Results 1 to 3 of 3
26th Feb 2016, 09:54 PM #1Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 838
Tailstock Barrel Key - Colchester Master
The barrel key on my lathe tailstock was pretty worn and beat up allowing quite a bit of slop in the keyway, which does not really effect anything but, has always annoyed, me so I made a new one, or two, actually. This is a really simple part but requires quite a few different processes in it's manufacture.
The first step was to turn and mill them slightly oversize to allow for final grinding to size after hardening. Material is EN36A,30mm Diameter.
In the furnace at hardening temperature after previous pack carburising. I forgot to photograph the carburising process.
Quenching in Heat Transfer Oil.
Hardness Testing - Result 60 Hrc.
Ready for grinding to final size.
Grinding the O/D on a purpose built fixture after grinding the top and bottom surfaces.
Grinding the actual key flanks to size.
The finished products and fixture.
27th Feb 2016, 08:33 AM #2Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
That's neat.
Was the original key hardened?
What grit is the grinding wheel you used? I'm curious as I want to buy the right one for my recently acquired surface grinder.
27th Feb 2016, 08:50 PM #3Golden Member
- Sep 2008
- 838
WTB A Steady Rest and a Travel rest for my Colchester Master 2500
By colnjulia in forum METALWORK GENERALReplies: 0Last Post: 15th Mar 2015, 01:54 PM -
9" tailstock barrel
By Tonyau in forum THE HERCUS AREAReplies: 1Last Post: 9th Jan 2013, 12:13 PM -
Barrel Vice
By barkersegg in forum GUNSMITHINGReplies: 9Last Post: 31st Oct 2012, 04:52 PM -
Colchester
By footz in forum METALWORK GENERALReplies: 18Last Post: 1st Oct 2008, 10:42 PM
