Results 1 to 15 of 17
22nd Jan 2014, 07:55 PM #1Philomath in training
Only in an imperfect world would we be without vice.
To my annoyance I managed to blunt a cutter on the weekend when I set it to clear the fixed side of my vice and it bottomed on the moving jaw (alright - the clearance was less than 0.25mm, but the jaw had still moved!)
While a Kurt or Glacern would be nice, the cost plus freight is too high for my liking.
Vertex do an angle lock style vice (model VA-4) which looks solid enough
https://www.machineryhouse.com.au/V304#
Anyone got one/ had experience with one?
22nd Jan 2014, 08:39 PM #2
You probably know what i'm going to say already.....
Of all the things i have bought in the last few years (except machines of course) Gregs Glacern would be on the top of my list as the best thing i have bought, no questions asked. It is precise, strong, well made. It is a joy to be able to go to the mill and clamp something in the vise without having to think twice about how well it is held and how well aligned it is. I think it is under 20lbs without the base? They really are worth every penny IMHO.
22nd Jan 2014, 09:42 PM #3future machinist
- Mar 2008
- nowra
- 1,598
Glacern say the shipping weight is 33lbs
for a 4 inch
http://www.woodworkforums.com/f65/im...l-vise-128172/BETTER TO HAVE TOOLS YOU DON'T NEED THAN TO NEED TOOLS YOU DON'T HAVE
Andre
22nd Jan 2014, 09:53 PM #4Golden Member
- Jun 2004
- Kyabram. Vic
- 632
Well; I am a mere peasant and have to suffer with a 6" Vertex angloc.
As yet I have no complaints. Muuuch better than the one that came with the "soggy noodle".
I have not yet used the 8" dovetail slide with gib strip adjustment vice that came with the Rossi. I have since seen them advertised new and were about the price the mill cost me.
I would hope that it is as good as the price.
Ken
22nd Jan 2014, 09:55 PM #5
Hi Michael,
I'm another one of the poor cousins who has to suffer in silence looking at others with their Kurts and Glacerns.... my Vertex 150mm is just fine, no complaints and no problems. I think they are excellent value.
22nd Jan 2014, 10:10 PM #6Most Valued Member
Hi Michael,
Sorry to hear about your cutter. Last year for my birthday I bought a Vertex K type vice. It's OK but I find when the alignment is crucial, the jaws lift a bit on clamping. This is very noticeable when using parallels under the workpiece as one is usually loose when the jaws are tightened. A soft mallet usually fixes the problem but I should have bought an anglock instead.
While I'm not overly demanding on the quality of my tools (I have a lot of Chinese stuff and find it OK) I found the vertex K type vice a bit disappointing, mainly in the finish. Especially compared to the Vertex 8" RT which by comparison seems better finished IMO.
Couldn't afford or justify a real Kurt.
22nd Jan 2014, 10:28 PM #7Golden Member
- Aug 2012
- Australia
- 645
Michael, I own two Vertex anglock VA-5 vices. They are rock solid. I liked them so much I got myself a Vertex K-type for little jobs and a 200mm Vertex rotary table. Vertex are much better quality than I expected. For the price one can't go wrong.
PS: There is a reason Glacern source their vices from Vertex..
22nd Jan 2014, 11:04 PM #8Chief Swarf Maker
- Aug 2013
- 132
I have the 6" anglock from vertex. Its a good bit of kit, and good value. I am amazed how much holding force you can get on such a small area with it. Ive only had a pull out once, which i rectified by going to a lower parallel. I was taking some pretty big cuts on round bar being held by ~4mm when it pulled out.
I do find occasionally that one parallel will be tighter than the other, but that may be operator fault. I did find its limit of opening at 147mm the other day, annoying when i wanted to hold 151mm :S
Ive worked out how to get it to hold upto approx 300mm but im not too keen on drilling holes in it just yet.
Hafco had another 6" anglock which had about 10mm more opening and (i think) taller jaws, i went in to buy that one but the vertex was much better finished so i bought that instead. Ill be going back for another one shortly. Cant wait to have 2, or even 3 of them lined up on the big mill for working multiple parts at once.
22nd Jan 2014, 11:12 PM #9
On the Glacern you can move the jaw plates to the outside of the Jaws, giving you about 300mm opening. Can you not do this with the Vertex's?
I'll second what Ken said, the vices that come with the soggy noodle's are next to useless as they are.
22nd Jan 2014, 11:23 PM #10Chief Swarf Maker
- Aug 2013
- 132
Not yet. Ill have to make new, taller jaws to sit outside and come over the top. Would also have to take the normal jaws out, which im loathe to do. Is any accuracy lost or realignment needed after doing this?
23rd Jan 2014, 12:05 AM #11
Not with the Glacern. The removable jaws should be ground parallel and the fixed and moving jaw should be dead square and parallel.
Michael,
There is always the possibility of myself or Josh/Ray grinding a Vertex vice for you to bring the specs up. Be even better to do a batch of them......
23rd Jan 2014, 07:13 AM #12Philomath in training
Thanks Ewan - it's a worthwhile idea but at the moment my concern is mainly about jaw lift. I was pleasantly surprised to find that after replacing the bearings in the head I was getting parallel to 0.05 without trying. That in itself is a big improvement. At this stage I would look at getting a vice and using it a bit before doing any tune up work.
23rd Jan 2014, 07:31 AM #13Golden Member
- Jun 2004
- Kyabram. Vic
- 632
Ewan,
My vertex angloc already has the threaded mounting holes on the outside of the jaws.
Ken
23rd Jan 2014, 09:52 AM #14Golden Member
- Aug 2012
- Australia
- 645
23rd Jan 2014, 09:51 PM #151915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
Shaper vice and milling vice
By morrisman in forum METALWORK GENERALReplies: 6Last Post: 5th Sep 2012, 12:06 AM
