Results 1 to 15 of 20
Thread: parting tool geometry
21st May 2015, 06:41 PM #1Senior Member
- Jan 2015
- 211
Ive been trying to part of some 35mm steel in my lathe, im running at about 150rpm and got the auto cross slider feed on 0.029mm/rev and it just isnt happening, stalled the lathe, tool dug in even snapped the blade off today. i did try to slow the feed rate down to no luck, which brings me to is the tool geometry right. whats the correct geometry for parting tools?
thanks
21st May 2015, 06:59 PM #2Most Valued Member
I used to have all sorts of issues with parting off. Similar to you, snapping blades and ripping the workpiece out of the chuck being the biggest issues. Then, there was a time when Stuart (stustoys) and I were talking shed stuff and he mentioned about reducing the back rake so that the tool is not so inclined to be pulled in to the work. I now grind my part off tools with very little back rake and it's pretty much fixed all my issues. I use a few other precautions too though. With large stock requiring deep cuts, I often part off in two places right next to eachother to create better tool clearance. I also withdraw the tool frequently to clear swarf, err on more feed rate rather than less, especially with stainless and I always use a form of lubricant, use the least amount of tool overhang as possible to get the job done and do it as close as possible to the chuck.
If you are using a part off blade that is thicker at top than the bottom, make sure you don't grind it upside down or it will not have the required clearance and it will grab. I don't use carbide part off blades, no need for my uses and they seem so expensive compared to a seemingly endless piece of HSS.
I still get nervous when parting large parts because of what used to happen, things would often seem OK and doing well and then at the last minute BANG! Bits everywhere!
21st May 2015, 07:12 PM #3Most Valued Member
Any chance of pics to show what you mean, please Simon. Always interested in learning something new.
21st May 2015, 07:17 PM #4Pink 10EE owner
- 6,218
lubricant, lubricant and more lubricant is a major secret of successful parting off with HSS...
21st May 2015, 07:30 PM #5Senior Member
- Jan 2015
- 211
21st May 2015, 07:33 PM #6Most Valued Member
I'll duck out to the shed at take a pic of my blades. Bare in mind that there are many people far more experienced than me when it comes to (successful) parting off.
21st May 2015, 07:37 PM #7Senior Member
- Jan 2015
- 211
21st May 2015, 07:43 PM #8Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 838
It could have more to do with the Lathe rather than the tool geometry, what type of machine are you using?
21st May 2015, 07:48 PM #9Senior Member
- Jan 2015
- 211
21st May 2015, 07:57 PM #10Most Valued Member
Here are my 3 blades I use. Looking at them they are a little tired and probably need a re-sharpen before next use but the geometry can be seen. The second pic is end on to show how the wedge shape provides clearence from the rest of the tool… assuming you don't do what I did and sharpen upside down so that the cutting is done at the narrowest (thinest part) and then siezes when fed in!
I also used to blame the quality of the steel too. But you can see that one of the blades is made in India and the others are China. Not top quality stuff but it still works for me. Also, I rarely use auto feed. I like to feel the tool cutting and vary the feed rate until it feels nice. It should feel like your cutting butter, if it doesn't then there is something not right. I find that feeding not enough can be worse than too much especially with stainless steel, it needs a nice positive feed rate or the tool will just work harden the work and rub and go blunt.
Edit: I just read Techo's response. The other things that you may want to look at are spindle bearings, cross slide and compound backlash and gibb adjustment but my experience showed the vast majority of my issues were user related such as tool geometry, feed rates, lubrication and tool rigidity. Also, don't forget to wind in your compound all the way. I do this because my Chinese lathe has a less than perfect compound and winding it in all the way adds to rigidity.
CheersGirl, I don't wanna know about your mild-mannered alter ego or anything like that." I mean, you tell me you're, uh, super-mega-ultra-lightning babe? That's all right with me. I'm good. I'm good.
21st May 2015, 08:28 PM #11Golden Member
- Mar 2009
- 54
- 825
I've had similar issues, I reckon everyone has fun and games when they first use a parting tool, it really fires the pucker reflex when the tool grabs and shatters with a bang.
I generally have good results with the following:
For steel or staino no top rake at all and keep the tool lubricated with oil, not the milky soluble stuff, proper cutting oil if you can get it, I use the Trefolex CDT in a spray can. Never let the tool rub on staino or it will work harden. For 35mm free cutting steel 150-200 rpm will be good to start but speed it up as the cut gets deeper, should be around 400 by the time you finish. Lower speeds for harder steel alloys and slower again for staino, a VFD is at its most useful when parting.
For brass or bronze a bit of negative or no top rake, I don't use any lube and rpm can be a bit faster.
For ally or plastic, grind a bit of positive top rake (2 o 3 degrees) no lube for plastic and a bit of kero, diesel or cutting oil for ally, again higher rpm is ok.
In general, keep the front relief small to support the tip, I usually feed the tool straight into the grinding wheel and let the curvature create the front relief. Make sure tool is set 90 degrees to work and on centre or even a little below but never above. Keep tool extension from holder as small as possible, extend tool out as cut progresses if necessary. Again increase rpm as cut progresses, if speed is too low it will be more inclined to dig in.
Greg.
21st May 2015, 08:35 PM #12Senior Member
- Jan 2015
- 211
Thanks for the pics. Ill try have a go at that. Because i mainly use carbide im not really cluded up on what back rake ect ect is. Could somone help me out?
21st May 2015, 08:40 PM #13Pink 10EE owner
- 6,218
My other take on it is front clearance should be kept as small as possible, this is what will stop the tool from digging in and is sort of you depth of cut restrictor..
A real learned person like Steamwhisperer may have the most parting secrets to give up...
I gave up with HSS and went to carbide inserts...Gold, the colour of choice for the discerning person.
21st May 2015, 08:53 PM #14Most Valued Member
Have a look at these pics and then compare to my pics and it will give you an idea of rake angles and front relief. You can see that my tools have very little positive rake angle. Greg suggests zero or negative for brass or bronze but I rarely change my angles specific to material type, mainly cause I'm too lazy.
Toolbit.gif This is for a general lathe cutting tool but the front relief is the same concept.
21st May 2015, 08:56 PM #15Senior Member
- Jan 2015
- 211
So thats the back rake..front releif i guess is the angle on the front of the tool
parting off... or should I say ..how to break the parting off tool
By eskimo in forum METALWORK GENERALReplies: 19Last Post: 19th Mar 2014, 02:29 PM -
Your best parting tool
By iron bark in forum METALWORK GENERALReplies: 61Last Post: 20th Dec 2012, 07:40 PM -
Parting tool mounted on rear tool post advice needed
By colbra in forum METALWORK GENERALReplies: 17Last Post: 12th Feb 2012, 02:49 PM
