Results 1 to 15 of 28
Thread: 12" level - choices
10th Sep 2013, 09:48 PM #1
12" level - choices
Hi
What is the general consensus re: a good 12" level . Where to buy ? Are the Asian examples accurate enough for hobby use ? I do have a old Rabone 6" machinist level , it has seen better days and does not appear to be a high precision instrument .
Mike
10th Sep 2013, 10:07 PM #2Philomath in training
- 6,563
What do you want to use it for though? I have a high precision level that rarely gets used as it is too sensitive most of the time.
10th Sep 2013, 10:27 PM #3
10th Sep 2013, 11:23 PM #4
Hi Mike,
If thats the case why do you need a 12" level? A 6" one will do fine. I use a Rabone (thought it was a starret but its not) 6" and my cheap 8" CTC .02mm/m level to do my machinery. Aiming for 12" Just means you will pay more than a 6" without gaining any extra accuracy. The vials are the same in a 98-6 or a 98-12. You just need to put the level on the saddle, or make a jig to bridge the ways.
10th Sep 2013, 11:38 PM #5Most Valued Member
How about .0006"?
Swiss Quality Discount
Just dont try emailing him lol
The base of my H&F level was less than wonderful and if I recall correctly cost me something like $185(thanks for reminding me..... not! ) Though the vival appears to be pretty good at 0.02mm/m
Though really, if its only for leveling a lathe, What Ewan said
p.s. whats wrong with the "old Rabone " anyway?
10th Sep 2013, 11:53 PM #6Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
I use a 98/6 for general levelling. I forget if it's 005"/ft or .005"/10". It won't drive you nuts.
For survey and rebuilding work you need more sensitivity. For that I have the CTC .02mm/m one. Bring your patience pills.
11th Sep 2013, 12:15 AM #7Banned
- Apr 2013
- adelaide
- 293
levels
I have a Chinese 6" level I bought on aliexpress. It was $70 including freight and the accompanying literature says it's accurate to .002mm. It looks to be the same as the Hare and Forbes item and does a good job, of course I have nothing to compare it with, but the lathe doesn't cut tapers so I guess it does it's job..
11th Sep 2013, 12:37 AM #8Most Valued Member
I've got a Starrett 98/12. Not the most sensitive instrument but it's all I got and use it for the lathe mainly. It gets me satisfactory results. If I'm careful (and patient) I can read to 1/2 - 1/4 graduation.
I wouldn't mind one of those CTC 0.02mm/M levels but it's not a high priority since I have been happy with the Starrett and for the work I do, it's good enough.
11th Sep 2013, 10:56 AM #9
Do the old ones loose accuracy over time if not looked after? I know if they have been dinged of course they will me out, what other factors are involved?
11th Sep 2013, 11:55 AM #101915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
11th Sep 2013, 12:59 PM #11Chief Swarf Maker
- Aug 2013
- 132
Digital Bevel BOX Inclinometer Angle Gauge Meter Protractor Finder Magnetic Base | eBay
Have you guys gotten onto these? Very handy, mine gets used every couple of days. The 0.1deg resolution works out to 0.01mm/m, maybe accurate to twice that.
You zero it off a reference surface them move it where you want and see how far off you are. Would probably be great for checking lathe beds for twist etc.
11th Sep 2013, 01:16 PM #12Banned
- Jul 2011
- Melbourne Australia
- 1,376
Some one check my trig, but I make out a change of 0.1 degree over a meter to be about 1.75mm
G.Q has a 15 inch Starrett 199 for sale. Its what the Americans call a master precision level. It $350 bucks though.
http://www.woodworkforums.com/f223/s...-level-175635/
Pictures and an R.C review are here:
http://www.woodworkforums.com/f223/s...el-box-174671/
Regards Phil.
11th Sep 2013, 01:31 PM #13Chief Swarf Maker
- Aug 2013
- 132
You could well be right, i was half asleep when i worked it out so probably misplaced a decimal point or 2 )
11th Sep 2013, 01:57 PM #14Most Valued Member
Hi,
My Starrett has adjustment at one end so you can actually set it wherever you like. Doesn't have to be set all that accurately (reading level) because for my use (lathe levelling) I'm merely using it as a comparator.
I got mine pretty cheap S/H from US because it was sold with a ding at one end. When I got it, I just filed it out. I just make sure this end always hangs over and never touches the bed. Works for me!
11th Sep 2013, 11:06 PM #15
My lathe stand for my Hercus 9" with easy level (I hope)
By hairy1 in forum METALWORK GENERALReplies: 7Last Post: 29th Feb 2012, 09:47 PM
