Page 5 of 16 FirstFirst 1234567891015 ... LastLast
Results 61 to 75 of 232
  1. #61
    May 2011
    Murray Bridge S Aust.
    5,959
    Mark, did you make or buy your big hacksaw?? I vaguely remember a thread where you were asking about one?? Fun part will be erecting the heavy pieces, do you have a crane, or will you hire one???
  2. #62
    Mar 2012
    Western NSW
    543
    Hi Kryn,
    i was going to make a large hacksaw out of one I already had but I bought one that should do 90% of what I need (500mm x 500mm capacity) and I'll oxy the larger ones. I need to modify some blades to fit but that shouldn't be too hard.
    i also have a 3 tonne hiab on my truck which will lift the posts into place (estimated weight of each post will be about 1000kgs).
    Will need to bring in a proper crane to move some of the larger machines and also to lift the overhead crane into position.
    Mark
  3. #63
    near Rockhampton
    6,217
    Quote Originally Posted by markgray View Post
    Getting a bit bored but need to do what I am told for once.
    ahh those bloody doctors, what would they know
    When I was assistant to building a UB shed many years ago back in the pre-internet days. we set up all the UB trusses on timber, lined one end up with each other then marked out the positions for the purlin lugs on every beam all in one go. Then a simple job of welding each one on.
    In fact if I was a squillion aire with nothing to do I would offer my services to help manufacture it. Unfortunately I am just a poor cow chaser.
  4. #64
    Mar 2012
    Western NSW
    543
    My thoughts exactly
    As a poor wheat/sheep man I hear you. If I was a sqillionaire I would pay you to come and help me. I am certainly learning a lot with this building and to me that's worth more than money. Can't wait to finish though!
  5. #65
    Mar 2012
    Western NSW
    543
    A bit of spring cleaning for the big power hacksaw. Will set up some conveyor rollers and stands to help feed the beast.
    Have to drill some holes in the blades I have so they will fit this hacksaw. Boy are the blades hard!
  6. #66
    Jun 2007
    Ipswich QLD
    68
    1,997
    Carbide bits I bought from Aldi worked fine for drilling similar for me Mark. Slow speed and steady as you go.
    Just read about knees ouch hope sorted soon.
    Shed looking good but is it big enough?🤣
  7. #67
    Mar 2014
    South of Adelaide
    1,227
    The holes would be easy to do in a EDM. You might as well get one , you have everything else.
  8. #68
    near Rockhampton
    6,217
    Looks good Mark.
    I wonder how big power hacksaws go.
    I was at an auction many years ago at a metal fabrication facility, and they had this large cold saw type machine, the blade would have been at least 3 feet in diameter.
  9. #69
    May 2011
    5,959
    I saw a cold saw like that Friday, ran at a high speed and threw sparks everywhere. Remember using one when I was a lot younger, the name Trengagger (or similar spelling) comes to mind.
  10. #70
    Jan 2011
    Far West Wimmera
    63
    4,049
    That doesn't sound very cold to me.
  11. #71
    May 2011
    5,959
    At least, it wasn't a friction blade, dirty, smelly things, cuts from those remained hot for a while.
  12. #72
    Mar 2012
    Western NSW
    543
    Raining today so harvest has come to a standstill after only 1 day. So pulled the covers off the cement after nearly a month since last slab was done. Looks pretty good.
    Time to start drawing the post configuration as making them will be the job over summer. Lots of measurements to take and decisions about the exact design. Have been doing some reading but seeing as I already have the material I can’t make to many changes.
    14664E4F-19E7-44A5-8BAE-6997109D4A77.jpg Some first drafts.
    Mark
  13. #73
    Mar 2012
    Western NSW
    543
    Quote Originally Posted by wheelinround View Post
    I have some solid carbide drills which I use of these jobs. They have 2 straight flutes rather than the helical flutes on normal drills. I must say that I run them at least twice as fast (if not more) than normal drills. Steady pressure similar to normal drills. The high speed reduces the chip load per revolution as they are prone to chipping the cutting edge otherwise. I have reground a carbide topped spade drill occasionally and I do go steady with them. Does anyone else have experience with carbide drills in hard steels?
    The shed is definitely not big enough but she will have to do!!
    Mark
  14. #74
    May 2011
    5,959
    The shed is definitely not big enough but she will have to do!! Mark
    You forgot to finish the sentence with a "for now"
    Fun part will be putting on the cladding and the roof.
  15. #75
    Jan 2004
    Mackay North Qld
    6,446
    The biggest I have seen was at QAL Gladstone ( circa late 1980's) that could cut 16" heavy wall pipe.It had hydraulic jaws that could squeeze the pipe out of round if you were not careful. The blade was made to take screwed on 75mm long carbide segments. The tooth pitch was around 5mm if I recall.
    It was a Kasto . I looked for and can't find one like it on Google. These days, by comparison, it is probably small to what is available now.
  1. what would be a better project
    Last Post: 26th Jun 2012, 06:22 PM
  2. A shed Hi Fi project
    By Graziano in forum METALWORK GENERAL
    Last Post: 3rd Apr 2012, 12:09 PM
  3. your latest project
    By krisfarm in forum METALWORK GENERAL
    Last Post: 10th Feb 2012, 04:53 PM
  4. Project #2
    By jackaroo in forum METALWORK GENERAL
    Last Post: 3rd Dec 2007, 06:45 AM
  5. Shed Heater Project (warning-large pics)
    By Plushy in forum METALWORK GENERAL
    Last Post: 20th Jul 2007, 11:32 PM
