Results 16 to 30 of 118
6th Feb 2016, 10:03 PM #16
A real good point on the wire wheels guys. I had forgotten about them.
A couple of points which have just come back,
Check the rpm ratings on wire brushes are suitable to the A /grinder.
An under rated wheel can spit wires as the machine RPM is too great for its rated RPM.
The other thing was the shape or twist in the wires.Some brushes are made as straight wire and the better ones have a twist.The straight wire brushes used to splay out horizontally as the top rpms were achieved and frequently let wires go.
The other one was the quality of the brush.An angle grinder wire brush is not a thing to cheap out on buying. Josco was a good brand as were Makita and Bosch and a few others.
PDW's comment on wires impaling you took me back quite a few years when I had to go the hospital after hours to get wires embedded in my arm removed.The odd thing was they went in, end on, and parallel to the skin.I was at home a few hours before I noticed the pain and felt the lumps.
Full face grinders were mentioned too. Hands up!. Who has a full face visor at home for use with their angle grinder?
Worse still who hasn't?
6th Feb 2016, 10:34 PM #17Member: Blue and white apron brigade
2 in my shed.
1 in my Van along with the other chainsaw PPE
1 at the mens shed.
While not life threatening the other health related thing about grinders is the noise so for every visor there is an accompanying set of earmuffs
6th Feb 2016, 11:51 PM #18
Just make sure the welding jacket goes nowhere near the wire wheel. It's hard (impossible?) to find jackets to fit me at 65 kg so they always end up loose and baggy. One moment of inattention some years ago and the grinder and wire wheel ended up chewing it's way through the leather jacket and only stopped when the jacket stalled the 4" grinder. Had it been the 9" I don't like to think what would have happened.
7th Feb 2016, 01:31 PM #19Most Valued Member
- Australia east coast
- 2,713
Yeah, I have 3 of them, one on the bench next to the vise where I do the vast majority of my grinding/cutting. Also ear muffs & riggers gloves.
I'm too lazy to change over cutting disks, wire wheels etc so I have quite a few 5" grinders. Only 1 9" grinder though, and 99% of the time it stays in the cupboard.
PDW
7th Feb 2016, 08:52 PM #20
7th Feb 2016, 10:15 PM #21Golden Member
- Jun 2005
- Helensburgh
- 618
I never use safety glasses as I reckon the rest of my face deserves the same safety precautions as my eyes do. I guess I have been using full face protection for about as long as it has been available because I used to wear glasses and it just made sense. When I did a lot of OA welding I also used a full face due my glasses fogging up with goggles and the odd tip backfire never worried me.
CHRIS
8th Feb 2016, 07:57 AM #22Senior Member
- Nov 2012
- Blue Mtns
- 115
You have to wonder looking at that list. You can't buy an electrical item or a plumbing item without them ramming into you to use a licensed tradesman. But tools like angle grinders and chainsaws are available to all
8th Feb 2016, 07:59 AM #23Senior Member
- Nov 2012
- Blue Mtns
- 115
Good reminder on the full face protection. What do most get? Can you still get those ones combined with muffs?
8th Feb 2016, 10:19 AM #24
Full face visors can be fitted to some bump caps along with hearing protection.
PPE is ok as long as you remember it is a last resort.
Another thing to take in board is the amount of wriggle room that you have when using the tools , sometimes safety glasses are all that you can have on as the visor gets caught on the material above your head.
Good discussion to have occasionally just to remind all of us of the risks involved with what we choose to do .
PS, how many people do you see using a weed eater in bare feet , no eye protection and a t shirt???
8th Feb 2016, 10:22 AM #25Member: Blue and white apron brigade
I use the Armadillo brand with the 3D curvature under the chin as 3D curved surface is stronger than a simple 2D curve.
I use Peltor Muffs with the behind the neck band as this clips over the adjustment knob for the Armadillo headband and the two hold each other on in a very positive manner.
The standard 60+ page Stihl operators manual has the first 26 pages related to safety.
