Results 1 to 12 of 12
    Jul 2008
    near Warragul, Victoria
    3,718
    Default Indexible milling cutters
    Was doing some browsing and came across these http://www.ebay.com.au/itm/Set-of-in...item3f500ab2ba What is the general opinion on these ? Mike
    Jun 2007
    sydney ( st marys )
    64
    4,887
    What RPM is the machine there to be used on good and what type of cutting would you intend doing with them.
    A general opinion would only be based on what someone else has used them for.
    I feel unless you know what you will be doing with them anyone's opinion is really null and void.
    Mar 2014
    South of Adelaide
    1,225
    That is pretty cheap. I don't have them but use similar cutters at work. You need a pretty rigid mill to use cutters like that successfully. I don't know what mill you have but i wouldn't use them in a hobby mill.
    Jun 2011
    Australia east coast
    2,713
    You need rigidity, HP and decent spindle speeds to get the best out of them.
    IOW if you have an RF45 type mill, don't bother.
    PDW
    Mar 2008
    nowra
    1,598
    Do you plan on using them on the cva mill ?
    Andre
    Jul 2008
    3,718
    Default cva
    My little CVA die sinking mill might handle those indexible cutters OK . From what I have read online: another CVA owner has written "it is a very rigid machine" It will spin up to 3000rpm in its standard configuration and I am fitting a higher HP motor to the CVA . Anyway 'Welder' who also has a CVA may comment on his experiences.
    Jul 2008
    3,718
    Default yes
    Quote Originally Posted by welder View Post
    Yes
    Mar 2008
    nowra
    1,598
    Its funny I bought some OF THOSE last week and.played.whith them on the weekend.
    Andre
    Jul 2008
    3,718
    Default Great minds
    "great minds think alike" So how well did they perform ? Did you give them a good try out ?
    Feb 2013
    Laidley, SE Qld
    1,038
    I have a 16mm one of those that I bought from CTC some years ago. It works OK for light cuts on a Hafpos HM52 at my max speed of 2400RPM. Doesn't leave a great finish but does remove metal. I figure that a pair of inserts are way cheaper than a 16mm HSS cutter.
    near Rockhampton
    6,216
    I have a 16mm one... With my bridgeport clone max depth of cut is about 0.75mm.... After that it chatters...
    Mar 2008
    nowra
    1,598
    I tried the 12mm holding it in ER collet but was very dissatis3ed. This was mainly because I didnt have enough preload in the mill spindle ,So after I fixed that problem, I went about work holding differently,I took the 25 mm cutter and.machined the end to MT3 and tapped it M 12. That worked better and I could take a 2.5 mm cut
    Andre
  1. AZSTAR Australian made milling cutters
    By bob ward in forum METALWORK GENERAL
    Last Post: 3rd Jul 2015, 09:51 AM
  2. Cutters for milling machine
    By woodfast in forum METALWORK GENERAL
    Last Post: 10th Apr 2012, 05:05 PM
  3. Threaded milling cutters
    Last Post: 28th Sep 2011, 03:37 PM
  4. Holders for milling cutters
    By Tiger in forum METALWORK GENERAL
    Last Post: 11th Oct 2009, 02:13 PM
  5. I'm after some odd milling cutters
    By funkychicken in forum METALWORK GENERAL
    Last Post: 4th Sep 2009, 09:28 PM
