Results 1 to 11 of 11
31st Jan 2016, 11:24 AM #1
Gasket For Rotary Hoe Transmission
I had to pull my Rotary hoe transmission apart, again.
Originally the tranny had a continuous weld all the way around it, I had to cut it and make my own flange for it so I could bolt it back together.
What type of gasket sealant do you recommend?
Do I use it with or with out a cork gasket?
What can I use for seals on the shaft where the tines attach to, under the steel cover on the R/H rear half?
I cannot get any spare parts for it as its too old, at about 15 years.
31st Jan 2016, 06:48 PM #2Most Valued Member
Don't worry about a cork gasket, unless you have included it's thickness in the spacing/depth of the flange you made. I would go for a quality sealant like threebond or something.
What type of seals did the shaft originally have? Where the inners lubricated with an oil bath or just packed in grease?
31st Jan 2016, 07:55 PM #3Pink 10EE owner
- 6,216
loctite make a red gasket maker material, or use grey silicone.
31st Jan 2016, 08:58 PM #4
31st Jan 2016, 09:29 PM #5Most Valued Member
- 5,945
For a gasket just some ordinary silicone will do the trick. If you can find a number on the seal, ask at the local bearing place to see what they might have, failing that measure your shaft and find a seal that will fit, the housing may need modifications, which should be easy for a bloke like you.
KrynLast edited by KBs PensNmore; 31st Jan 2016 at 09:30 PM. Reason: Granma
1st Feb 2016, 10:25 AM #6Most Valued Member
- Charlestown NSW
- 1,669
Geeez, there's some wear on those sprockets. Have you looked at replacing them and the chain. Might not be worth the cost though.
peter
1st Feb 2016, 11:17 PM #7Diamond Member
- N.W.Tasmania
- 1,407
I'm not too keen on Silastic for sealing against oil, as in my experience it needs to have fully cured before being exposed to the oil, but another big issue can be getting the assembly apart again if the need arrises. Either Loctite master gasket or even better IMO would be Permatex No.2 gasket compound would be my choice.
RT
3rd Feb 2016, 10:28 PM #8Senior Member
- Jun 2005
- Townsville, Tropical Nth Qld.
- 225
WM460,
If you google rotary hoe parts or manuals, you should find an exploded view for that machine and you may be lucky enough to have a part number that is universal. As the other posters have said, good quality silicone, let it cure before refilling with oil.
Rgds,
Crocy.
4th Feb 2016, 10:01 AM #9Most Valued Member
- Australia east coast
- 2,713
4th Feb 2016, 11:21 AM #10
When selecting a silicone make sure it is suitable for use as gasketing and is oil resistant. There are silicones and there are silicones.
Cheers.
Vernon.
5th Feb 2016, 09:11 PM #11
I am heading to Alice Springs tomorrow morning, I will take the tranny to CBC Bearings and see if the can help me with the bushes and seals.
rotary table
By tanii51 in forum METALWORK GENERALReplies: 24Last Post: 9th Jun 2014, 07:34 PM -
Engine Head Gasket?
By Machtool in forum METALWORK GENERALReplies: 75Last Post: 13th Mar 2014, 12:22 AM -
Rotary broaching
By morrisman in forum METALWORK GENERALReplies: 7Last Post: 29th May 2013, 12:21 AM -
Needed a chainsaw carb gasket now on Sunday afternoon.
By aametalmaster in forum METALWORK GENERALReplies: 13Last Post: 25th Sep 2012, 02:42 PM -
Which rotary table??
By xr6t in forum METALWORK GENERALReplies: 20Last Post: 5th Mar 2010, 09:22 AM
