Page 1 of 2 12 LastLast
Results 1 to 15 of 30
    Jan 2014
    Northern Beaches, NSW
    288
    Default Which Taps would you buy?
    Today I snapped my (cheap) M6 tap on my second of 6 holes... Not happy as on a Sunday arvo I couldn't find another quickly to get my job finished...
    So I now need another M6 tap but thought I'd replace my other cheap ones with better quality ones whilst I'm at it.
    So, what taps would you buy? Standard plug and taper or the spiral ones? Chinese or Australian/English/USA?
    Also, should I look at second hand ones or new only?
    I'm probably looking for M3 - M12.
    Any suggestions, thoughts or recommendations please.
    I don't want to spend a fortune as I don't use them all that often, but the cheap Chinese ones I have at the moment are rubbish.
    Thx
    Jon
    Thx
    Jon
    Sep 2008
    Riddells Creek, Vic.
    831
    You get what you pay for with taps and dies Jon. The easiest to get quality taps would probably be Sutton or Goliath, these will be made from HSS with ground and relieved threads.
    Lex.
    Ueee's Avatar
    Dec 2011
    Canberra
    39
    4,515
    Hi John,
    It depends on how much you want to spend, and what you call cheap......
    My local shop sells sets of Guhring gun nose taps, M3-M12 plus correct drill sizes for about $120. I consider this to be good value but it may be more than you want to pay. I just bought a 10 piece set of Stock? brand (German) Gun and spiral M3-M8 for $49 off ebay. You just need to keep looking to find bargains on ebay.
    I would only buy spiral or gun nose, spiral for blind holes and gun for through holes.
    I like Dormers as they are what i can get locally and i have NEVER broken one, be it M3 or M16.
    Here is an M6 on ebay out of the UK http://www.ebay.com.au/itm/DORMER-E5...item4aa030fdd5 the seller has heaps of other dormer taps so you may be able to get a few with combined postage.
    Ew
    Aug 2012
    Australia
    645
    Wow! That is cheap for that sort of quality. If I had not spent my life savings buying each of Goliaths 3 tap sets in metric I would be getting the details..
    I now generally buy HSS Dormer and Goliath taps as they are easiest to find on Ebay UK at a reasonable price (1/3 rrp).. I have broken too many tungsten/carbon steel taps to bother these days.
    Jan 2014
    288
    Thanks Ew & Lex.
    Can I ask what Gun Bose taps are? I've only ever ears of plug, taper & spiral before.
    Thx
    Jon
    jatt's Avatar
    jatt is offline Always within 10 paces from nearest stubby holder
    Bendigo
    51
    760
    I have been getting good service from my Bahco tap and die set I picked up from the Big B (up to 12 mm metric) for about $60 That was at least a couple of years ago. They havent done hundreds of holes, but even so I have been using em on some old school MS with only one die thats lost a couple of teeth. As I kill em, will just replace respective units with better stuff.
    For a relatively cheap set I'm pretty happy with em. I try and be gentle with em, knowing they arent exactly top of the range stuff.
    Coupled with some good Sutton finishing taps for blind holes in the 4 sizes I use the most..
    Already have a set of 0.1 mm increment drill bits (cheapy Chinese, from memory less that $100) for the final hole sizing prior to tapping. So no need to purchase correct size for every tap.
    Sutton, P&N & Dormer seem to be the easiest for me to get my mitts on. Happily use any of em when looking for a better quality tap.
    Frisky wife, happy life. ​Then I woke up. Oh well it was fun while it lasted.
    From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
    Mar 2014
    South of Adelaide
    1,225
    I would buy good brand name ones eg. Sutton, Dormer, Goliath. The only cheap Chinese ones I've ever used were Frost ones, they were terrible couldn't even tap a hole with them. I only buy quality ones now, they are sharper which means less force to cut a the thread = less breakage. watch out buying 2nd hand, i recently bought a 1 1/2 unc tap on ebay, looked good in the photo. when i got it there was 2 chipped threads on the other side, so be weary if the aren't photos of the whole tap.
    Aug 2012
    Australia
    645
    Tell me about it. I needed a M12 x 1.75 die as my lathe will not do 1.75. All I had was a set of Frost that I purchased a long time ago. Long and the short of it is I ordered a Goliath M12 x 1.75 today. The Frost was not even attempting to cut the thread. The sad thing is that Frost is owned by Sutton. I guess it has its place.
    Oct 2007
    Sydney
    3,112
    Some of the "Australian" brands aren't what they used to be, I don't buy them anymore.
    I use HTD taps for hand tapping, and spiral flute taps for machine tapping. I'm not sure what the price of HTD taps is as I buy them overseas, but think they may be good value even though Japanese made. I've found them to be excellent quality anyway.
