Results 1 to 9 of 9
Thread: Hacksaw push or pull
8th Apr 2016, 10:44 AM #1
I was having a three way conversation yesterday with two older trades men and the topic of hacksaw blade direction came up and the opinion of the two guys was opposing.
Is a hacksaw generally set up as a push or pull saw? Teeth forward or back?
Found this in Wikipedia
On hacksaws, as with most frame saws, the blade can be mounted with the teeth facing toward or away from the handle, resulting in cutting action on either the push or pull stroke. In normal use, cutting vertically downwards with work held in a bench vice, hacksaw blades should be set to be facing forwards. Some frame saws, including Fret Saws and Piercing Saws, have their blades set to be facing the handle because they are used to cut by being pulled down against a horizontal surface.
I know some of you have old school trade background and training others have read some really old texts. What are you opinions and how do you use it?…..Live a Quiet Life & Work with your Hands
8th Apr 2016, 11:59 AM #2
Handsaw - always had it cutting on the fore-stroke, never seen one cutting on the back-stroke.
My 1940's Hercus power hacksaw also cuts on the out stroke.
8th Apr 2016, 12:01 PM #3Banned
- Feb 2015
- Oz
- 73
- 459
I must admit I have never given it any thought, always set the teeth forward. I might have to give teeth facing backward a go and see how it works. Of course using a hacksaw is not my favourite pastime, in fact I hate hacksaws so much I bought a Milwaukee hackzall - marvelous tool.
8th Apr 2016, 12:09 PM #4
To add another take on this, its possible to put the blade in what I would call the conventional way (teeth forward) but to still use it as a pull saw, as in using your front hand that is holding and supporting the saw frame, to pull the saw through the job, or at least to help the saw through the job by pulling to some extent, and helping to ensure the blade is cutting in tension rather than compression.
It's Ripping Time!!!
8th Apr 2016, 04:04 PM #5Most Valued Member
- 5,945
I've always been taught/told, that hand hacksaws, cut on the push stroke, 60 strokes per minute?
Power hacksaw, cut on the pull stroke, good quality ones, have a lifting arrangement to lift the frame on the push stroke, which is why the solid vise is mounted where it is.
8th Apr 2016, 07:24 PM #6
8th Apr 2016, 09:19 PM #7Member: Blue and white apron brigade
- 7,183
In all cases the cut has to be performed in the direction of the teeth - there's no question about this.
The question then is this best done on a push or pull stroke and this depends on whether the blade is tensioned or not.
Lifting the blade to clear the work aside, a tensioned blade doesn't care whether it cuts on the pull or the push as the blade won't flex much in either direction.
For a blade not under tension the cut stroke is best performed as a pull.
A excellent demonstration of this is Japanese woodwork saw which are extremely thin.
Western wood saws have to either be stiffened by backing like tenon saws or made much thicker so they won't flex on the push.
Another good example are those one ended hacksaw blade holders that just hold the blade at one end. Try using those in push mode and you end up with a bent blade but they work fine in pull mode. I din't know how many blades I bent before I realised they work better as a pull saw.
After that it comes down to operator ergonomics.
I reckon its easier to push a conventional (tensioned) hacksaw as using two hands you can generally push harder and smoother than you can pull.
Same with filing.
16th Apr 2016, 12:43 PM #8Intermediate Member
- May 2013
- Toogoolawah, Queensland
- 66
- 44
I can remember as an apprentice Sparky back in the early 1970's being on a job where we needed to cut into a lot of existing Electrical Conduit to install new junction boxes and additional conduit branches and cables. All of the conduit was nailed to the over-head timbers, so we were standing on step ladders and sawing with our arms stretched over our heads. After a few hours of difficulty doing this overhead sawing, the supervisor on the job suggested that we reverse the hack saw blades in the frames so that the teeth were facing towards the handle and use it as a pull saw. It made working overhead much easier, and quicker.
RoyGManufacturer of the Finest Quality Swarf.
16th Apr 2016, 12:48 PM #9Banned
- Feb 2015
- Oz
- 73
- 459
Well I can tell you for sure that cutting on the pull stroke is the way to go when cutting lamb shanks - yummmmmmm. Did that last night, tonight I'll be munching on them!
Push or pull on ally using MIG?
By constablechris in forum WELDINGReplies: 5Last Post: 2nd Jan 2012, 10:17 PM -
Difference in Push/Pull with MIG
By DirtPig in forum WELDINGReplies: 4Last Post: 28th Sep 2011, 09:09 PM -
Wire in a push pull gun...
By constablechris in forum METALWORK GENERALReplies: 17Last Post: 24th Sep 2011, 11:18 AM -
MIG welding technique - push or pull
By pheonix122973 in forum WELDINGReplies: 13Last Post: 22nd Jan 2009, 10:50 PM
