Page 1 of 2 12 LastLast
Results 1 to 15 of 21
Thread: collet chuck
    Jun 2014
    scone
    14
    Default collet chuck
    I have a h p I -- nt40-HMC32M collet chuck, I would like to buy some collets for. Could someone suggest a supplier. Thanks JustronChuck.png Added a photo hop this will help
    Jun 2011
    Australia east coast
    2,713
    Quote Originally Posted by justron View Post
    Sorry, it doesn't really help. I assume it's a 40 taper and likely an ER32 collet, but without a picture of the collet holder, the internal taper and - ideally - a collet, we're all guessing.
    You can buy a brand new 40 taper ER32 collet chuck for less than $100, and a full set of collets for $62 when they're on special. I bought a cheap set off eBay and am quite happy with them.
    PDW
    May 2011
    Murray Bridge S Aust.
    5,942
    Be warned there are 2 different styles of collets, short and long. DAMHIKT.
    Jul 2013
    BRISBANE BAYSIDE
    90
    Hi justron,
    Hard to be sure from your photo, but it doesn't look like an ER32 collet chuck to me.
    Here are some photos of the NT30 / ER32 collet chuck that I use in my RF45 mill. Bought from CTC tools in HK.DSC04718.JPGDSC04719.JPGDSC04721.jpg
    Hope they might be of some use in figuring what you have.
    Mar 2012
    Western NSW
    543
    That looks like a Nikkon collet holder. I have one very similar and they take a special collet. Will pull mine out on the weekend and compare and post some photos.
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,540
    Quote Originally Posted by markgray View Post
    That looks like a Nikkon Nikken collet holder. I have one very similar and they take a special collet. Will pull mine out on the weekend and compare and post some photos.
    Mar 2012
    Western NSW
    543
    Oops! Yes Nikken Thanks Michael
    Here is a link
    http://www.lyndexnikken.com/Milling-Chuck
    Jun 2014
    scone
    14
    Thanks for the replies. The collets are straight, 32mm diameter and approximately 68mm l0ng.
    Justron
    Mar 2012
    Western NSW
    543
    Photos of my Nikken collet chuck and one collet.
    Hope this helps in your hunt for some collets
    2015-10-03 16.33.19.jpg2015-10-03 16.33.41.jpg2015-10-03 16.33.58.jpg2015-10-03 16.34.06.jpg
    May 2012
    Kimberley, West Australia
    176
    I have what appears to be the same chuck, obtained surplus from an engineering firm some years ago. The collets are all marked "ER32" and are metric sizes. Will this help to widen your search? Regards,
    Combustor.
    Old iron in the Outback, Kimberley WA.
    May 2012
    176
    Default Colllet chuck Oops!
    Mind not on job. Edit, Edit! That should be "ST32".
    Combustor.
    Oct 2004
    Southern Highlands NSW
    1,894
    Try Moyle's of Summer Hill, Sydney.
    Jordan
    Oct 2011
    59
    6,540
    The trouble with those Nikken chucks is the collets are not easy to find but critical to their operation, and that's assuming that the chuck is not excessively worn/damaged (that is, it still grips properly). It may be a far easier and cheaper thing to buy a ER32 chuck and collet set and use that. There are also meant to be some large C spanners with the chuck too, so if you haven't got them, there's more expense and wallet pain. The collets are similar to 5C collets where a different collet is required for each discrete size, so you will need both metric and imperial if you use both metric and imperial sized cutters.
    I have a Nikken quick-change set and after trying to find a replacement have discovered that Nikken made several similar styles of collets but only one fits the chuck. Unless you know exactly what you are looking for, ebay may not be your friend.
    Jul 2006
    Athelstone, SA 5076
    4,255
    being a so called Brand Name collet chuck I reckon the collets them selves wont be cheap?.
    so as others have said probably cheaper to get a new chuck and collets
  15. #15
    Aug 2012
    Adelaide Hills, SA
    141
    I have some of the Nikken parallel collet chucks and quick changes and really like using them. A good industrial engineering retailer should be able to get the Nikken collets. I have also found some chinese copies of them but they are not quite as accurate. You do need a c spanner. I have found it best to buy a kit with the collets and have been lucky to find them used, in good condition and nearby. I also have some adaptors for the 1 1/4" chuck that has 1 1/4" mandrels with drill chucks and MT adaptors on them. They are even easier to use than the quick change!!
    I will try and find where the parallel collets where and I will post that for you.
  1. Collet Chuck for the Lathe
    By Oldneweng in forum METALWORK GENERAL
    Last Post: 15th Jan 2015, 10:54 PM
  2. D1-6 ER40 collet chuck
    By Ueee in forum METALWORK GENERAL
    Last Post: 7th Nov 2013, 11:26 PM
  3. Collet Chuck Woes
    Last Post: 15th May 2011, 05:23 PM
  4. ER 32 or ER 40 collet chuck
    Last Post: 4th Apr 2011, 01:58 AM
  5. WIP - Collet Chuck
    By Vernonv in forum METALWORK GENERAL
    Last Post: 23rd Jan 2011, 11:53 AM