    I'll differ in my opinion from Ewan and suggest you buy your taps as standard set of 3 hand taps. Don't get me wrong, the spirals etc are very good, and as I suggested above, I use them too, but often a taper tap can be used unguided without any concerns about running straight. Often taps will break when they run slightly off, hence it's a good idea to guide them, but I will often run a taper tap without any form of guide without any issues; the taper will guide the tap quite well. The only downside is you need to run the tap almost all the way through which a slightly longer process, but faster than changing taps or even setting up a tap follower.
    There's two things I always feel it's not worth scrimping on; measuring tools and taps/dies. It's just not worth the angst having either one unreliable will invariably bring.
    Aug 2012
    Australia
    645
    Quote Originally Posted by Pete F View Post
    I noticed that now P&N drills are now made in China. That shocked me a lot given they are under Sutton. Sutton have Frost as their cheap brand, but now P&N?
    I will have to check out HTD taps. I have just purchased my first few YG taps. They are made in South Korea. I found them via people on PM saying they are a good replacement for Yamawa, which are excellent, but apparently now hard to get.
    I also really like spirals. But ended up buying 3 tap sets from Goliath & Dormer. I had a spiral literally explode on me when it was slightly off center in my tapping head. It was Europa brand. Never again. No more Europa (I have broken a few of their "quality" taps), but also not using spirals as much as I used to. Only where I need to tap lots of holes on the mill or tap blind holes to get the extra depth.
    Ueee's Avatar
    Dec 2011
    Canberra
    39
    4,515
    I agree that it is easier to line up a taper tap by hand. However i generally drill and then start the tap and the drill press so alignment is not a problem, and if you cannot do this a tap guide is a good idea.
    All the straight taps i have broken though i have done so backing off the cut and having it jamb. Not a problem with spiral/gun taps as they should not be backed off.
    The gun taps are stronger than the spiral taps and will take more before letting go. It is worth noting that the theoretical tapping size is not the drill size that should be used. You really should have some clearance, 75-80% thread depth is good. Commercial tapping is generally done at 65%.
    A gun nose or spiral point "shoots" the chips out in front of it, hence why it is best for through holes.
    For some reason searching google images for Gun nose tap i got this beauty.....
    Ew
    Edit, here is a specials page for the Guhring sets. Its not current though. http://www.guhring.com.au/monthly-sp...September2013/
    Oct 2007
    Sydney
    3,112
    Drilling and then using a tap follower or other method of guiding the tap immediately is fine for one-offs, but a total PIA when multiple holes are being drilled and tapped and it would take forever. I often come across situations where a hole needs to be tapped that won't fit under a drill press. I have a few tap guides that can be used by hand, including a simple block with appropriate size clearance holes I made up, but there are times when even they can't be used for one reason or another.
    I agree, backing off is another classic time taps will break.
    The amount of acceptable thread engagement will depend on the application, the "recommended" drill size assumes full engagement. I'll often go oversize with my drill size if it's not a critical tapped hole, having said that have never had an issue since throwing all my cheap taps in a bid with a hearty "good riddance" to see them on their way. I guess maybe 50% of the time recommended hole size and the other half I'll go larger.
    Each tap style has plusses and minuses, and there's no perfect solution where one size fits all. Well, short of buying one of each style of tap in every size I guess! What I use is my opinion for what it's worth.
    Ueee's Avatar
    Dec 2011
    Canberra
    39
    4,515
    I find with a keyless chuck you can swap pretty darn quick, center drill, tapping drill, back gear, tap and then finish by hand. Next.....
    A taping chuck would make it so much easier but as i said above on most tapping chucks it says "recommended thread depth 65%"
    Your not wrong there! If only funds where unlimited.....
    Ew
    Oct 2008
    N.W.Tasmania
    1,407
    Quote Originally Posted by ventureoverland View Post
    Thanks Ew & Lex.
    Thx
    Jon
    Hi Jon, Here is a Goliath Product price list link which will show and tell you more about the different sorts of taps and dies available than you probably want to know. It variously comes up as a 2003, 2006 and also a 2014 price list, but it has lots of good info and the prices are not exactly mouthwatering, more like eye watering, but armed with the info within, you can chase bargains on eBay like the one Ewan got. If the situation is a bit urgent and you can't afford to wait, you might be able to just get the ones you need for now, and keep an eye out for a bargain for the others that you'd also like to get, and pick them up as you can. Good luck,
    Rob.
    http://www.goliath.com.au/pricelist%202003.htm
  15. #15
    Jun 2013
    Tasmania
    257
    Some good info here. Like many, I am due to upgrade to better taps.
    What I notice, particularly in the cheap sets is that the handles also are absolutely rubbish.
    So does anyone have any recommendations on brands of good handles to drive your taps?
  1. taps and dies
    By doug3030 in forum METALWORK GENERAL
    Last Post: 10th Mar 2012, 01:44 PM
  2. BA taps
    Last Post: 23rd Sep 2011, 05:16 PM
  3. Brass Taps
    By bob colles in forum METALWORK GENERAL
    Last Post: 31st Aug 2011, 01:10 AM
  4. Brass 26 TPI Taps
    Last Post: 20th May 2011, 12:57 AM
