Results 1 to 10 of 10
Thread: X2 Modifications
23rd Jan 2015, 01:17 PM #1Most Valued Member
- 5,945
X2 Modifications
Has anyone done a 2 speed belt drive conversion on the X2 minimill? Tired of replacing stripped/shattered gears. Also looking at fitting a reversing switch, which wires are cut into? Am looking for the belt size and diameters of the pulleys used, searched Google, plenty of designs and details, but no pulley sizes. Can't work out how to get the speeds versus diameters, using the same size belt. Pulleys will be about 19 mm and 80 mm for low speed, looking to get around 1500 and 2800 RPM max, motor is variable speed. If someone could work this out for me, I would be really appreciative.
YES I FAILED MATHS at school .
KrynLast edited by KBs PensNmore; 23rd Jan 2015 at 01:20 PM. Reason: More details
23rd Jan 2015, 01:46 PM #2
Kryn, my first mill was an X2 and I always intended to convert it to belt drive, but I got sidetracked and sucked in to buying a DM45
However I did collect a lot of info on the various belt drives, one of which I have attached as it gives some sizes you are after.
I am happy to stick the whole folder of stuff I have collected on a disc and post it to you if you want.
MillBeltMod.pdf
23rd Jan 2015, 02:16 PM #3Golden Member
- home
- 621
I bought one of the Stirling Steel kits that are still sold by the Little Machine Shop in the US. Price has certainly gone up since I bought mine.
Another option is this one by Hoss. Plans available.
Check out all the other mods he made to his X2
I could measure the bits on my belt drive if you want to go DIY.
23rd Jan 2015, 02:20 PM #4Most Valued Member
- 5,945
Thanks for that Big Shed, would appreciate the disc . Please let me know costs and acc. details so I can do an EFT to cover costs. I looked at that site, interesting reading.
I probably do a WIP with details, so that others can do it also, if there are requests to do so. It's a beggar having to wait for parts, only a couple of days longer from the US than Qld.
23rd Jan 2015, 02:25 PM #5Most Valued Member
- 5,945
23rd Jan 2015, 03:24 PM #6
23rd Jan 2015, 03:39 PM #7Senior Member
- Oct 2009
- Upwey VIC
- 186
Kryn.
Attached spreadsheet with pulley sizes that can be changed to suit whatever centre distance between pulleys on the X2 you like.
X2 Mill Pulley Sizes.xlsx
I will find the link to my X2 belt conversion and post it later.
Andrew.
23rd Jan 2015, 03:57 PM #8Senior Member
- Oct 2009
- Upwey VIC
- 186
Kryn,
Posts with pictures for my X2 belt drive conversion.
http://www.woodworkforums.com/showth...99#post1611899
http://www.woodworkforums.com/showth...00#post1621200
http://www.woodworkforums.com/showth...86#post1622786
Edit:
Please note that these 3 posts have been merged in to their own thread here:
http://www.woodworkforums.com/showthread.php?t=191914
Andrew.Last edited by Big Shed; 23rd Jan 2015 at 07:04 PM. Reason: Posts merged in to new thread
23rd Jan 2015, 05:26 PM #9Philomath in training
- 6,542
This is about the X3 but may offer some hints -
http://www.arceurotrade.co.uk/projec...3cncIndex.html
23rd Jan 2015, 06:35 PM #10Most Valued Member
- 5,945
Thanks everyone for the heaps of information, very useful. Thanks Andrew for the spreadsheet and post on your conversion. I looked in the search area but nothing much came up, obviously I didn't look hard enough.
Thanks once again
