Results 226 to 226 of 226
Thread: VSD power tests
29th Sep 2018, 09:35 PM #226
Hi Bob,
I had a quick read of your referred to post and your description of the dimmer and bridge rectifier controller.
Using a high voltage electrolytic capacitor on the output of the bridge would have given you a more stable, measurable, DC level, but as you pointed out the DC motor doesn't care at all.
It is one technique that is used in DC and universal motor controllers to replace two of the rectifiers in the bridge with thyristors, so that the DC output from the bridge rectifier can be varied.Best Regards:
Welder tests
By Grahame Collins in forum WELDINGReplies: 3Last Post: 28th May 2008, 11:56 PM
