Results 16 to 26 of 26
31st Mar 2014, 10:23 PM #16
Thanks Karl,
Just like you and Peter i have a Comet 3 so i will look into a reg and tips. I see some regs on ebay, http://www.ebay.com.au/itm/LPG-REGUL...item4acf90d617
Where have you sourced the tips from?
1st Apr 2014, 05:59 AM #17Most Valued Member
- Sep 2011
- Ballarat
- 3,103
I have been using OXY/LPG since 1991 and haven't found it restricting at all really (if you discount fusion welding).
As has been said the only real difference is the LPG regulator, hoses and tips.
I used to go through about 7 bottles of oxy to one barbie bottle of gas, which could be got on any day of the week at swap and go.
I think the oxy was an 'E' size.
Here is a pic of the trailer I fitted out for onsite work to gauge the oxy size.
Phil
1st Apr 2014, 08:50 AM #18Most Valued Member
- Australia east coast
- 2,713
Aside from fusion welding (and I have a TIG) the main downside I've found to using LPG instead of acetylene is the lower heat when wanting to bend thick metal. You can bring the temperature up a lot quicker with oxy-acet than you can with oxy-LPG and that keeps the HAZ a fair bit smaller, plus the whole process is faster.
But for the price difference it's a pretty easy choice unless you really need the extra heat capacity of acetylene.
I haven't done any brazing for years and seeing as I got given a 15kg spool of silicon bronze MIG wire, may never do any again (not that I've tried it out, mind).
PDW
1st Apr 2014, 11:29 AM #19Most Valued Member
Thanks guys.
So let me get this straight. All I need to aquire to get into oxy LPG is to buy something like this:
http://www.ebay.com.au/itm/CIGWELD-W...item5aed86dc59
And then buy an oxy bottle and use the BBQ gas and I'm good to go?
1st Apr 2014, 12:22 PM #20Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Hi Simon,
Yep.
Phil
3rd Apr 2014, 07:29 PM #21danielson
- Dec 2009
- broadford
- 63
- 213
as an add to this post,try BMS in Campbellfield for a quote.They do oxy profile cutting and also water jet cutting.Alliance laser in Campbellfield can cut 16mm no probs and have a 12.00mtr x1.500mtr table. cheers Danny.
3rd Apr 2014, 10:45 PM #22
Thanks for all your contributions!
Our 1/2ton 20mm steel plate is now cut up and back in my shed
It was done by flame cutting on a rail mounted electric straightline oxy cutter. All up 9.3m cut at $150 for labour and gas. VERY clean cuts!Cheers, Joe
3rd Apr 2014, 10:51 PM #23future machinist
- Mar 2008
- nowra
- 1,598
I have two of those electric oxy torchs that I got from Castlemain foundry no track though
Andre
3rd Apr 2014, 11:32 PM #241915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
4th Apr 2014, 01:03 AM #25
4th Apr 2014, 11:06 AM #26Most Valued Member
Ha!
Sheet metal folders... with attitude!
1250mm wide and hopefully 1.5mm (or more) capacity. I've been dicking about for a few months, slowly getting mine done and batteling to procure the required materials. Joe contacted me about 4 weeks ago saying he also wanted to build one. I think I have achieved more in 4 weeks than the previous 4 months! It's much easier to get the size plate (16mm, 20mm & 25mm plate) we need for two people and halving the cost each than going it alone! If you don't shop around and take advantage of bargains (in complete sheets) then the price of the steel gets right up there and soons becomes an expensive way to obtain a sheet folder!
Also I have been able to draw on Joes experience/knowledge since he has experience in using folders in the past. It's been great to be able to bounce ideas of someone who has used one.
So far it's working out quite well I must say.
Plasma cutting compared to oxy??
By Mathuranatha in forum WELDINGReplies: 6Last Post: 19th Jun 2009, 10:09 AM -
Milling, Laser Cutting or Waterjet a large object
By mangrovejack in forum METALWORK GENERALReplies: 5Last Post: 29th May 2009, 11:51 PM -
CNC plasma cutting
By Andy Mac in forum METALWORK GENERALReplies: 7Last Post: 23rd May 2008, 12:01 AM
