Results 16 to 30 of 38
Thread: Lathe manual
  1. #16
    Jun 2007
    sydney ( st marys )
    64
    4,890
    I see in some of the manuals covering this style of lathe they mention using a power twist belt rather than taking the Headstock apart.
    If possible put the details and size of the gears as previously asked for , some one here might even knock them up for you as love job.
  2. #17
    May 2012
    Lismore
    28
    Hi Phaser, your Hafco is very similar to my Lantaine with some small differences. I replaced my belt by removing the back gearset and the rear headstock bearing. I was able to squeeze the belt in through the rear headstock bearing space and then reinstalling the back gears and headstock bearing. It was not easy or ideal, but possible.
  3. #18
    Nov 2012
    Mid North Coast NSW
    423
    Ooh that would be nice. I'll measure the 40T and get back.
  4. #19
    Nov 2012
    Mid North Coast NSW
    423
    Here is a drawing of the 40 tooth gear. The 120 tooth gear is 152.6mm diameter.
    Not sure how to measure the teeth themselves, they're fairly small.
    While I was doing this measurement I noticed something odd. The gears that are currently in place appear to be in the wrong orientation (according to the plaque on the machine)
    Another couple of things I need to know.
    What is the correct gear combination for cutting non metric threads ? The plaque doesn't mention this.
    and, When do I drop in the half nuts on the dial indicator for metric threads ? That's not mentioned either.
  5. #20
    Jan 2011
    Far West Wimmera
    63
    4,049
    The 120/127 tooth pair provide the ratio change for metric/imperial. I believe that the top (40T) gear can be reversed. The chart shows the gears set for metric. Yours appears to be set for imperial. Turn the top gear around as per the chart.
  6. #21
    Nov 2012
    Mid North Coast NSW
    423
    Quote Originally Posted by Oldneweng View Post
    Thanks for your answer.
    So ok if I've read you correctly, what you're saying is my machine is ready to go with imperial threads the way it is currently set up ?
    and do you believe the top gear drives the 120 tooth for imperial or 127 tooth for metric ?
    If that's the case, it solves one important question.
    and yes I'm sure the top gear would be reversible, once I get it off that is because both 40T are stuck at the moment. Prob been that way for a long time.
    I'll have to get my gear puller out.
  7. #22
    Nov 2012
    Mid North Coast NSW
    423
    The gear doesn't sit square to the large gear when its reversed.
    also, is it normal for these gears to be so tight ?
    Even after a clean up I had to wind the gear on with its holding screw.
  8. #23
    Jan 2011
    Far West Wimmera
    63
    4,049
    I could not say for sure, but that is my guess. It will cut imperial, but whether that gear combination is correct I don't know for sure. Be easy to do a scratch test on a shaft and check the pitch.
    With the gears set as per chart for metric, the drive is reduced by (120/127) or 0.9448. When set for imperial the 120T gear just transmits the rotation thru without affecting it. I guess this means you have an imperial lead screw.
    You cannot use the dial indicator for metric on an imperial lathe. You have to keep the half nuts engaged the whole time.
    My top gear is pretty tight on the shaft. It needs levering off.
  9. #24
    Jan 2011
    Far West Wimmera
    63
    4,049
    With a bit more research.
    Your lathe may have a 127T/100T combo. I pinched this quote from a thread on The Home Shop Machinist forum.
    The compunded transposing gears must convert 25.4 (25.4 mm = 1 inch) to a whole number (usually even). For 127/100, 100/127 x 25.4 = 20 for, 127/120, 120/127 x 25.4 = 24.
  10. #25
    Nov 2012
    Mid North Coast NSW
    423
    I thought about scratch test too. I will try it tomorrow.
    The lead comes in right on 8TPI so it must be imperial. Stands to reason since the machine is 32 years old.
    Your last answer about the dial indicator has made me see the light and now I understand. Thank you.
    I couldn't get my top gear off by levering with screwdrivers, I had to use a puller, so I might try a light hone inside the gear and aim for a light press fit.
    Do you know where I can get a chart showing thread depth of cut for imperial and metric ?
  11. #26
    6,480
    Does this help ?
    <http://mdmetric.com/thddata.htm>
  12. #27
    Nov 2012
    Mid North Coast NSW
    423
    Does this help ?
    Yeah that looks great. Thanks
  13. #28
    Nov 2012
    Mid North Coast NSW
    423
    Is there any reason why these two vernier dials are locked with a grub screw(circled) ?
    It would be so much better if they were reset-able.
  14. #29
    Jul 2010
    9,088
    I can think of a few but none of them important, if you want thumbs screws go for it, not like it will be hard to change back. I hope there is a soft slug under those screws so the shaft isnt all "dinged"
  15. #30
    Nov 2012
    Mid North Coast NSW
    423
    The dials on the apron handle and the tailstock don't have grub screws and so they are easy to set.
    I loosened the cross slide dial grub and found it a bit notchy to turn
  1. Hercus Lathe Manual
    By aalstin in forum THE HERCUS AREA
    Last Post: 2nd Dec 2020, 12:43 AM
  2. manual for hercus lathe
    By bt 66 in forum THE HERCUS AREA
    Last Post: 8th Sep 2019, 09:46 PM
  3. Digitising manual lathe.
    By yorkshire racer in forum THE HERCUS AREA
    Last Post: 9th Feb 2013, 12:24 PM
  4. Nuttall lathe manual
    By Old Croc in forum METALWORK GENERAL
    Last Post: 1st Sep 2009, 02:41 PM
  5. lathe manual
    By cup-88 in forum METALWORK GENERAL
    Last Post: 10th Apr 2007, 09:49 AM
