Results 1 to 4 of 4
Thread: Information on Sheraton
24th May 2014, 11:28 PM #1Member
- Jul 2009
- perth
- 67
Hi All
Im procrastinating over a lathe acquisition
I would like to get a few viewpoints on the Sheraton challenger if anyone out there owns one
what are its specs , eg swing , dist between centre , spindle bore and speed range
And a rough ballpark value for one in pretty good condition
thanks in advance
Tom.
24th May 2014, 11:50 PM #2Pink 10EE owner
- 6,218
Specs are 14" swing, 28 or 36" between centres, 1 11/16" spindle bore weight around 850kg.. Spindle nose will depend on age... I have seen some that use the A series spindle noses, others that use the D series... The A series is bolt on, the D series uses camlocking pins..
Quality wise when new I would have said they were a bit better then say an equivalent colchester lathe..
The Sheraton line of lathes seemed to have been a slightly altered version of the Le Blond, Regal line of lathe. Le Blond is/was a well regarded US manufacturer of lathes..Gold, the colour of choice for the discerning person.
25th May 2014, 01:02 AM #3
RC nailed it, the Sheraton are copies of the later LeBlond Regals. I'm not sure if they copied the servo shift, i have never seen one with, but if the one your looking at does AVOID IT.
http://www.lathes.co.uk/regal/page5.html
25th May 2014, 09:26 PM #4Member
- queensland
- 81
I leaned against a Sheraton Defiance lathe for 6 months in the late 80's also did the occasional bit of work with it too.
Great lathe; accurate, reliable, and just pleasant to use. Preferred it over a Colchester.
About 5 year ago I was in Hare and Forbes and they had about a dozen of these from TAFE and were asking $3600 each if memory serves me correct. They'd all been sold by then otherwise I'd have bought one. It is on my list of machines I'd like to buy if I can find a good one local to me.
Garry
Sheraton CUB
By morrisman in forum METALWORK GENERALReplies: 0Last Post: 14th Dec 2011, 09:31 PM -
run out on Sheraton model A
By morrisman in forum THE HERCUS AREAReplies: 14Last Post: 21st May 2011, 01:04 PM -
sheraton A steady?
By danielhobby in forum THE HERCUS AREAReplies: 3Last Post: 13th May 2010, 01:49 PM -
Sheraton Lathe information?
By Greg Q in forum METALWORK GENERALReplies: 18Last Post: 25th Jun 2008, 09:36 PM -
Sheraton SSS lathes
By Aussie redback in forum METALWORK GENERALReplies: 5Last Post: 5th Jul 2005, 02:41 PM
