Results 1 to 12 of 12
Thread: buying fasteners in Adelaide
13th Apr 2016, 04:28 PM #1Golden Member
- Vic
- 48
- 544
A mate of mine in Adelaide is looking for a few m6 studs around 140mm long (for motorcycle cylinder). Does anyone know any where in SA that he could get them from?
Thanks heaps
Jackaroo
13th Apr 2016, 05:28 PM #2China
- Dec 2005
- South Australia
- 1,657
13th Apr 2016, 07:41 PM #3Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
Most studs are custom made for the application so will be hard to find. If you can get away with threaded rod most of the places below should stock m6 hi tensile threaded rod, beware the minimum purchase is $10-15.
Fastners australia- Mile end
Konnect fastners- lonsdale and regency park
13th Apr 2016, 08:05 PM #4Most Valued Member
- Jun 2012
- SA
- 1,649
13th Apr 2016, 08:47 PM #5Philomath in training
Universal fasteners have changed their name to Konnect and moved to Wingfield. They now have a $25 minimum order.
Another option is United fasteners on Cavan road. Popular because they do not have a minimum order value.
14th Apr 2016, 12:24 AM #6China
- Dec 2005
- South Australia
- 1,657
If you use Konnect make sure you take a card of some form they no longer accept cash
14th Apr 2016, 12:29 AM #7Golden Member
- Vic
- 48
- 544
Thanks everyone, much appreciated for that. I'll pass the info on to him.
14th Apr 2016, 10:32 AM #8Most Valued Member
- Jun 2012
- SA
- 1,649
The worst that can happen is you will fail.
But at least you tried.
14th Apr 2016, 10:45 AM #9Senior Member
- Dec 2010
- Syd
- 492
What sort of bike? They sound like the length required for cylinder head retention - and struggle to imagine anything other. Even on a 50cc, smallest I've seen used is 8mm..usually something can be made to work from another oem in that case.
If it is a head, thread in a joint that sees cyclic loading, probably not something to recommend, if it sees much use.
14th Apr 2016, 11:36 AM #10Golden Member
- Vic
- 48
- 544
Hi Hunch,
Yes its the cylinder head bolt! 125cc, 1952 Lambretta. The later models are using m7 and m8. One of them on his is broken but I guess he wanted to keep it period.
Regards,
Trong
15th Apr 2016, 07:27 AM #11Senior Member
- Dec 2010
- Syd
- 492
Interesting, must be fairly low comp - probably fuel related post war. Would have thought with 3 Italian scooter booms over the decades I can think of, plus likely thousands, if not tens of thousands sold, must be a supply out there somewhere. I might even go bolt and timesert the cases if desperate and nothing available.
15th Apr 2016, 09:53 AM #12Golden Member
- Vic
- 48
- 544
The compression ratio is 6.5:1 for it Hunch (2 stroke). He found a place in UK who could supply them so that is a relief if he has to get them in.
H&F in Adelaide.
By wm460 in forum METALWORK GENERALReplies: 3Last Post: 21st Feb 2015, 04:33 PM -
Coke in Adelaide
By tongleh in forum THE SMITHYReplies: 6Last Post: 16th Feb 2013, 04:35 PM -
Sheet supplies in Adelaide
By Gavin Newman in forum TRAILERS & OTHER FABRICATED STUFFReplies: 4Last Post: 11th Jan 2011, 10:41 PM -
assorted fasteners
By snowyskiesau in forum METALWORK GENERALReplies: 10Last Post: 16th Jun 2009, 02:31 PM -
Look what followed me home from Adelaide
By Big Shed in forum METALWORK GENERALReplies: 19Last Post: 14th Feb 2009, 06:32 PM
