Results 1 to 8 of 8
    Dec 2007
    1,628
    Default 3D Laser Printer
    Have you guys seen this??
    http://glowforge.com/
    Ueee's Avatar
    Dec 2011
    Canberra
    39
    4,515
    Tharwa Valley Forge is getting one, it will be interesting to see what it is like.
    Dec 2007
    1,628
    Two things I don't like about it are it is "Cloud Based" so you have to send your file to the cloud and it sends instruction back to the printer, so you must have internet access and it can't drop out. The other is just calling it a printer, when it is a cutter/engraver.
    I'd love to split the cost with a few guys close by and get one.
    I assume Tharwa wants to engrave knives and make leather sheaths?
    Jul 2006
    home
    621
    Calling it a printer is a bit of a stretch. It's a laser cutter - unless I missed something in the video.
    Jul 2006
    home
    621
    Quote Originally Posted by DSEL74 View Post
    I doubt they'll be engraving (or 'printing') on knives. Metal is a problem for low power laser cutters - metal isn't mentioned as an example material either.
    We have a 40W laser cutter at my local makerspace and it can't cut metal. It can engrave on metal but it has to have a special coating applied and that's fairly expensive.
    Jun 2008
    Victoria, Australia
    74
    5,080
    My eldest son just bought a laser cutter engraver, it does plywood and acrylic, had a play with it last weekend, I don't see what this machine does that a laser engraver can do at much lower price.
    His looks like this http://www.ebay.com.au/itm/HIGH-PREC...item3f46d673f8
    Just looking at the machine, I can't see any exhaust ducting for smoke or water cooling, does this machine not need it?
    PS, As snowyskies says, my son's can also can engrave on metal, but only with special inks.
    May 2008
    241
    I have to admit, when I first read about this printer it really rubbed me the wrong way be proclaiming itself to be a "printer", when printing is an additive process, and this is purely deductive. I'd wager this misappropriation of the word printer is going to be their biggest source of revenue.
    Dec 2007
    1,628
    I think this one comes standard with a 40W laser and an option of a 45W, so it can engrave metal but not cut it. The higher W laser allows it to work much faster than the cheaper units it was compared to in a review.
    The base model ducts out the window, or you can get a filtered model, prices go up of course.
    http://glowforge.com/tech-specs/
  1. 3d printer x Milling machine
    Last Post: 22nd Sep 2014, 08:18 AM
  2. Laser Sight
    By Oldneweng in forum GUNSMITHING
    Last Post: 8th Jul 2014, 09:15 AM
  3. Looking for a laser cutter
    By Finn562 in forum METALWORK GENERAL
    Last Post: 8th Apr 2013, 07:51 PM
  4. Laser light.
    By GSRocket in forum METALWORK GENERAL
    Last Post: 27th Jul 2012, 06:44 PM
  5. Replies: 4
    Last Post: 19th May 2008, 05:03 PM
