Results 1 to 5 of 5
Thread: Top Hat Installation Info
26th May 2014, 03:20 PM #1New Member
- Tin Can Bay Qld
- 3
Hi Guys
I am a member of woodworkforums to mostly watch and learn on the wooden boat side of things but have ventured to the "dark side" of metalwork to ask for some advice.
I am building a freestanding 6m x5m Dutch Gable steel carport which I bought as a kit from a Gold Coast supplier whose advertising blurb said would include a full set of building instructions when they really meant here is a meagre set of engineering drawings and good luck. Nevertheless I completed the steel frame by myself to a pretty good standard and, as was always my intention, I contacted a professional roofer to have him hang the roof sheets and trim to get the best possible finish.
Long story short is that I can save some more money if I install the metal top hats (Topspan61) myself. My immediate problems are positioning (which I can probably work out from the plans even though no dimensions are given) and cutting mitres on the battens where the hips meet.
Is it just the same as woodwork - cut the 45 mitre and secure both ends independantly (two perpendicular sds) on the steel purlin ?
bagman
26th May 2014, 03:59 PM #2
...note the hip battens, usually 150mm centre of hip to outside batten.
Just substitute metal for the timber ones
26th May 2014, 04:31 PM #3New Member
- Tin Can Bay Qld
- 3
Hi Wolften
I should have included this plan to show what I am dealing with - the frame is bracketed so that a diagonal purlin sits at each hip and the top hat mitres over these purlins.
It is a nifty design.
bagmanIMG.pdf
26th May 2014, 07:55 PM #4Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,039
27th May 2014, 10:29 AM #5New Member
- Tin Can Bay Qld
- 3
Thanks Bob - sounds like good advice to me.
