Results 1 to 15 of 44
1st Mar 2015, 08:52 PM #1Intermediate Member
- Jan 2006
- Malvern East
- 36
Which pedestal drill press should I buy?
Hi All,
I am looking to build a CNC machine from aluminium and MDF and I need to get myself a pedestal drill press.
I have heard that the Taiwanese made ones are a lot better than the Chinese ones with the price to match so I am looking for guidance.
I have up to $800 to spend but could stretch that a bit further for the right one. I figure that this will last me for 10 years so a few hundred extra now is not a big deal.
What is the best I can get for this kind of money that will suit hobby / backyard woodworking and aluminium drilling?
Ideally I would be able to get it from Melbourne so I can look at it prior to purchasing.
Thanks.
1st Mar 2015, 10:07 PM #2Philomath in training
- 6,559
Your question is a little open ended as you have not said what size holes you wish to drill, how often you think it will be used or the thicknesses of the materials. $800 will buy a reasonable drill press from someone like Hare & Forbes - http://www.machineryhouse.com.au/Ben...lling-Machines.
Taiwanese is usually better quality than Chinese, but there are good and bad of everything.
It would also allow you to buy a good second hand unit. Waldown are much favoured on the forum; other brands generally well regarded are Tough and Servian. Whether second hand will suit depends as much on what you want it to do as what is available at the time and your confidence in selecting good from bad. Potential bargains are old 3 phase units - you would need to fit a VFD but most members don't see that as a disadvantage.
The one thing I would suggest is steering clear of drills being sold though your local hardware store. As has been pointed out before for other similar questions you get what you pay for so a $129 drill press will be of pretty basic quality.
MichaelLast edited by Michael G; 1st Mar 2015 at 10:10 PM. Reason: Added VFD bit
1st Mar 2015, 11:08 PM #3Member: Blue and white apron brigade
One of the major differences between DPs that are less than $800 is quill travel.
Standard quill travel is about 80 mm but the bigger drills have 100 mm or more travel and this is really useful to have
The other significant difference is bigger motors.
1st Mar 2015, 11:21 PM #4Golden Member
- victoria
- 499
2nd Mar 2015, 06:29 PM #5Novice
- 19
Another vote for an old Waldown - nice heavy construction. They're an Australian brand too, so you can still get help from them, with old instructions/drawings and maybe spare parts if you're lucky. Here's what they've been selling for on eBay:
http://www.ebay.com.au/sch/i.html?_f...mplete=1&rt=nc
2nd Mar 2015, 08:55 PM #6Member
- Jul 2013
- BRISBANE BAYSIDE
- 90
If you want a new drill press, then Trade Tools have a good range of Taiwanese machines, and while they are very big in Queensland, they do have a Victorian store at Dandenong. I have owned and used one of their drill presses since the late 80's. Well worth a look if you are anywhere near. Alan.
2nd Mar 2015, 10:22 PM #7Intermediate Member
- Dec 2011
- Buderim qld
- 40
Nearly all the imported stuff has gone up in price recently due to our weakening dollar.
3rd Mar 2015, 04:45 PM #8
Lots of variables, if you have 415v 3 phase power, I'd go looking for an Arboga around the auctions, they come up all the time and go for less than your $800 budget. Old Waldown's are beautiful to use, heavy, solid, smooth running and just all round nice to use. I wouldn't buy any of the current new drill presses. Maybe consider a decent second hand mill drill, if it was the right price.
Alternatively, keep an eye one the Grays Auctions in your area.
PS.. Just for fun, I did an ebay search for Arboga... here's one for $7000 ( outch) http://www.ebay.com.au/itm/ARBOGA-A2...item3cee7bae44
3rd Mar 2015, 05:30 PM #9
Saber 1100W-drill-press_main.jpgMy choice would fall with a Taiwanese manufactured drill press
Most Taiwanese model drill presses I have gone over seem to offer in general.
A minimum spindle movement
The motor is usually of a good standard
The motor and belt tension systems work fairly well
The table height change mechanism components are usually not plastic
The tables are made from a decent thickness material and sport decent T slots
The spindle winding arms are solid -the better ones have a single cast arm
These are features I would look for.Total tools have one in the Saber their house brand .I can't think how much it was.< edit> the table model pictured in $599 and the floor model $999.The floor model is the one that has the T slot table and has a 20 mill capacity over the the table model 16mm.Both have keyless chucks. I like the one piece spindle winding arm as the arms on the other types can fall out over the years.
4th Mar 2015, 06:48 AM #10
I agree with Grahame. I was looking for one of those super duper old drill press for month to no avail.
Either overpriced or need a crane to move it, or interstate ... anyway, no luck. And I have 3ph in the workshop, if you don't, you are even more restricted.
Finally gave up on those and concentrated on new taiwanese.
Found this one http://www.machineryhouse.com.au/D152 second hand from a fencing factory that closed down for half the new price.
It was two years old and was a few blocks away from Hares and Forbes so decided to take it to them for a check.
They were very accommodating and found a factory defect that made it noisy.
Had to pay for the parts but not for the labour because it was just out of warranty apparently (?)
Anyway, very happy with this thing. Heavy, powerful 1.5hp motor, long stroke, heavy duty lift for the table, a bit stiff to rotate the table but manageable.
I took out the original chuck and bought a bigger keyless chuck that works like a charm. Speed is slow enough to use a broach adaptor for big holes
They make one even bigger than this but the price new is something like $1,200Civilized man is the only animal clever enough to manufacture its own food,
Barry Groves
4th Mar 2015, 09:08 AM #11
Even at the H &F $869 price that drill press compares very favorably with the total tools equivalent model being some $130 cheaper for the same features.
4th Mar 2015, 02:04 PM #12Senior Member
- Jan 2015
- 211
hare and forbes have a sale on form the 19th-21st if you where going to get a drill from there.
4th Mar 2015, 09:56 PM #13Intermediate Member
- Jan 2006
- Malvern East
- 36
Hi everyone,
Thanks for all the great advice.
The H&F drill press is the one I was looking at.
Are they definitely having a sale this month?
Thanks,
Brenton
4th Mar 2015, 10:39 PM #14Member: Blue and white apron brigade
4th Mar 2015, 11:13 PM #15Intermediate Member
- Jan 2006
- Malvern East
- 36
