Results 1 to 6 of 6
Thread: X2 Parts????
17th May 2015, 03:33 PM #1Most Valued Member
- 5,942
X2 Parts????
Has any one changed their X2 to a belt drive? I am after the small gear that goes on the motor, also I doubt anyone would have it, but after the plastic mount that goes between the motor and the gearbox cover. Trying to keep it going, till I can do the conversion.
17th May 2015, 04:47 PM #2
Amos (Penturner) has but it may be a slightly different model (Asset Machinery).
He is moving to Cairns in a couple of days so you better be quick.
17th May 2015, 05:08 PM #3Senior Member
- Oct 2009
- Upwey VIC
- 186
Kryn,
Are these the parts?
May be worth checking the motor shaft diameter as I believe this has varied with certain models.
I think the one pictured is 9mm ID.
Andrew.
17th May 2015, 05:46 PM #4
Seen this on epay.
http://www.ebay.co.uk/itm/Sieg-X2-mi...item3aa9764e57
17th May 2015, 06:17 PM #5Most Valued Member
- 5,942
18th May 2015, 09:45 PM #6Senior Member
- Jan 2015
- 211
I
Using used car parts
By Dave J in forum METALWORK GENERALReplies: 23Last Post: 6th Apr 2012, 10:01 PM
