Results 1 to 11 of 11
Thread: Steel Suppliers in Sydney
2nd May 2015, 09:27 PM #1Novice
- Jun 2010
- 19
I am trying to buy some 1215 grade free machining steel in a few sizes. Maybe some round bar, some flat and some square in various smallish sizes. My local steel merchant (Mascot Steel) were unable to help. When I asked at the counter for some free machining steel the sales guy just said we only have mild steel. When I asked him what grade he told me mild steel and he had never heard of any different grades. I bought a bit of round bar and took it home, it was black steel bar ( hot rolled I am guessing )and machined OK but with a pretty bad finish. Edcon steel have some bright mild steel which is better but still not great. Can anyone point me in the direction of a decent steel supplier in Sydney where I can get a few pieces of free maching steel. It doesn't have to be 1215 grade, just something with a little lead in it would be fine.
2nd May 2015, 09:50 PM #2Senior Member
- Jul 2012
- Griffith NSW
- 435
2nd May 2015, 10:06 PM #3Senior Member
- 112
You might try Bohler-Udderholm who have a Nth Parramatta address, phone 9681 3100. Up to about 18 months ago they had a retail outlet at Kings Park called The Steel Store where most grades of steel & CI were available. Unfortunately it has closed, and I suspect those services may be no longer available. It would be worth a phone call.
Chas.
2nd May 2015, 10:23 PM #4Most Valued Member
- 5,942
3rd May 2015, 10:42 AM #5Senior Member
- Dec 2010
- Syd
- 492
I understand Bohler have Wollongong and Newcastle warehouses, doubt that would be economic for a few bibs and bobs. Guildford the other one, closed 6 or 7 years back, I'd be surprised if Parra was anything but an office.
Bit ironic, what was once a very industrial area not that long ago, from Redfern, Alexandria to Mascot you struggle to get a bit of steel now! Could try Interlloy if you fancy a hike and avoid fees.
3rd May 2015, 01:32 PM #6Novice
- Jun 2010
- 19
OK thanks for the suggestions. I will check them out and let you know how I go.
3rd May 2015, 02:37 PM #7Intermediate Member
- Jul 2009
- 45
- 42
Edcon steel at Brookvale are pretty good and helpful.
4th May 2015, 09:35 AM #8
4th May 2015, 08:45 PM #9Senior Member
- Aug 2010
- Springwood
- 168
I believe EDCON steel still supply engineering steels. You might have to talk to head office to order it. Have a look at the website and play with the steel finder search engine. It lists free cutting mild steel as a grade.I noticed a few years ago they changed the website and removed the visible links to engineering steels, it's in the downloadable catalog also. I think all engineering steel is stocked at Milpera (Revesby) store as I have ordered small amounts of differing grades and it is cut and shipped from there to blacktown where I collect it.
The free cutting stuff would more than likely be 12S14 (S1214) (sulphurised) mild steel. Unlikely to get leaded (12L14) as I don't believe it's manufactured now due to OHS issues with handling lead at the smelter.
http://www.edconsteel.com.au/steel-finder
Here's the tech data on 1214 (12S14) there's a list of recommended alternatives in this sheet. Notice it warns against galvanising and welding and it has an unchecked tensile strength.
http://www.edconsteel.com.au/pdf/1214.pdf
5th May 2015, 11:44 AM #10Senior Member
- Jan 2015
- 211
If you tell edcon steel what you want im sure they will order it, usually when they order stuff in its a minimum order, usually a length. Have a look on edcons website and they have the steels they 'stock'
6th May 2015, 08:05 PM #11Novice
- Jun 2010
- 19
Thanks Swarfmaker and other respondents. I did as suggested and used the advanced search facility and was able to see they do sell free machining steel grade 1214. It's just not listed in the steel finder. I have bought from them before and found the guys on the shop floor quite helpful so I will order what I need from them. Thanks again to all.
Steel Suppliers Brisbane
By smidsy in forum METALWORK GENERALReplies: 4Last Post: 15th Mar 2012, 03:10 PM -
Cor-ten steel price and suppliers
By rod13 in forum METALWORK GENERALReplies: 3Last Post: 9th Jan 2012, 01:25 PM -
Queensland Steel Suppliers
By smidsy in forum METALWORK GENERALReplies: 1Last Post: 22nd May 2011, 08:18 PM -
Steel Suppliers
By cliff.king in forum METALWORK GENERALReplies: 5Last Post: 30th Mar 2008, 09:32 PM