Compare this to the Ryobi petrol chainsaw which has an 18 page manual with about 12 pages on safety, while its electric chainsaw has similar pages numbers but the diagrams are separated from the text at the end of the manual
For its bigger saws the Stihl manuals states clearly on the front page.
]This saw is capabale of severe kickbackwhich may cause serious or fatal injury.
Only for users with extraordinary cutting needs andexperience and training dealing with kickback.
Chainsaws with significantly reduced kickbackpotential are available.
STIHL recommendsthe use of STIHL reduced kickback bar and low kickback chain.
Chainsaw injuries and deaths to professional workers have dropped very significantly with the increased use of Chainsaw chaps and hardhats, and improved training since the 1990's, but I know of very few DIY who use this level of PPE. Normally I'm a stickler for chainsaw PPE use but the one time in the last few years I did not wear PPE to cut down a 4" diameter Paperbark tree from my mum the chain came off the 25" bar and whipped around and dealt me an eye watering blow between the legs. Luckily the chain was not actually rotating at the time.
A body map of chainsaw injuries shows that one of the most common chainsaw injuries (~30% where standard chainsaw PPE also doesn't help much) is where an operator believes they can hold a piece of wood with one hand and use the chainsaw with the other. What invariable happens is the chainsaw cannot be held firmly enough so the chain skates across the surface of the wood and into the operators hand. Similar injuries happen with grinders. Even though they can be easily defeated it's almost like all the handles need deadman switches on them. I'd like to see deadman switches on both handles of routers as well.
8th Feb 2016, 10:49 AM #26Most Valued Member
- 2,713
Waste of time, humans are far too creative - I use router bits in a die grinder for freehand wood butchery. Works great.....
...... but I wouldn't actually recommend it to anyone if they are currently attached to all their digits.
Agree about chain saws. As I've gotten older, the size chainsaw I'm comfortable using has dropped. I even have one of those twee 14" electric ones nowadays and it gets a lot more use than my Stihl does.
PDW
8th Feb 2016, 12:28 PM #27Member: Blue and white apron brigade
8th Feb 2016, 02:18 PM #28
achjimmy,
The nub of the problem is that some new A/G operators will not read instructions,do not not seek advice other than from similar idiots on Utube and then wonder why they get hurt.
Ego and pride and are certainly part of the problem.
You hear and see the "git it done" mentality from some on the oversees forums and with it seems to come a willingness by those individuals to use unsafe practices and expose themselves to harm not only in what we are speaking now ,but in quite wide range of activities (metal working and other wise- where safety procedures are short -cutted in favour of getting the job done quicker and cheaper- quite often these people are owner operators so I understand why, but will never agree with them.
My guess is is that we never change those types ,but hopefully if beginners can read advice on best practice safety matters here, they may well avoid the bad habits promoted elsewhere.
Even if we change one persons mind on machine safety its well worth the effort,though we might never know it.
8th Feb 2016, 10:24 PM #29Diamond Member
- Aug 2006
- 1,106
9th Feb 2016, 12:27 AM #30Banned
- Aug 2015
- QLD
- 735
No regulating them chainsaws. I own a chainsaw and I VOTE !
...actually, I got three of them. Big one for ripping them posts, mid size one fer dropping them gums, and a little one to carry on the quad bike.
Game changer - very interesting ABC news article
By nearnexus in forum METALWORK GENERALReplies: 4Last Post: 3rd Sep 2013, 06:35 PM -
Eveleigh news article + video
By AndrewOC in forum THE SMITHYReplies: 2Last Post: 25th Jul 2013, 06:01 PM -
Versatile Tool and Cutter Grinder "made in Melbourne"
By Garry Edwards in forum METALWORK GENERALReplies: 7Last Post: 22nd Feb 2012, 09:50 PM -
Opposing toothed "Clutch-Plate" Nuts? (a bit like "Castle" Nuts...)
By Batpig in forum METALWORK GENERALReplies: 6Last Post: 5th May 2009, 08:18 PM -
Difference "Galvanised" and "Primed" Steel
By Fr_303 in forum METALWORK GENERALReplies: 4Last Post: 22nd Jan 2008, 05:59 PM
