Page 1 of 3 123 LastLast
Results 1 to 15 of 43
    Jun 2011
    Adelaide
    27
    248
    Default Need help finding a capacitor for my lathe motor
    Hey guys my lathe recently died on me while machining it has done this before were it would slow down then stop but all i would do was just turn it off then on again and it would work fine all though this time nothing happens not a sound or anything. I took the capacitor out, but some of the info on it has rubbed off and don't have much of a clue what im really looking at hahaha :/ So would some one be able to point me in the right direction i also added a picture of the capacitor. (only assuming that its the capacitor.)
    Cooper
    Apr 2013
    adelaide
    293
    Default Capacitors
    The capacitor has all the information on it you need, the values shown are pretty standard. K.D. Fisher in St Marys, or anybody else that sells capacitors, should be able to help you out. They're only about $20, or $10-$12 bucks on line. You didn't mention how many capacitors the motor has.
    Aug 2010
    Near Bendigo, Victoria, AUS
    72
    3,105
    You are looking for a 16µF (micro farad, sometime written as "MF" or "uF") motor capacitor for 380 or better still 450VAC. The rest of the lettering is not that critical.
    Like these: 16 uf motor capacitor | eBay
    Cheers, Joe
    7,189
    If you turn it on and spin it by hand for a couple of turns does it eventually get up to full speed?
    If it does keep spinning then it is definitely the "start" capacitor, if not then it may or may not be the "run" capacitor.
    The capacitor in the picture is a motor running 16 microfarad (mfd) 450 V jobbie by the look of it.
    These are a common motor capacitor just do a search on the web or flea bay
    I guess you don't need me to tell you to be careful.
    Jun 2011
    Adelaide
    27
    248
    Ahk cheers guys i got really confused when i saw the 315v and 450v ahahah :/ the motor only has the one capacitor.
    Oct 2010
    melbourne, laverton
    1,910
    Default cap
    a air con place should have it
    May 2006
    Canley Heights, NSW
    67
    529
    Big difference in prices, who's trying to rip who off ?? Australia the most expensive country in the world.
    Shane
    Got the square peg in the round hole, now can't get it out !!
    Jul 2006
    Athelstone, SA 5076
    4,258
    could be capacitor? but could also be something else.
    I can test capacitor for you, what area are you in?...without looking in the odds n sods bin, may also have 1 if yours is crook
    Oct 2004
    Southern Highlands NSW
    1,898
    That old cap was made by Ducati, the motorbike company.
    Jordan
    Jun 2012
    SA
    1,649
    Ahhhh, made in Italy.
    That explains a lot.
    Your lucky it went this long.
    Rob
    The worst that can happen is you will fail.
    But at least you tried.
    Sep 2006
    Australind , WA
    58
    1,281
    What Jhovel said....
    Also, you will also probably be able to find a suitable replacement from Radiospares and/or Element 14 ( formerly Farrnell ) Thats where I get mine from. Best not to skimp on Capacitors as they work hard and I don't trust the chinese ones....
    Capacitance is not critical, just something relatively close will do and as long as the voltage rating is as high or higher, would suit.
    Buy two and you will have a spare.....
    Apr 2013
    adelaide
    293
    Default K.D Fisher AKA Plessey
    K.D Fisher are otherwise known as Plessey Capacitors. Plessey have been around for years.
    7,189
    Quote Originally Posted by nearnexus View Post
    Rob
    I think the Romans might have a bit to say about that.
    Jun 2011
    Adelaide
    27
    248
    well i ended up buying this 16uF Multi Purpose NEW RUN Capacitor Suit 240V Motors | eBay should come by Friday, didn't want to wait a couple of weeks for one to come from china but ill be bidding on this motor Vintage Electric Motor | eBay just in case but if it works ill just use the one ill buy on the drill press since it needs a new motor Ill let you guys know if all is well!
    Cooper
  15. #15
    Nov 2005
    adelaide
    597
    check the rpm may be the wrong one usually 1440 or 2850 rpm drill press maybe different from lathe
    john
  1. Buying a lathe, finding materials
    By whatwastold in forum METALWORK GENERAL
    Last Post: 26th Oct 2006, 10:22 AM
