Results 1 to 12 of 12
    Jun 2012
    boston
    43
    Default Band saw Cutting a Car in Half
    Just saw this today. What's the size of this band saw ?
    http://sawblade.tv/video/curiosity-s...-subaru-car-2/
    near Rockhampton
    6,218
    Bit gimmicky to me.
    Cutting 1mm sheet steel is not much to spruik about...
    Now if they had have sectioned the engine lengthways...
    Now this is cutting http://www.theatlantic.com/technolog...-pieces/59656/
    Jan 2007
    Katoomba NSW
    209
    Quote Originally Posted by bosox View Post
    J What's the size of this band saw ?
    60 inch. And it would have been more impressive if they cut it long ways.
    Built: a Bench,a Desk,an Archery Display,
    Those were the droids I was looking for.
    Apr 2010
    Rural Victoria
    358
    When I was a youngster I was most impressed with my brother's ashtray that he made by cutting through a piston on the axis of the gudgeon.
    Years later.... meh....
    Jun 2012
    boston
    43
    Bit gimmicky to me.
    Wow! That's a jaw dropper. How did they sawed it in half? What kind of band saw that can do it.
    Jun 2012
    boston
    43
    Quote Originally Posted by NCArcher View Post
    Thanks for the info. Yea, I agree with you. I wish they'll do something more massive cutting like .rc. posted/ .
    Oct 2004
    Southern Highlands NSW
    1,898
    I knew someone who reckoned he often cut cars up using a woodworking hand held circular saw. Possibly a little dangerous?
    Something I tried is cutting sheet steel with a circular saw, with the blade mounted backwards (not a tipped blade). This cuts by friction, and produces less of a burred edge.
    Jordan
    Nov 2013
    Brisbane
    102
    Quote Originally Posted by nadroj View Post
    Jordan
    I once cut up a car with a jigsaw...
    Mar 2008
    nowra
    1,598
    Diamond Wire It was an amazing operation like all heavy salvage
    Andre
    Jan 2004
    Mackay North Qld
    6,446
    Not impressed at all ..6mm or thereabouts of . It is no test to the capacity of the bandsaw, at all. The harmonics transmitted from the sheet steel might be interesting though.
    If you think about it, the pitch of the saw teeth would be no where suited to the sheet thickness.Ie not a real market for sawing single thickness sheet metal on edge.
    IMHO the clip is an out and out gimmick and does little to demonstrate the capabilities and qualities of the blade.To those who use the larger size bandsaws a lot, it wouldn't provide them a good reason to switch blades
    It sounds like this company may be a new player in the market and are seeking recognition. Was it me ,deaf as a post or did the presenter offers very little in the way of information about the blade specs .its feed rate and feet per minute.
    Saw a bulldozer in half - that WILL impress me.
    EDIT OK ! Sawing a ship in pieces and underwater to boot,is impressive . It is almost like something from a James Bond movie .
    near Rockhampton
    6,218
    Quote Originally Posted by Gammaboy View Post
    I once cut the top off a caravan with a chain.... It involved two trees a tractor and a strong chain... instant flat top trailer
    Jan 2004
    Mackay North Qld
    6,446
    But was it done with Precision and did it take time ?
    I have seen farmers cut down trees with two tractors and a strong chain
