Results 1 to 2 of 2
    Apr 2013
    Bunbury WA
    98
    Default New tank for plasma
    I just scored a compressor with a 24 litre tank, the aim is to rig the tank up so it takes air from the 40 litre tank and hopefully drops out any moisture prior to plasma cutting. I was thinking of just running a line from outlet to inlet then i thought positioning the secondary tank higher might be better. Anyone know anything about this?
    input appreciated.
    6,473
    Hi Clive,
    Water will always migrate down to the lowest point if it can. Just make sure that you can drain both tanks at the bottom. Chilling the hot air will also force moisture out as well. An old fridge could come in useful
  1. Etchant Tank.
    Last Post: 5th Dec 2015, 11:09 PM
  2. Petrol tank
    By gooddroprob in forum METALWORK GENERAL
    Last Post: 3rd Oct 2014, 09:23 AM
  3. Coollant Tank
    Last Post: 26th Mar 2012, 04:04 PM
  4. brazing fuel tank?
    By Mathuranatha in forum WELDING
    Last Post: 26th Apr 2009, 12:14 PM
  5. adding a coolant tank
    By Dusty Wheels in forum METALWORK GENERAL
    Last Post: 24th Jun 2007, 01:24 PM
