Results 91 to 105 of 147
21st Apr 2014, 03:24 PM #91.
- 6,459
A HUGE Thank you to Bob L
None of this would have been possible if it wasn't for Bob's generosity, expertise and patience.
Bob T.
21st Apr 2014, 03:32 PM #92Most Valued Member
Oh, It was as easy as that then
Great work Bobs!
21st Apr 2014, 03:38 PM #93.
- 6,459
To be honest Stu, the turning was more nerve racking than dealing with the piddly wire. There wasn't a lot to hold on to so I was constantly fearful of peeling the job out of the chuck. Loctite was my friend, again.
Bob.
21st Apr 2014, 03:53 PM #94Most Valued Member
Yes, this one would have been a little hairy.
http://www.woodworkforums.com/attach...6&d=1398053992
Makes my latest job look even more boring then it was already lol
21st Apr 2014, 04:53 PM #95
Nice work BobL and BobT, in the world of star/delta conversions, that one has to be a degree of difficulty 10. Nice to see it all came together.
21st Apr 2014, 04:56 PM #96Member: Blue and white apron brigade
What a sweet little thing it is!
Great machining/turning Bob.
Hows the switching gear going?
21st Apr 2014, 07:19 PM #97
Great to see it running Bob. I got one running today too.
21st Apr 2014, 09:20 PM #98.
- 6,459
Thought about the switching a bit then got consumed by the turning Bob.
I will use the grinder's switches to switch the VFDs remotely via the contactors. Switching the VFDs' supply power really needs to be via a pair of illuminated switches in a visible position. The original power on-off switch is tucked away behind the rear of the base.
Hey Dean,
When I turned the VFD on, the motor ticked over at about 15 rpm. I thought FM! Then I realised the VDF was running on 5 Hertz. That was the first time I had ever wired it up, it has sat new and unused in its box for about 3 years. I had bought it for the 13's coolant pump.
Certainly was a great feeling to see and hardly hear it running at 50Hz.
Bob.
21st Apr 2014, 10:29 PM #99Golden Member
- May 2003
- 526
Well done BT and Mr Bob. To me that was a radical conversion and great outcome.
Rod
22nd Apr 2014, 11:44 AM #100Most Valued Member
- 4,258
And here I was thinking it was destined for the scrap heap
well done guys...and that is also for those of you who also gave valuable and encouraging info etc etc
22nd Apr 2014, 08:52 PM #101
The instructions that came with mine say that it should not be left unused for any length of time. It should be powered up every so often. After reading this I was glad when it was still working. It was sitting in my metalworking cabinet for about 2 years.
I fully understand your feelings, although I did not have the dramas that you did with the motor.
23rd Apr 2014, 08:57 AM #102Most Valued Member
- 4,258
23rd Apr 2014, 12:38 PM #103Member: Blue and white apron brigade
Sorry, back to crimpers, I was in Altronics this morning buying a couple of relays so I has a look at their crimpers
At the last moment I weakened and got sucked in by the magnets and bought the Deluxe Magnetic 7 piece jaw set
http://www.altronics.com.au/index.as...=item&id=T2177
Yes they are somewhat overpriced but I've done it now and they should last me and my son for many years to come and hopefully save me the odd trip to where I used to work to borrow theirs.
23rd Apr 2014, 02:23 PM #104Most Valued Member
Hi Bob,
I wouldn't be to worried, you did better then me, the above lug shop is closed Easter Tuesday! In 6 months you'll have forgotten the price.... so they tell me.
Mine crimpers have a "quick release" as well. Depending on what you do it could get painful real fast playing around with screws. One thing that did cross my mind with the screw ones, perhaps the hole could be turned into a slot so you only need give the screw half a turn?
Sometimes it would be nice to have two handles
23rd Apr 2014, 03:23 PM #105Member: Blue and white apron brigade
Looking to swap a 2Hp single phase motor for 1.5 or 2Hp 3-phase motor
By jhovel in forum METALWORK GENERALReplies: 7Last Post: 10th Mar 2014, 07:26 PM
