Results 1 to 7 of 7
19th Mar 2015, 08:36 AM #1
WX#@%G AL-320G longitudinal/cross feed handle
Has anyone devised and fitted a simple stop to prevent flicking through neutral? Pics are good!
19th Mar 2015, 12:14 PM #2
AL 320G handle
you can't get more simple than this, just remove the pin for the side you want to use, Leroy.
19th Mar 2015, 12:16 PM #3
19th Mar 2015, 12:29 PM #4
Al320G handle
from memory about 10 to 12mm deep, keep them a close fit with the pins so they don't wobble, I seem to remember one of the holes went right through and I had to plug it from underneath but that was just carelessness on my part,
Leroy.
19th Mar 2015, 09:10 PM #5Member
- Jul 2013
- BRISBANE BAYSIDE
- 90
I did basically the same thing, except I just used plain 3/16" ss rod for the removable pins.
Holes were drilled 3/16" and are 16mm deep. Pins are 41mm long.
Works like a charm and it's basically foolproof.
This is a basic design flaw in the AL-320G but this is a simple fix.
Alan
19th Mar 2015, 09:28 PM #6Member
- Jul 2013
- BRISBANE BAYSIDE
- 90
Here are some photos of my mod. Wasn't sure if I could figure out how to add them, but it seems to have worked.
I did not go through the casting with 16mm deep holes. The pin lying next to the lever was just left there to show the length for the photo. When I remove a pin to operate the feed handle, it gets put on the non skid decking material on top of the gearbox.
All the best with it.
Alan
20th Mar 2015, 09:44 AM #7Most Valued Member
- Jun 2012
- SA
- 1,649
Why not just fit a spring loaded detent pin/ball under the handle base, and drill a register hole (s) where needed.
This is the same method as used for QCGB selection dials/levers.
Be a lot better than stuffing around with pins.
Be dead easy to make a larger metal base block if needed - just extend the rear away from the handle threaded side.The worst that can happen is you will fail.
But at least you tried.
Cross feed fix for SB or Hercus ?
By morrisman in forum METALWORK GENERALReplies: 0Last Post: 28th Sep 2012, 08:27 PM -
Dodgy cross feed nut
By morrisman in forum THE HERCUS AREAReplies: 4Last Post: 20th Feb 2012, 04:32 PM -
Cross feed material
By morrisman in forum METALWORK GENERALReplies: 1Last Post: 26th Dec 2011, 12:32 PM -
Cross feed nuts .......ideas
By morrisman in forum METALWORK GENERALReplies: 2Last Post: 2nd Dec 2011, 05:47 PM -
cross feed screw
By azzrock in forum THE HERCUS AREAReplies: 57Last Post: 6th Feb 2011, 05:41 PM
