Results 1 to 5 of 5
Thread: OLD BURNERD CHUCK
14th Mar 2014, 12:37 PM #1
OLD BURNERD CHUCK
Hi
My Sheraton 9 from the 1950's 60's came with its original 3 burnerd chucks..The teachers at the tech obviously didnt change chucks that often.. the two 5" 4 jaw chucks were not worn, but the little 4" 3 jaw was not that good . I just had a close look at the 3 jaw. the flats on the jaws that clamp the work, have Vgrooves worn into them.... I used a diamond plate and re profiled the flats backto flat ............hope it works OK i also gave the chuck a polish with a coarse then fine file and emery cloth.. it looks new again i plan to use this chuck on my Hall dividing head which is almost finished
14th Mar 2014, 01:44 PM #2Most Valued Member
- Jun 2012
- SA
- 1,649
14th Mar 2014, 07:35 PM #3
14th Mar 2014, 07:38 PM #4Diamond Member
- Sydney, NSW
- 1,249
How was making the Div head? I've just ordered the Dividing head book from The Book Depository. I hope its a good book. Your DH looks good.
Ben.
14th Mar 2014, 08:53 PM #5
head
Hi Ben
It is pretty straightforward . I altered the dimensions slightly from his drawings as I only had crap steel to play with and I milled it down to suit my needs .
It is mostly made from black hot rolled junk steel but it seems to have turned out reasonably well. I tried to make the spindle diam. and the bearings bore as close a tolerance as I could and it turned out good , it only needs the slightest pressure from the locking arm to lock the spindle in place . The gears are from my Sheraton , they have a 5/16" bore . I will cut the spindle nose with a 1 1/2"- 8 thread so I can use the chucks from the Sheraton lathe . This DH will be a useful accessory I feel . Mike
Pratt Burnerd opening screws
By ausdag in forum THE HERCUS AREAReplies: 14Last Post: 9th Jul 2011, 10:13 AM -
Wanted jaws for Burnerd 4" 3 jaw chuck.
By Com_VC in forum THE HERCUS AREAReplies: 21Last Post: 31st Mar 2011, 11:51 AM
