Results 1 to 15 of 16
Thread: Self drilling taps
26th Jun 2015, 11:05 PM #1Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,039
26th Jun 2015, 11:17 PM #2
Hi Bob,
A few years back I had a sales representative from a tool manufacturer call to demonstrate some of those "self drilling taps" ! He actually left me a couple of them. No they don't drill the hole as such. They are intended to open out an existing hole to the correct tapping size.
The idea being that nominal sized holes slightly off position could be threaded by an unskilled operator.
After we broke several of his taps using a drill press and reversing tapping head the representative went away, not to be seen or heard from again. The tool company that he came from sent me, FOC a set of metric taps. I still have some of them.Best Regards:
26th Jun 2015, 11:20 PM #3Philomath in training
They are a spiral flute tap. Self drilling taps have an end that looks like a drill bit on them (as per the picture). The point on the end of those does not really have a purpose - it is probably there to aid manufacture.
Very handy for bulk tapping, especially with a tapping head.
26th Jun 2015, 11:22 PM #4Most Valued Member
So they're not worth buying??????
26th Jun 2015, 11:37 PM #5
Hi Michael,
The problem that I / we (the rep) found was that there is a conflict between the tapping head clutch setting for drilling and tapping. Set the clutch for tapping and you couldn't apply as much down force on the drill. So drilling took a lot longer. Set the clutch tighter and you broke the tap. These drill taps are really only any good when used with CNC machines where you can independently control the drilling and tapping parameters.Best Regards:
26th Jun 2015, 11:42 PM #6
I believe they are machine taps and clear their own swarf ( to a degree )
The ones I have used required about a third of the force needed by the straight groove taps.
27th Jun 2015, 01:26 AM #7
Spiral flute taps, not as robust us hand taps or gun nose but they push the chip (wire really) up out the flutes. Best for blind holes, use gun nose for through holes. They do not need to be backed out of the cut to break the chip like with a hand tap, just drive them in. In fact backing them out will mean the chip does not come out properly. In all seriousness, does anyone still buy hand taps?
27th Jun 2015, 01:58 AM #8Most Valued Member
- 4,890
I still do as a lot of the sizes I use are far to expensive in spiral form or gun nose if available.
27th Jun 2015, 08:49 AM #9New Member
- Mar 2014
- Norway
- 3
I buy hand taps when I see them second hand. I only buy industrial HSS hand taps. I use these for thread repair more than cutting threads. I have spiral taps and machine taps which I prefer for cutting threads from scratch. A good quality hand tap is still a decent investment for the average hobby machinist.
Paul.
27th Jun 2015, 02:33 PM #10Senior Member
- Jul 2012
- Griffith NSW
- 435
27th Jun 2015, 03:33 PM #11
The tap is definitely not one for use in a school.Trust me on this.
Maybe one student in ten could be relied upon to use the tap properly and not break it.
Crikey! Kids just using ordinary taps is a PITA. My strategy was always to design projects that required a fairly big diameter tap as using the smaller ones meant they would just snap them like carrots.
As an experienced user you will begin to appreciate it when a spiral tap is just so much easier to use.
As far as the drill tap shown, I have a set of them ,bought to drill and tap holes for wooden battens to a steel frame gate.
I used a M6x1 to drill and tap a couple of hundred holes with the battery drill.Well worth the money in this case as it was a real time time saver.
27th Jun 2015, 10:03 PM #12Member
- Jul 2012
- Malvern East
- 84
its the reverse centre
The reason for the point on the end of a spiral flute gun tap is to support the end of the tap during the grinding process the spirals are ground in in one operation and the end of the tap deflects too much so instead of a centre drill the end of the tap is supported on a male centre
Anca grinding machines can spit one out in under 30 seconds
Bruce
13th Jul 2015, 05:00 AM #13Golden Member
- Nov 2010
- Gippsland Victoria
- 733
13th Jul 2015, 08:02 AM #14Philomath in training
It's a personal preference but I'd suggest not - as Ewan says, they are a little more fragile so the likelihood of snapping one off is increased.
Once you are confident that you are tapping square and you can judge the resistance of the tap well then try one.
I have metric spiral flute taps that I use reasonably often for hand tapping but still use straight flute taps for smaller holes and other thread forms. For the ones and twos that I do, there is no great time saving. I did use a tapping head with a M6 spiral flute tap for 80 or so holes and that was like magic!
13th Jul 2015, 11:54 AM #15Golden Member
- Aug 2012
- Australia
- 645
As Ew said initially, spiral taps are great for blind holes. Given the full-depth (70% or so ref Stuart ) thread starts a lot earlier on the tap than say a gun or standard tap you can tap holes blind holes a lot deeper with good thread penetration.
They also look mighty cool when using them..
Which Taps would you buy?
By ventureoverland in forum METALWORK GENERALReplies: 29Last Post: 30th Jun 2014, 08:32 PM -
BA taps
By morrisman in forum METALWORK GENERALReplies: 9Last Post: 23rd Sep 2011, 05:16 PM
