Results 1 to 15 of 20
Thread: How did he make this?
24th Mar 2015, 01:40 PM #1
Quite a few years ago a family friend made this pot for us. He made it at a time when I didn't have much interest or knowledge about metalwork. He is now deceased unfortunately. It's a pot that we have used for boiling tomato sauce bottles among other things. The bloke that made it would have only had basic tools and was not a metal worker. I know he had an arc welder and perhaps an angle grinder. I believe he took a beer keg and modified to make this pot. I don't know much about beer kegs but can anyone tell me what type of metal this would likely be and how did he rivet/join the handle to the top of the pot? I've been asked to make something similar and this pot is very sturdy and convenient. It has a few hammer marks which I think our family friend was responsible and I can see the welding near the bottom, apart from that I don't know much else.
24th Mar 2015, 02:08 PM #2Most Valued Member
Hi Tiger, if it was a keg, it would probably have been stainless steel, with the top cut off.You could try scrap metal merchants to see if they have any. The handles are a U bolt that would have been cut to length, drilled, one hole drilled into the pot where the handle was required, then a rivet would have been set and peened over. Once one rivet was in, the rest of the holes would have been drilled and then riveted.
Another alternative is a hot water system tank, they are usually steel and could possibly be picked up from plumbers, a bit cheaper than a S/S keg. Cutting it would be the same as for the stainless keg.
24th Mar 2015, 02:24 PM #3
Thanks Kryn, sounds like you know your beer . Great info and very helpful, tell me is there much to this setting and peening? And do you reckon the weld near the bottom was already there?
24th Mar 2015, 02:51 PM #4Most Valued Member
Hi Tiger, the only thing I know about beer, is that draught beers always show the manufacturers on the labels, (Draught Horses), I find beer tastes terrible.
Setting and peening is (I could stand to be corrected) where a rivet is put into a hole (usually a sliding fit) then a setting tool is used, this tool is similar to a punch, but has a hole in it for the rivet to slide in, this forces the 2 parts together, then the rivet is peened over using a ball peen hammer, with a lump of steel to prevent the rivet coming out when peened.. Getting the rivet the correct length is the fun part, to short and it won't hold, to long and it looks ugly.
It's hard to say if the weld is new or old because of the dirt on the side of it, but looks as if it is original.
24th Mar 2015, 02:59 PM #5
Thanks again Kryn, I'd shout you a beer but I don't have any.
24th Mar 2015, 11:21 PM #6Most Valued Member
25th Mar 2015, 07:31 AM #7Most Valued Member
- Charlestown NSW
- 1,673
If you have access to a welder it would be a whole lot easier and quicker to just weld the handles to your new pot. I understand that a welder might not be an option. If not, you could also use screws in place of rivets. I'm thinking gutter screws with the head inside the pot to give you a fairly low profile, nut on the handle side and if you cut the screw to the right length you could then pein the end over like a rivet. It wouldn't come loose if you did it right.
bollie7
25th Mar 2015, 08:18 AM #8Intermediate Member
- Sep 2014
- Australia
- 26
It looks like half of an old air compressor tank to me. Is it stainless steel or regular carbon steel?
25th Mar 2015, 08:26 AM #9Intermediate Member
- Sep 2014
- Australia
- 26
Actually, its also possible that its an old cornelius keg. Home brewers tend to use these for beer as you can open the top to clean them. Maybe if there is any home brewers here they can confirm what the kegs look like with the bottom plastic part removed.
25th Mar 2015, 09:00 AM #10Senior Member
- gold coast
- 303
Tiger--- It looks to me to be the top of a hot water system. Try scratching the metal to check if its shiny or 'red'. If it's shiny then its probably steel, and if its 'red' then its copper.
I suggest that the weld on the bottom was made during manufacture and not by your friend, who possibly just cut the hot water tank in half.
If you have a friend who is a plumber then he could look out for one when hes doing a replacement, since they usually go to the dump or scrap merchant.
Good hunting
Brian
25th Mar 2015, 10:02 AM #11
Thanks for the comments, I can weld to an extent but the weld on this item looks very clean and measured. I've been told that the item may have been a beer keg but we've never been certain. I think it's stainless steel, it's fairly heavy (and very sturdy) but I'll do that scratch test to see. Brian, you may be right, could be part of a hot-water system, I'll do some searching on the Internet and see if I can find something similar. Not sure why it was riveted as I agree screws would have been a bit easier but the way the guy did it, there's been no movement with the handles at all despite the weight we've put in the pot.
25th Mar 2015, 11:49 AM #12Senior Member
- 316
Hi Tiger,
Personally I think the most important issue you will need to address, is to ensure whatever material you use (maybe bar stainless steel) is to have the inside surface coated especially if it is to be used for human consumption. I know a lot of people are skeptical of these claims but it is better to be safe than sorry...
http://www.naturalnews.com/036029_co...hemicals.html#
MH
25th Mar 2015, 12:12 PM #13
25th Mar 2015, 12:21 PM #14
Reading that naturalnews link, I think I'll wear my sceptical hat with an added sceptical scarf, gloves, belt and braces. Apparently the only safe saucepans are the ones made from titanium! (obviously hasn't seen the research on titanium toxicity!)
Interestingly, the article says that cast iron is bad, but a link further down the page promotes cast iron as good.
However, reading it in detail it definitely says that iron is bad for you...I wonder if I can get it chelated out of my blood!
25th Mar 2015, 02:43 PM #15
Mainly used for boiling bottled tomato sauce so nothing eaten directly from the pot.
OK So I Want To Make One Of These
By seriph1 in forum METALWORK GENERALReplies: 10Last Post: 21st Feb 2011, 06:18 PM -
What I Make (or used to)
By Wood Butcher in forum METALWORK GENERALReplies: 6Last Post: 17th Oct 2005, 09:14 AM
