825
A job like that shouldn't be a problem for a Bramley bender or you could always heat it with an oxy. I'm working interstate for the next couple of weeks but if you don't get any other offers and aren't in a hurry I might be able to help you out when I get back. I'm in Fawkner.
Greg.
Sourcing Bright Flat Steel Bar
By ericg in forum METALWORK GENERALReplies: 7Last Post: 26th Sep 2014, 08:11 AM -
Supplier of high speed steel and tool steel bar and spring steel in melbourne?
By fudo133 in forum METALWORK GENERALReplies: 3Last Post: 25th Jun 2014, 12:44 PM -
How to bend 10mm or 12mm steel tube
By jabell in forum TRAILERS & OTHER FABRICATED STUFFReplies: 8Last Post: 2nd Nov 2012, 04:35 PM -
Decorative steel - flat bar supplier
By Marc in forum METALWORK GENERALReplies: 3Last Post: 19th Aug 2012, 09:09 PM -
Best way to bend steel Mesh
By BobL in forum METALWORK GENERALReplies: 23Last Post: 11th Mar 2012, 05:15 PM
