Results 1 to 15 of 19
Thread: VFD Remote Cable
13th May 2014, 09:54 AM #1
VFD Remote Cable
I have been trying to find a longer cable for the control panel of my Huanyang VFD. I have the VFD mounted inside an enclosure and the control panel stuck to the front of the enclosure. I need enough length to allow the lid to swing back. About 400mm. It is a 10 pin IDC connector at both ends.
I have had very little success. Can anyone point me to a source.
13th May 2014, 10:02 AM #2Most Valued Member
Pretty sure Rs has the cable and the plugs. I'll dig it out shortly when I'm on pc.
13th May 2014, 10:38 AM #3Member: Blue and white apron brigade
- 7,182
They are quite easy to make up yourself and as ST says RS, and Altronics and Jaycar also have the parts.
And if you need help
http://www.jaycar.com.au/images_uploaded/IDCconnJ.pdf
13th May 2014, 10:48 AM #4Most Valued Member
oops. while RS does have them. I found my paper and Bobs right, it was Altronics I was thinking of.
http://www.altronics.com.au/p/p5310-...unting-socket/
http://www.altronics.com.au/p/w2510-...-ribbon-cable/
and if you want to add a speed pot
http://www.altronics.com.au/p/r1976-...short-pcb-pot/
13th May 2014, 11:02 AM #5
Thanks guys. I did a search on Jaycar for "10 pin IDC". This did not provide what I wanted. I noticed a picture in the "Related products" which produced "10 Way IDC Line Socket".
I will check at a Jaycar dealer this afternoon when I go into town for an appointment. If no luck there I will order the bits online.
13th May 2014, 11:08 AM #6
A further check showed a lack of 10 way ribbon cable. Sigh. I guess that you just buy 16 way and rip off what is not needed.
13th May 2014, 11:17 AM #7Most Valued Member
They(Jaycar) dont have the pot you need either*(if you want to mount it on the board)
*or at least I cant find it
13th May 2014, 11:40 AM #8
It is probably a matter of using a different search term!
I will post an update in my lathe thread shortly about the layout. I am using an external pot. I had a look at my meagre store of electronic components. I found about 3 pots. After a bit of research, I found that I had exactly the right pot as quoted in the manual. 100k Log. It has probably been bouncing around in boxes for 20yrs. I will buy another one this afternoon. I would hate to find it does not work. The pot is mounted on the door of the main enclosure, just below the remote. The switches (For, Rev, Stop, EStop) are mounted on elec enclosures, attached to the side of the main enclosure. I am using recycled stuff where possible at the moment. I am still waiting on the switches to arrive from Hongkong. Another week or 2.
The remote will only be used for adjusting settings.
I have read the pdf and have had a few things clarified. Like the 1.27mm and 2.5mm spacing. I presume this is the right spacing although I have seen mention of 2mm spacing.
I have probably thrown out 10 of these cables over the years from old computers.
13th May 2014, 12:01 PM #9Most Valued Member
Oh they have plenty of pots if you dont want to mount it to the remote pcb board. So you're good there.(the have hoz but not vert)
100k? Though I have my doubts it will matter much*, are you sure it isnt 10k?
*but then I wouldnt knowLast edited by Stustoys; 13th May 2014 at 12:04 PM. Reason: just everything lol
13th May 2014, 12:03 PM #10
Yes I wondered about the 100K too, mine uses 10K as well.
13th May 2014, 12:30 PM #11Oh they have plenty of pots if you dont want to mount it to the remote pcb board. So you're good there.(the have hoz but not vert)(the have hoz but not vert)
Ok, maybe I made a mistake with the 100k pot, but I will buy a new one this afternoon. All good. Thanks for pointing that out. Not sure where the 100k came from.
A quick check of the pot and printed manual tells me that I was wrong. I will buy a 10k pot log this afternoon. I hope I will also get the bits for a longer remote cable.
13th May 2014, 01:10 PM #12Most Valued Member
Yes. Jaycar have plenty of 10k pots that will do the job if you dont want to mount the pot in the blank spot in the VSD panel.
like this
http://www.woodworkforums.com/showthread.php?t=147356
13th May 2014, 02:04 PM #13
13th May 2014, 03:22 PM #14
Jaycar don't carry the right pot for the Huanyang keypads. They can order them for you though....
May have been a typo, but Dean, you said "I will buy a 10k pot log this afternoon" - you need a LINEAR pot (lin not log). Just in case ....Cheers, Joe
13th May 2014, 04:38 PM #15
Hmmm. Plucked it out of my memory. As I stayed home sick today with reason, I am not about to trust my memory. Thanks for mentioning that Joe. What I did not mention is the messing around I went to in determining the breed of the one I have (100k) New and old codes the same for each. "A" from memory. "A" in old code is the opposite type to "A" in the new code. It turned out I had a "B" which had a much clearer provenance. Anyway, I am going to buy both. I will be leaving in a few minutes, so I am glad you posted, and I checked.
