Results 1 to 15 of 24
4th Sep 2015, 10:36 PM #1Golden Member
- Nov 2010
- Gippsland Victoria
- 733
$40 micrometer accurate to 0.00005" = credible ?
http://www.amazon.com/iGaging-Digita...ription-iframe
Is there too many decimal places here ?
4th Sep 2015, 11:29 PM #2Most Valued Member
- 4,890
No it is showing 5 ,unless it was stated as being 1,2,3 or 4 it looks right.
5th Sep 2015, 05:32 AM #3Best Regards:
5th Sep 2015, 07:49 AM #4Philomath in training
It can display to that level, but whether it is that accurate is questionable. At that level thermal effects and measuring technique have large influences, so while the micrometer may be able to discriminate to that level in reality the value displayed is probably better regarded as a random number distributed somewhere around the true value.
5th Sep 2015, 08:17 AM #5Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Hi Bill this is worth a watch about the accuracy.
It seems Mitutoyo has put out a micrometer that measures accurately down to 0.1 micron repeatedly.
Pretty rare thing.
phil
http://youtu.be/P5hMWKl7F18
5th Sep 2015, 08:57 AM #6Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
5th Sep 2015, 09:38 AM #7Most Valued Member
- Oct 2007
- 3,112
Where does it say that it's accurate to 0.00005"?
5th Sep 2015, 10:04 AM #8
Really, it's just rocket science.
Hi Phil,
I'm guessing that this sort of equipment typically gets kept in temperature controlled clean rooms. To Michael G's comment about thermal effects and techniques, I'd add that cleanliness counts as well. I could easily see that you might have to wipe the item, to be measured, down with lint free ethanol impregnated wipes, for example. You might also be limited in terms of touching the item because the heat input from your hands would change it's dimensions. The cost of developing policies and procedures might be significant.
Nice bit of kit though.
Lathes - Sherline 4410 CNC
5th Sep 2015, 10:11 AM #9Golden Member
- Nov 2010
- 733
Oooops
My apologies,
See text below
Accuracy claimed 0.00016"
Resolution claimed 0.00005"
My fault, looked at the number stamped on the instrument in the picture then getting accuracy and resolution confused - I need to smarten my act up and get a better understanding of both terms. I know theres been numerous posts about it in the past but I still haven't got it sorted out inside my head. Will go and do some learning. Now.
See text below
Professional Tool, SUPER Precision
Crisp, clear, easy-to-read LCD display, accurate to 0.00016". Hardened and ground spindle with carbide anvil ensure durability and accuracy. Comes in a case with adjustment wrench, instructions booklet, ball attachment and extra battery.
Features:
- BONUS: Ball attachment
- 2 measuring modes Metric/Inch Standard
- Large LCD Display
- Absolute & Incremental Modes
- Automatic Switch Off
- Accuracy +/- 0.00016"
- Range 1-2"/25-50mm
- Resolution 0.00005"/0.001mm
- Carbide Measuring Surfaces
- Direct USB SPC Output available
- Meet or Exceeds Federal Accuracy Standards
5th Sep 2015, 10:15 AM #10Most Valued Member
- Oct 2007
- 3,112
5th Sep 2015, 10:22 AM #11Golden Member
- Dec 2007
- 574
Looks to be the same one
http://www.aliexpress.com/item/Good-...444_6,201409_3
5th Sep 2015, 10:57 AM #12Member: Blue and white apron brigade
Precision and resolution are effectively the same as the reproducibility of a measurement.
All they mean is that if many repeated identical measurements (same object and instrument) are made then a nominal % (typically 95%) of the values should be within the precision.
On one of the You tube reviews of this instrument you can see the effect of resolution when he goes to zero the instrument. He performs the zeroing repeatedly until he gets a zero - that's probably a combo of some dust and the resolution of the instrument.
Accuracy refers to the absolute uncertainty of a measurement.
In terms of temperature effects.
The coefficient of steel @ 25ºC is approx 0.00001 m/ºC.
Hence a 10ºC change on a 1" (25.4mm) dimension in steel will change the dimension by
10 x 0.00001*0.025.4 = 0.00254 (~0.002 mm), 100º will be ~20 microns.
This is consistent with the claimed accuracy of 0.00016" or 0.0041mm
Or to look at things the other way around, the claimed accuracy will handle a temperature change of no more than ~ 16º
As BB says, cleanliness, and also surface smoothness are for most cases (especially DIY) more significant than temperature.
5th Sep 2015, 11:32 AM #13Most Valued Member
5th Sep 2015, 12:13 PM #14Most Valued Member
- Oct 2007
- 3,112
Ah, no, they're not I'm afraid. Precision, resolution, and accuracy have very specific meanings in metrology, and they're often confused. Something can have high resolution but not be accurate or precise. Something can be precise but not be accurate, nor have high resolution. So it goes on. They are all independent. Ideally of course, we'd all like to have something that's accurate, precise, and of high resolution. That's not always possible.
My favourite diagram to describe the differences is the target image.
If you want to include resolution in this the analogy would be to take a telescope and zoom in on where the darts land. The higher the resolution, the greater the magnification of the telescope.
With things like micrometers, I would encourage people to stay away from cheap Chinese rubbish. Your measuring tools are the foundations upon which you build all your work. If you can't trust them, then the game is over before it even begins. Good tools are expensive, however they often come up used in good condition for no more than the Chinese rubbish.
5th Sep 2015, 12:38 PM #15Pink 10EE owner
- 6,218
I have a very repeatable chinese micrometer, it is consistently off by 0.01mm at various points of travel... In some places it might be +0.01mm, other places -0.01mm..
It is very repeatable thoughGold, the colour of choice for the discerning person.
Suggestions please: Accurate hole drilling
By LouL in forum METALWORK GENERALReplies: 15Last Post: 25th Sep 2011, 12:39 AM -
QUEENSLAND Mitutoyo Digimatic micrometer, Inch/Metric 1-2"
By SurfinNev in forum METALWORK - Machinery, Equipment, MARKETReplies: 4Last Post: 5th Oct 2010, 02:51 PM -
accurate countersinking SS
By old_picker in forum METALWORK GENERALReplies: 8Last Post: 2nd Oct 2009, 03:05 PM -
Opposing toothed "Clutch-Plate" Nuts? (a bit like "Castle" Nuts...)
By Batpig in forum METALWORK GENERALReplies: 6Last Post: 5th May 2009, 08:18 PM -
Difference "Galvanised" and "Primed" Steel
By Fr_303 in forum METALWORK GENERALReplies: 4Last Post: 22nd Jan 2008, 05:59 PM
