Results 1 to 8 of 8
3rd Jan 2014, 09:48 PM #1.
- 6,458
Blacking As An Alternative to Bluing
Ray suggested the use of soot from a candle flame as a means of "colouring" an arbor to test its fit so I gave it a whirl this morning. I had been using bearing blue but with poor results either from a poor fit or poor application of the blue. Licking the flame across the metal results in a deposition of soot, the more licks the blacker. I tried three 30 taper arbors, my home made version, one from CTC and a Schaublin.
Mine first. There is contact about two thirds of the way up the taper. I have some ISO 30 collets and their contact surface is about the same, so I won't fiddle with mine any further
The Chinese. It appears that the taper is hollow with contact at the ends only.
And the Swiss. Pretty much uniform contact.
I found this a lot easier than mucking around with blue. Thank you Ray.
Bob.
3rd Jan 2014, 10:24 PM #2Philomath in training
- 6,542
Bob, are you going to do the arbor I sent you with this method? I'm interested to know whether I've gained enough skills to be a Chinese machinist yet.
3rd Jan 2014, 11:55 PM #3Senior Member
- May 2010
- rural s.a.
- 120
Hi Bob, something worth trying is lighting some camphor, easy to get from some moth/silver fish repellant from the local super market. Nice really black deposit.
tinkera
4th Jan 2014, 08:56 AM #4Most Valued Member
- Jun 2012
- SA
- 1,649
Kero wick in a lantern would work well I suspect.
But at least you tried.
4th Jan 2014, 12:18 PM #5Originally Posted by BT
I always associate lamp-blacking with leather aprons and flakey tobacco in tins, cloth caps, and running a lathe wearing a tie. Absolute precision craftsmanship and everything ruled by British Standards.
4th Jan 2014, 01:02 PM #6Most Valued Member
According to the docco I saw Purdey is still much like that* and still use lamp black for final fitting of their actions.
*with the odd CNC here and there
4th Jan 2014, 07:18 PM #7
6th Jan 2014, 08:32 AM #8Most Valued Member
- 4,255
burning masking tape gives off a lot of soot
or you could you use a calcium carbide burner also
My second attempt at steel bluing
By BobL in forum METALWORK GENERALReplies: 20Last Post: 4th Dec 2018, 02:25 PM -
Bluing a tapered shaft
By jack620 in forum METALWORK GENERALReplies: 20Last Post: 9th Apr 2013, 07:02 PM -
Blueing Blacking and Browning Formula Available
By hux in forum METALWORK GENERALReplies: 19Last Post: 17th Apr 2012, 09:46 AM -
Bluing
By bollie7 in forum METALWORK GENERALReplies: 1Last Post: 28th Apr 2009, 10:37 PM -
Metal bluing solution
By ohno in forum METALWORK GENERALReplies: 28Last Post: 16th Dec 2006, 08:00 PM
